Fastboot reason: Flash Failure
Posted 21 July 2013 - 10:50 AM
Posted 21 July 2013 - 11:29 AM
- johnthehillbilly, shane1, cinco312 and 1 other like this
Posted 21 July 2013 - 01:51 PM
I had the same problem and tried to flash the stock update (most recent) from the droid developers forum. Now when I try to boot normally it fails and when I boot into recovery, I get the message "No valid PIV block in SP for system, piv validation failed (system). Doesn't seem good...any suggestions?
Posted 21 July 2013 - 03:17 PM
So, an update. Having gotten to this point out of a desire to return to the pre-OTA 4.1.2 version (build 9.9.1Q-66), I decided to see if Matt's utility would flash a system onto my now-fast boot only device. Surprise, surprise, I picked option 1 (stock system, kernel & radio), and it actually returned my device to working order using the earlier build. I now intend to flash the stock recovery and then proceed to see if I can root the device using the earlier exploit. I guess I found the hard way to roll-back the recent OTA...
- shane1 likes this
Posted 21 July 2013 - 03:22 PM
Posted 21 July 2013 - 04:04 PM
Successfully used Matt's utility (option 2) to flash stock recovery. A question, if I use option 5 (Motochopper Root Exploit) to root the phone, can I return it to stock using option 1?
Posted 21 July 2013 - 04:39 PM
i dont see a reason why you wouldnt be able to.
- BobDeGJr likes this
sig made by
Rinkle McBally
Posted 21 July 2013 - 06:50 PM
On the other hand, unlocking the bootloader using motopocalypse appears to be a one-way trip. Has anyone been able to relock their bootloader after unlocking it with this exploit?
Posted 21 July 2013 - 06:52 PM
you cannot relock once its unlocked, did you get root?
sig made by
Rinkle McBally
Posted 21 July 2013 - 07:55 PM
- shane1 likes this
Posted 22 July 2013 - 03:13 AM
- johnthehillbilly, shane1 and BobDeGJr like this
Posted 23 July 2013 - 11:37 PM
Flash anything successfully. Easiest thing is boot logo
I was having the exact same issue and then I came across this post, and now, no more "flash failure" error. Thanks bro!
- livinginkaos likes this
Posted 24 April 2014 - 03:59 PM
have the same issue on my xt 907 where is this utility and anything special to do or just use option 2 to get rid off
Posted 24 April 2014 - 04:02 PM
I you're on the latest OTA and your BL is locked, you can't use any of Matt's utilities. What exactly is your issue?
