[ROM][AOSP][4.3] Eclipse-ver5.1-Build6.Remix - 11/02/13
Bionic Targa 4.3
123 replies to this topic
#1 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
  • LocationWhere I AM
Posted 20 July 2013 - 04:38 PM
First off this is not a MOTOBlur Eclipse build that everyone is use to. So all those options that are available to Blur base ROM do not work on this.
Do not ask if Webtop works, or Moto Share and what nots. This is AOSP base which I learned to do from
Now that the Air is Clear.... Lets Move on.
All right Guys I am back on the UnNatural Path of Voiding everyone's Warranty including mine.
I have been hacking and hacking away at this new 4.3 version so I can bring you a taste of what I like to use on a daily bases. If you choose to install this onto your device that is your choice, a good move on your part. Enjoy
First Things First
Proper Thanks goes out to
Nitroglycerine33 (for allowing his ElementalX AOSP source to be Public)
Hashcode (for his dedication for allowing us to run Custom ROM's)
dhacker29 (for never giving up on us)
These Three guys are the reason I was even able to get this going.
Find them, Donate to them and thank them ALOT.
JP, JayRod, Bama, Eydea, Mrlolli, B.E.McAllister, jl90 (for putting up with all the Question I have had and other stuff).
Thanks goes out to the tester's that got to taste this before it got launched
(You know who you are)
Standard Disclaimer
Changelog
General UI
-Theme engine
-Reboot options
-Screenshot option
-Customize lockscreen hotseats
-Eclipse mode - Choose between light and dark themes
Input Controls[/B]
-Volume rocker controls (wake, skip tracks)
-Long press back to kill
-Hardware key remapping
-Customize software keys
-Home button wake - on/off
-Volume panel and ability to unlink/link notifications & ringtons
-Clear all recents
Statusbar options
-Clock (Hide, center, right), Day of the week
-Signal text
-Combined notification count
-Custom 1% Battery Mod on Boot
-Battery Bar options
-Battery text
-Battery style options
-Power widgets/toggles
-Quick settings/tiles (Custom tiles too)
Misc apps/settings
-Quick reply Mms with emoji
-DSP manager (Enhanced for 4.3 found
-Modded AOSP camera
*Power shutter
*Enhanced shutter speed
-Quiet Hours
-AOSP File manager
-Terminal emulator
-Embedded Superuser
-LockClock
-USB audio
-Launcher2
-Advanced settings for kernel tweaks (color temp, vibration, backlight, sound)
-Profiles
-Notification and battery LED control
Tweaks and Goodies
-Extra Kernel Modules and Schedulers
-AOKP Performance app
-init.d scripts
-Build Prop tweaks
-Zram Swap (enabled on boot)
-Data and Wifi Tweaks
-The Best for Last 3g and 1x support.(Just leave phone in Global mode)
Gapps= included in the build. 1 stop installation setup.
Installation Instructions.
1. You must be on 4.1.2 on your Stock side, If you are not then get going and come back.
2. Install in SS 3.11 & (preferred) 3.60 ONLY
3. Fresh Slot ONLY install (Will work on any slot you choose)
4. Wipe, Wipe, Wipe and Wipe again....Your Mother should have taught you already....:cool:
5. Install Update then wipe cache and dalvic once more before reboot.
The Goods
Additional Theme
I don't normally ask for Donations and I will not start now, but if you feel the need then it will be greatly appreciated
  • Bama, matjmonk, mrlolli and 5 others like this
#2 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 20 July 2013 - 04:39 PM
For Future Use..........
  • cgillie92 and Ulysses like this
#3 mrlolli
mrlolli
    Put Member Title Here
  • 763 posts
  • LocationNowhere
Posted 20 July 2013 - 05:00 PM
Great job on this!
Sent from my XT875 using Xparent Blue Tapatalk 2
Nice job on the signature, jl90...thanks!
#4 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 21 July 2013 - 02:51 AM
It was a handful, but worth every hour spent on it.
Sent from my XT875 using Xparent Red Tapatalk 2
#5 bigv5150
bigv5150
  • 150 posts
  • LocationDirty Jerzey
  • Current Device(s):Droid Maxx
Posted 21 July 2013 - 05:30 AM
Nobe I have given up on ROMS but am going to give this one a try especially since it has the same birthday as me :) I will report back.
#6 bigv5150
bigv5150
  • 150 posts
Posted 21 July 2013 - 06:59 AM
So far so good very smooth I like the Green hope she continues to run smooth very nice job.
#7 cgillie92
cgillie92
  • 129 posts
Posted 21 July 2013 - 10:47 AM
Loving this ROM!! But I am getting screen flickering I don't know how or why but rebooting will fix that
#8 bigv5150
bigv5150
  • 150 posts
Posted 21 July 2013 - 12:33 PM
Been on all day and it is running just as smooth this is a great ROM loving the green theme and icons great job.
#9 FrankrBionic
FrankrBionic
  • 78 posts
  • Current Device(s):Galaxy Nexus
Posted 21 July 2013 - 01:45 PM
IMA bout to $#!+ my pants!!! FINALLY!
Sent from my XT875 using Tapatalk HD
  • mrlolli and nobe1976 like this
#10 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 21 July 2013 - 03:00 PM
I haven't seen this happening when I tested this. What apps and such are running while this is going on. A usual reboot will fix this as you can see, but try rebooting into recovery and wipe cache and dalvic again. There could be traces of the previous ROM still lurking on the Slot.
#11 rocketsaucev2
rocketsaucev2
  • 447 posts
Posted 21 July 2013 - 03:22 PM
I really want to try this but have the worst luck with phone not waking up when I ran liquid and aokp. I groaned when I saw this was kexec Sent from my DROID BIONIC
#12 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 21 July 2013 - 03:51 PM
I really want to try this but have the worst luck with phone not waking up when I ran liquid and aokp. I groaned when in saw this was kexec
Well this one I have got to say has not had that issue with me and I have been running it all week. With multiple successful reboots and playing and streaming music with 4g. The only thing I can recommend would be to clean slate Slot 1. I would even go as far as backing up all slots onto the external side and booting into Stock, UGH, to format the internal Storage. Then start all the Slots fresh and clean, but that one is up to you.
#13 bigv5150
bigv5150
  • 150 posts
Posted 22 July 2013 - 09:33 AM
Well second day and its still running great no reboots or lag at all.
  • nobe1976 likes this
#14 KingDufus
KingDufus
  • 11 posts
  • LocationBeantown
  • Current Device(s):Motorola Droid Bionic HW B
Posted 22 July 2013 - 10:57 AM
Thanks for the new ROM! Unfortunately, as in all other kexec builds for my phone, after about a day of use and a few user initiated reboots, GPS suddenly won't turn on when opening up Google Maps or GPS Status. A couple of reboots afterwards usually fixes the problem. Everything else seems to work great.
#15 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 22 July 2013 - 11:11 AM
Google Maps had a update recently, did you install it? If so uninstall it and see if that makes a difference.
#16 Apeman81
Apeman81
  • 56 posts
Posted 22 July 2013 - 12:58 PM
Giving this a go.  So far, solid and steady.  No glitches or issues.
Thanks for the effort!
#17 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 22 July 2013 - 03:42 PM
It was the lease I could do for the community. :D
  • mrlolli likes this
#18 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 22 July 2013 - 04:16 PM
Well how about those Beans Baby......
#19 rocketsaucev2
rocketsaucev2
  • 447 posts
Posted 22 July 2013 - 04:19 PM
I've never not seen 'screen' towards the top, curious
#20 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 22 July 2013 - 04:31 PM
During a work day I stream mostly via Bluetooth headset. My screen time is at the bottom.
Also tagged with one or more of these keywords: Bionic, Targa, 4.3
