XT926 bricked after car charger
XT926 repair
3 replies to this topic
#1 artsmart
artsmart
  • Current Device(s):XT926 droid razr MAXX HD
Posted 19 July 2013 - 01:15 PM
Dear All,
I need help with my XT926
today I use my charger during driving and device switched off completely.
No buttons, leds was not active on charge.
After that it starts heating up to the 50-60 degrees C
When I came home tried to charge with standard charger but nothing happend, leds is not active during charge.
1) My opinion is that something wrong with car charger and it could be the reason. But on the device itself I couldn't find any reset button to check while batterly still was full
2) Could you recommend any further steps to check the device ?
3) If service required, how to send device to the service (due to I'm in Russia) and Motorola does not support these devices in Moscow repair centers?
#2 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 19 July 2013 - 02:47 PM
you could try holding power and volume down to reboot it. its like a battery pull.
sig made by
Rinkle McBally
#3 artsmart
artsmart
Posted 19 July 2013 - 09:46 PM
I have a try but it was not helpful. It is switched off and have no  reaction to the buttons and this type of hard reset.
#4 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 20 July 2013 - 04:43 AM
Make sure your using the Motorola cable and leave it on the charger for a while you could also try hooking it up to the computer for a bit to charge off that with the Motorola cable then try the reboot  I told you about if that doesn't do anything I'd say your phone could be busted :(
sig made by
Rinkle McBally
