Hello.
To cut a long story short: I used to have my RAZR XT910 (with deleted and lost CID) running on a Chinese kernel and a modified Chinese ROM that was working like a charm. Unfortunately I messed things up with BMM (my fault!) and to un-brick it fastly I used a method that fixed the problem but that got me on
ROM: 982.124.14.XT910.Retail.en.EU
Kernel: 3.0.8-g7198280 hudsoncm@il93lnxdroid84 #1 SMP PREEMPT
As explained it appears that:
"With that unbrick method, you have flashed EMEA 4.1.2 OTA which flashes cdt.bin secure version 7. Once the cdt.bin is upgraded you will not be able to flash partitions signed with lower secure version. In your case, china system,boot,recovery have version 5 but your device is flashed to version 7. There is no known way to bypass it. You are stuck with EMEA 4.1.2 custom roms or CM variants, sorry."
Isn't there any "hard-core" method to work around this? No leak or whatever?
Thanks a lot!
