Vanilla RootBox is built straight from RootBox sources and always carries a very light installation with no extra/useless apps. This means, you can enjoy a pure Android experience combined with AOKP/CM features and some CM cherry-picks. Keep in mind Jelly Bean is only at the beginning stage of development and there will be minor bugs. Every RootBox releases are stable and always up to the challenge for a daily usage. If you're wondering how this ROM differs from any other AOKP roms out there, I only have one thing to say: Try it yourself and choose the one that meets your requirements.
For a complete list of all Features in RootBox, visit the following link: Complete Feature List
AOKP Features
Hybrid Settings
Per App DPI
Per App Colors (Statusbar, Icons, NavBar)
Per App UI (Phone, Tablet, Phablet)
Per App Expanded Mode (FullScreen)
NavBar Height
General Settings
Home button call answer (Accessibility Option)
Variable Lockscreen Pattern size (CM)
Quiet Hours (CM)
Power Sounds (CM)
Camera Shutter sound
Permissions (AOKP)
Profiles (CM)
Update Center – OTA Updates through GOO Manager
Camera
Save pictures to external memory
Timer Shutter
Voice Shutter
Power Shutter
Picture Size
Focus Mode
Color Effects
Exposure
White Balance
ISO Settings
Scenery Settings
Smart Shutter
Store Location (GPS)
Burst Shots
Clock
Clock: Increasing Alarm
Clock: Flip/Shake – Snooze or Dismiss
Clock: Disable Alarm Icon on Statusbar
MMS
Easy selector
Privacy Mode
Quick Message
Wake and Unlock
Strip Unicode
Emoji support
Direct Call
Message font size
Text area size
Phone
Blacklist
Noise supressiony, Off)
Flip Actions
Phone: Advance Phone Settings (Vibrate on Answer, Every 45 Seconds, On Hangup and On Call Waiting)
Rejected calls as missed
Voicemail can be cleared in notification
Quick Tip: To avoid bad flashes and unexpected surprises, make sure you check the md5sum of the downloaded zip file against the one displayed on AndroidFileHosting.
