[ROM][JB 4.3][AOKP/CM10.2/PA] ReVolt JB mb886 [ALPHA][09/29][ReVolt-Control]
Posted 16 July 2013 - 11:06 AM
Posted 19 July 2013 - 05:11 PM
I flashed this rom for my atrix hd....All that happens when i reboot. the revolt screen stays on with the blue wave flashing over it and it does it over and over again will not boot???? PLZ HELP me??
Posted 20 July 2013 - 03:39 AM
What gapps did u use?
Posted 24 July 2013 - 06:27 PM
When I try to tether it reboots. Regardless of what I try to do. Turned off everything, turned on everything, select only certain things to run while trying to tether, nothing works. Otherwise it is a great stable ROM. Used ROM Toolbox Pro to set CPU speeds and such and got great battery life out of it. Turned down the CPU speed and works very smoothly and with no problems.
Did note that Youtube crashes on boot. This seems typical with CM/AOPK/KANG roms, so no problem. I don't YouTube anyway....
Posted 24 July 2013 - 06:33 PM
For the crash on flash issue, there is a noted problem with the Atrix HD for the need to format the data and cache areas. It also sounds like you did not format delvic cache.
Best method is to reboot to recovery. Format system data and cache. Format delvic cache. Reboot into recovery again.
Format data and cache again.
Flash the ROM
format delvic cache again
flash Gapps (be sure to use the right one. I used gapps-jb-20130301-signed.zip)
reboot
enjoy....
Note: that it will take a while for it to rebuild cache. Let it go for a while before you get upset.
if it does not go out of the Revolt screen, reset to factor default, clear delvic cache, and reboot again.
If it still does not work, you may have had a corruption error in your download of the ROM or gapps. I had this happen to me too.
Posted 28 July 2013 - 05:20 AM
- gary1399 likes this
Posted 03 September 2013 - 05:48 PM
Fixed the OP for Tim's LAZY ASS
- timpohladthomas likes this
Posted 05 September 2013 - 07:11 PM
download link is no good
Posted 05 September 2013 - 07:16 PM
It looks like ReVolt has been pulled for a short time. It appears that Tim is working on getting ReVolt to be official, then I'm sure he'll re-post links.
Posted 05 September 2013 - 07:22 PM
You nailed it rick... I am working with the main dev to become official for moto qcom devices and while we make lots of changes we feel it's best not to have halfway working releases coming out. Very soon tho folks. Don't worry.
- RikRong likes this
Posted 05 September 2013 - 07:33 PM
Posted 23 September 2013 - 04:58 PM
Posted 02 April 2014 - 06:13 PM
This thread is no longer officially supported, please see newer officials topics is applicable
