[ROM][JB 4.3][AOKP/CM10.2/PA] ReVolt JB xt926 [ALPHA][09/29][ReVolt-Control]
56 replies to this topic
#41 DroidAddict101
DroidAddict101
  • 259 posts
  • LocationBinghamton
Posted 01 October 2013 - 11:06 AM
I downloaded the latest version this morning and could not set up due to the keyboard constantly fc'ing. Anyone else have this happen?I wiped everything before flashing and flashed the goo.im 4.3 gapps.Sent from my XT926 using Tapatalk 2
Use slim gapps instead.
  • animez likes this
#42 bjoostema1933
bjoostema1933
  • 122 posts
  • LocationNorth Carolina
  • Current Device(s):Razr HD Maxx /Nexus 7
Posted 01 October 2013 - 11:07 AM
I've heard that the fix for this is flashing the slim 4.3 gapps.  At least that worked for the AOKP release which had that identical problem.  Good luck man, I hope that solves the issue for you.
Edit. what he said, I didn't see his post, I must've been typing when it hit :)
  • animez likes this
#43 animez
animez
  • 59 posts
Posted 01 October 2013 - 11:22 AM
Thanks, I'll give it a try tonight.
#44 bigdanmeys13
bigdanmeys13
  • 31 posts
  • Current Device(s):Motorola Droid Razr Maxx HD
Posted 01 October 2013 - 02:40 PM
Try Slim GApps.
**Edit** Didn't see previous replies. Apologies for repetitive posts.
Sent from my Droid Razr HD using Tapatalk 2
  • animez likes this
#45 animez
animez
  • 59 posts
Posted 01 October 2013 - 04:58 PM
Downloaded the Slim minimal gapps and had the same problem. Downloading the AIO version now...so sloooooooow.
#46 bjoostema1933
bjoostema1933
  • 122 posts
Posted 01 October 2013 - 05:07 PM
What recovery are you using buddy?
  • animez likes this
#47 PILLMUZIK3600
PILLMUZIK3600
  • 34 posts
  • Twitter:PILL_KOZBY_
Posted 01 October 2013 - 10:26 PM
Try the 9/17 4.3 gapps on goo.im worked perfect for me the first time I flashed
Sent from my Droid Razr HD using Tapatalk 4
  • animez likes this
#48 animez
animez
  • 59 posts
Posted 02 October 2013 - 01:38 AM
I'm currently using OUDhs touch. The AIO version of Slim GApps did the trick, I still got a few fc on the AOSP keyboard but the were intermittent and I typically install the google keyboard anyway.
Man this rom is smoking fast, great work OP.
#49 bjoostema1933
bjoostema1933
  • 122 posts
Posted 02 October 2013 - 05:06 AM
I'm currently using OUDhs touch. The AIO version of Slim GApps did the trick, I still got a few fc on the AOSP keyboard but the were intermittent and I typically install the google keyboard anyway. Man this rom is smoking fast, great work OP. Sent from my Droid Razr HD using Tapatalk 2
guess the recovery wasn't the problem then, I'm glad you got it working man!
  • animez likes this
#50 xeroequality
xeroequality
  • 10 posts
Posted 03 October 2013 - 11:03 AM
Is there a mirror for the downloads? The download link from the OP is downloading at like 0.01 kbps... :-(
#51 livinginkaos
Posted 03 October 2013 - 11:28 AM
We're looking into it.  It shouldn't be as slow as it seems to be.
#52 livinginkaos
Posted 03 October 2013 - 11:39 AM
The D/L speed appears to be back to where it should be :)
  • timpohladthomas likes this
#53 pegs520
pegs520
  • 69 posts
  • Twitter:pegs520
  • Locationutica
  • Current Device(s):motorola droid razr maxx hd
Posted 07 October 2013 - 02:01 PM
I flashed this, ran it fine. Restored my apps with tibu, and now I'm without MMS/picture messaging.
It's not showing an error, just "sending" forever.
Any clue what the problem might be, or how to fix it?
It was a clean flash, I flashed twice, used normal and slim gapps, using twrp.
#54 bjoostema1933
bjoostema1933
  • 122 posts
Posted 07 October 2013 - 02:17 PM
I'm in the same boat as you, but on a different rom.  I think mms is jacked on a lot of the recent 4.3 releases in general.  I tried to configure all the apn settings manually, but to no avail.  If I figure out a workaround, I'll pm you...I think it's something to do with recent updates to the base perhaps.
#55 pegs520
pegs520
  • 69 posts
  • Twitter:pegs520
  • Locationutica
Posted 07 October 2013 - 05:46 PM
I finally figured it out! I had almost the same settings, so I don't know why it worked - maybe the APN type makes a , but I got mms/picture messaging to work with these settings from this post:
EDIT: sorry, that didn't paste right. here
Edited by pegs520, 07 October 2013 - 05:50 PM.
  • bjoostema1933 likes this
#56 bjoostema1933
bjoostema1933
  • 122 posts
Posted 07 October 2013 - 06:49 PM
Good find man!  That worked, thank you buddy!
#57 tucstwo
  • Google+:tucstwo@gmail.com
Posted 02 April 2014 - 06:12 PM
This thread is no longer officially supported, please see newer officials topics is applicable
