[ROM][JB 4.3][AOKP/CM10.2/PA] ReVolt JB xt926 [ALPHA][09/29][ReVolt-Control]
Posted 16 July 2013 - 10:04 AM
- zooyork0721, Anon5978, shane1 and 1 other like this
Posted 16 July 2013 - 10:35 AM
Posted 16 July 2013 - 10:46 AM
Yea me 2
- grafarcobier likes this
Puff the Magic Dragon
Posted 16 July 2013 - 10:47 AM
I'm assuming we download gapps too?
Proud father of a US Marine
Posted 16 July 2013 - 10:50 AM
Not sure but the file is big so gapps should be in there... Don't quote me on it though....
Posted 16 July 2013 - 10:59 AM
Flash standard 4.2.2 gapps separately.
- secretNinja likes this
Posted 16 July 2013 - 11:20 AM
Can i get a couple more screenshots please?
Posted 16 July 2013 - 11:39 AM
Sent from my MB886 using Tapatalk 4 Beta
Posted 16 July 2013 - 12:04 PM
Installed, boot looped. Rebooted, wiped and tried again........ and rebooted.......... and looping again. I'll try to reflash and see if that works.
EDIT: Flashed without gapps and it started right up. Rebooted, flashed a different gapps, and no problem.
Posted 16 July 2013 - 12:06 PM
What gapps did you use?
Posted 16 July 2013 - 03:55 PM
The gapps developed for axiom did not work. Generic gapps worked.
- timpohladthomas likes this
Posted 16 July 2013 - 04:22 PM
Sent from my Droid Razr HD using Tapatalk 2
Posted 16 July 2013 - 05:27 PM
Funny how things work, was just the opposite for me.The gapps developed for axiom did not work. Generic gapps worked.
Sent from my Droid Razr HD using Tapatalk 4 Beta
- zooyork0721 and timpohladthomas like this
Posted 16 July 2013 - 06:41 PM
Posted 16 July 2013 - 07:02 PM
Smooth install with 20130301 gapps.
Anyone running N39 or N40 on this?
I'm considering installing N40, but wondering if I should since it's running pretty well at the moment.
Posted 16 July 2013 - 07:03 PM
I run n40 on my aokp from yesterday, which would be very similar to this and it runs great. I also run crossbreeder.
- dhyamato likes this
Posted 17 July 2013 - 02:29 AM
I'm running the same combo- turning wifi tethering on reboots the phone.I run n40 on my aokp from yesterday, which would be very similar to this and it runs great. I also run crossbreeder.
