bionic stuck in fastboot and encryption faliled boot up
3 replies to this topic
#1 rp201
rp201
  • 7 posts
  • Current Device(s):bionic
Posted 13 July 2013 - 08:02 AM
carrier: verizon
phone history: was original bionic with sim from 18months ago when purchased. It was activated in the last week with a newer sim card supplied vzw. (I kept the old sim card just in case).  Phone was updated to latest system update. (I'm assuming Jellybean but in my haste I did not check for sure to verify I just assumed cause I checked for system update and it said it was up to date) I perfomed root with tinylinux virtual machine process.It  worked fine. I then went and installed boinicbootstrap.apk from 2011 (maybe I should have bought the the $2.99 one in store).  I rebooted into recovery and did a backup in cwm which was successfuly. when phone rebooted after backup it received an encryption failed error. I attemepted to use HOB 10.3 (rsd lite 5.7)  app to flash cdma_targa_9.8.2O-72_VZW-22_cfc.xml.zip. the following way.
1. select fastboot mode in bios boot
2. connected cable
3. selected cdma_targa_9.8.2O-72_VZW-22_cfc.xml.zip file and decrompress and run.
the flashing process fails on step 5/24 fb_mode
any suggestions?
#2 rp201
rp201
  • 7 posts
Posted 13 July 2013 - 10:13 AM
found a new flash file here
 that addresses the oem_fb_mode error.
Phone is up and running. thank you.
  • purplekero likes this
#3 transmissiontech
transmissiontech
    Your Tranny Specialist
  • 7,484 posts
Posted 13 July 2013 - 01:32 PM
Bootstrap will not work on the bionic with JB, it will totally brick the phone.
Google pixel 32 gig....
#4 rp201
rp201
  • 7 posts
Posted 14 July 2013 - 01:13 AM
yes transmissiontech! I looked after I leaped.  I'm now running safestrap 3.11.  same result with more flexabilty.
