[RECOVERY XT912] Safestrap Recovery v3.7x [05/15/2014 V3.73 - TWRP 2.7]
safestrap
875 replies to this topic
#1 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
  • Twitter:Hashcode0f
Posted 22 May 2012 - 08:06 AM
POPULAR
SAFESTRAP v3.73 (2nd-System Bootstrap / Recovery) for XT912 Spyder
** INSERT STANDARD DISCLAIMER: I'm not responsible for any damage you do to your phone using my tools. Always have a fastboot available for disaster recovery. **
Download the APK Installer:
Mirror 1:
Mirror 2:
FOLLOW THESE INSTRUCTIONS:
[ DOUBLE-CHECK you have the "Spyder" version ]
NOTABLE TWRP-BASE CHANGES:
  • Key/button vibration in recovery and MANY more 2.7.0.0 updates
  • Screen saving in recovery. Can set the timeout under Advanced->Settings->Screen *Don't freak out of the screen is dark, try the power button.
  • SElinux support in recovery
  • and much much more.. check the TWRP changelog here:
DEVICE SPECIFIC SAFESTRAP CHANGES:
  • [05/15] (3.73) Bugfix for dual SD card UMS mounting and pull in TWRP changes
  • [04/14] (3.72) Mostly other device updates
  • [01/15] (3.71) Code cleanup
  • [01/15] (3.71) Minor hijack updates
  • [12/18] (3.70) Mount cleanup during hijack / debugging output
  • [12/18] (3.70) Splashscreen: Instant stock boot key (needs to be set for Moto OMAP4's still)
  • [11/13] (3.65) recovery init.rc cleanup
  • [11/13] (3.65) fix updater build for cm 10.1 and 10.2
  • [09/20] (3.60) Better handling for virtual images > 2gb
  • [09/20] (3.60) Much improved block device handling
  • [09/20] (3.60) Bugfix in script translation
  • [09/20] (3.60) hijack / init.rc tweaks
  • [09/20] (3.60) update to TWRP 2.6.3.0 base recovery
  • [09/06] (3.53) Fixed mass_storage in recovery (via Mount menu)
  • [09/06] (3.53) Added Webtop to partition backup list (optional)
  • [09/06] (3.53) New virtual systems created will be 640mb (got reset 600mb)
  • [09/06] (3.53) Fixed file selector when changing from internal to external storage (previously location wouldn't update)
  • [09/05] (3.52) added "Reboot to Recovery" in APK
  • [09/04] (3.51) Disabled screen blank while creating a rom-slot
  • [09/04] (3.51) Fixed openrecovery script processing for stock slot to re-inject hijack after .zip install (cmupdater on stock now works)
  • [08/30] (3.50) If running a new CM10.1/CM10.2 ROM (08/30 or later) you *should* be able to install Safestrap and update the recovery w/o having to go back to stock. If Safestrap shows "recovery not installed" while you're on a ROM-slot, then that ROM hasn't been updated and it won't work. Swap back to stock ROM and update Safestrap from there.
  • [08/30] (3.50) Worked on stock ROM flashing and *should* work with CM10.1/CM10.2 builds on or after 08/30 *WILL NOT WORK WITH OLDER ROMs.*
  • [08/30] (3.50) Battery meter is back
  • [08/30] (3.50) Updated TWRP theme
  • [08/30] (3.50) Added partition sizes to ROM-slot screen when it's ACTIVE
  • [08/30] (3.50) Added "Check FS" function to ROM-slot screen when it's ACTIVE
  • [08/30] (3.50) Complete re-write against TWRP 2.6 base (up from version 2.2.2.1):
  • [12/29] (3.11) Allow use of custom updater-binary in .zip files for flashing on stock ROM (virtual slots still use prebuilt updater-binary in recovery).
  • [12/29] (3.11) BUGFIX: Fixed fake flash error at the end of a .zip install. (No real error, .zip installs fine)
  • [12/29] (3.10) Early support for booting custom ROMs on stock partitions. (Custom ROMs will need to be worked out for XT912 on JB4.1 still)
  • [12/29] (3.10) Enable flashing to stock ROM
    • After .zip installations, nandroid restore or system wipe on the stock ROM: the current Safestrap files are restored to the system partition (Doesn't include the APK in /data -- so if you're restoring an old backup, be sure to update the Safestrap APK)
    • During the Safestrap files restore a check is done to be sure there are minimal files on /system to re-enter Safestrap
  • [12/29] (3.10) New virtual system partitions will be 640mb (closer match to stock RAZR/D4)
  • [12/27] (3.07) Bugfix: missed some changes in Safestrap 3.06
  • [12/26] (3.06) Bugfix/Update for JB4.1 OTA for DroidRAZR (Non-JB devices can also use)
  • [10/17] (3.05) Fixed SD card / emmc sharing in recovery (UMS)
  • [10/17] (3.05) Fixed recovery installation/removal from ROM-slots
  • [10/14] Updated to v3.04 BETA.
  • [10/14] Recovery is now based off TWRP 2.2.2.1 (fully featured touch-based recovery)
  • [10/14] Can create up to 4 Virtual ROM-slots to flash ROMs to and when "Active" ALL TWRP functions affect that ROM-slot (For example: Flashing .zips, Backup and Restore)
  • [10/14] Nearly instant swapping from ROM to ROM
  • [10/14] User selectable data partition sizes during ROM slot creation: 1GB, 2GB or 3GB
  • [10/14] ROM slots are saved on the internal emmc space so that preinstall and webtop partitions are no longer used and shouldn't break OTAs.
  • [10/14] Charging in recovery
  • [10/14] Supports "Reboot Recovery" from Android OS
Entry to recovery via Splashscreen on boot-up. The screen stays up for around 8-10 seconds and if you hit the menu button, it takes you to Safestrap Recovery.
SPECIAL THANKS TO:
  • The entire TWRP team who has built an AMAZING recovery system.
  • The testers which have helped in past and present versions of Safestrap, knowing that it could mean they brick their devices.
As always, let me know what you think!
SCREENSHOTS (showing slightly older TWRP base)
  • MrFrankRazr, mugsy77, mattlgroff and 40 others like this
#2 STiK
STiK
    STiK in the Mud
  • 304 posts
  • LocationEverett, WA
Posted 22 May 2012 - 08:30 AM
Bout time you did something worth while :P
  • fatmando2 likes this
#3 Guest_BDH_*
Guest_BDH_*
Posted 22 May 2012 - 08:33 AM
Thanks Hash!!!!
#4 holla
holla
  • 68 posts
  • Locationatlanta,Ga
  • Current Device(s):DNA
Posted 22 May 2012 - 09:27 AM
hmm...i cant get it to boot into recovery.i removed bootstrap and did a wipe cache.do i need to do a wpie dat/factory reset?
#5 kl0wn
kl0wn
  • 192 posts
Seems like a pretty good sign for the Razr peeps :lol:
#6 zachjeep
zachjeep
  • 172 posts
Posted 22 May 2012 - 10:22 AM
I had to push both volume keys like standard recovery to get safestrap to load when the screen was blank after I pushed menu on the spash screen.
Doing it up with .79 CM9
#7 theonlycosmic
theonlycosmic
  • 470 posts
  • LocationCalifornia
Posted 22 May 2012 - 10:24 AM
You have to completely remove bootstrap from your system. To do this, search how to remove bootstrap. It will tell you what to do.
#8 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 22 May 2012 - 10:52 AM
Wow, that's really odd. It does take a while (10 seconds?) from the menu press to when Safestrap Recovery shows up.
Could you try again, and if the screen never shows up, try using the menu/home buttons to move the selection around and see if that causes the screen to show up.
  • BytecodeMe and The Persuader like this
#9 holla
holla
  • 68 posts
Posted 22 May 2012 - 11:03 AM
i'm gonna go back to stock and do it all over i'm off today and bored and need something to do this time w/out install bootstrap to see if i can get it to work this time. :)
#10 _base2
_base2
  • 810 posts
Posted 22 May 2012 - 11:24 AM
for you lazy folks...
(how to remove bootstrap)
[ sent from _base2 ]
#11 Rycix
Rycix
    Bouncing Ball Of Energy / Android Rescue Squad
  • 107 posts
  • LocationNew England, USA
  • Current Device(s):XT912
Posted 22 May 2012 - 11:42 AM
Link on your site points to 1.09 safestrap and is labeled as the 2.00 safestrap
Droid Razr XT912, cooling down with ICS on 6.16.211
#12 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 22 May 2012 - 12:49 PM
Wow. Epic fail on my part. Thanks for the headsup. It's fixed.
  • Rycix likes this
#13 STiK
STiK
    STiK in the Mud
  • 304 posts
Posted 22 May 2012 - 01:17 PM
lol
#14 brucb3
brucb3
  • 19 posts
Posted 22 May 2012 - 01:37 PM
So does this work for people on the leaks .84 and .85?
#15 _base2
_base2
  • 810 posts
Posted 22 May 2012 - 01:44 PM
Yes
[ what path? ]
#16 2tealth
2tealth
    I Cannot Spell Stealth
  • 133 posts
Posted 22 May 2012 - 03:22 PM
This is great hashcode, thanks a lot for your work.
Founder and main developer of Team SpeedCore
#17 brucb3
brucb3
  • 19 posts
Posted 22 May 2012 - 04:22 PM
Yes
[ what path? ]
What I meant to say was can I use this to go from leak .84 to leak .206?
#18 chavist
chavist
  • 69 posts
Posted 22 May 2012 - 04:38 PM
I have followed all of the steps to uninstall bootstrap, installed safestrap and get to the secondary boot screen; however, when I try and enter recovery the screen stays black and I end up resetting the phone. Any help
#19 Guest_BDH_*
Guest_BDH_*
Posted 22 May 2012 - 04:40 PM
No it's just a recovery. I'm not around my PC right now but look in the development section. Matt just released a method to get from .84 to .206
  • sk842018 likes this
#20 _base2
_base2
  • 810 posts
Posted 22 May 2012 - 04:49 PM
Me neither lol but here it is anyway :)
)!-[6.14.84/85,-6.16.203/204/206]
Get Unstuck From Ics(But Not Back To Gb)! [6.14.84/85, 6.16.203/204/206]
[ what path? ]
Also tagged with one or more of these keywords: safestrap
