[ROM][JB 4.3][AOKP/CM10.2/PA] ReVolt JB xt907 [ALPHA][09/29][ReVolt-Control]
#61
Posted 21 July 2013 - 04:48 PM
#62
Posted 21 July 2013 - 04:54 PM
ok so i thought this should be pretty basic to flash this.... i mounted system, then wiped, and then mounted again, then flashed and I got stuck in a boot loop. What am i missing?
Do not mount system. Try flashing again without mounting the system and use standard gapps and u should be fine.
#63
Posted 22 July 2013 - 04:49 PM
Ok so I tried to do it that was as well and nothing.... just put me into a boot loop again.... I can figure out what is going on here. Quick question I noticed in the title of this rom it says port does that have anything to do with the rom and how it behaves or how my phone needs to be set up to run it? I have flashed flying jelly and touchwiz a couple of times and they load up just fine. (just to give you an idea of what has worked for me in the past.)
#64
Posted 22 July 2013 - 08:12 PM
I always Mount, wipe twice, reboot recovery, Mount then install .works for meOk so I tried to do it that was as well and nothing.... just put me into a boot loop again.... I can figure out what is going on here. Quick question I noticed in the title of this rom it says port does that have anything to do with the rom and how it behaves or how my phone needs to be set up to run it? I have flashed flying jelly and touchwiz a couple of times and they load up just fine. (just to give you an idea of what has worked for me in the past.)
#65
Posted 22 July 2013 - 08:14 PM
What recovery you usingOk so I tried to do it that was as well and nothing.... just put me into a boot loop again.... I can figure out what is going on here. Quick question I noticed in the title of this rom it says port does that have anything to do with the rom and how it behaves or how my phone needs to be set up to run it? I have flashed flying jelly and touchwiz a couple of times and they load up just fine. (just to give you an idea of what has worked for me in the past.)
#66
Posted 23 July 2013 - 03:36 AM
Port just means I made a rom work on a device it was not currently working on.
#68
Posted 24 July 2013 - 02:23 PM
#71
Posted 26 July 2013 - 02:28 AM
#72
Posted 26 July 2013 - 02:35 AM
#73
Posted 28 July 2013 - 05:28 AM
- neckchop and Noigel like this
#74
Posted 03 September 2013 - 05:44 PM
Fixed the OP for Tim's LAZY ASS
- johnthehillbilly, Noigel, timpohladthomas and 1 other like this
#75
Posted 03 September 2013 - 10:49 PM
Flashing now Revolt 4.3!
Thanx, Sir!
UPD - AOSP keybord FC ((
PIE-control don`t work - only "home" & "recent apps" buttons works
But - veeeryy fast boot & great smoothness!
Waiting next version!
Tim - you are the best!
Motorola Droid Razr M XT907 / ROM: KitStalk by GraberRoms
#76
Posted 23 September 2013 - 04:06 AM
Sent from my Droid Razr M using Tapatalk 4
#77
Posted 23 September 2013 - 04:42 AM
#78
Posted 24 September 2013 - 12:07 PM
#80
Posted 24 September 2013 - 12:33 PM
