[ROM][JB 4.3][AOKP/CM10.2/PA] ReVolt JB xt907 [ALPHA][09/29][ReVolt-Control]
#41
Posted 12 July 2013 - 03:47 PM
WE ARE DOING BIG THINGS! :
- neckchop and RikRong like this
#42
Posted 12 July 2013 - 05:45 PM
#43
I have a question how does this rank on battery life? I'm on axiom got 15 hours. With 12% left with moderate use.. Is this Any better?
#44
Posted 12 July 2013 - 05:47 PM
I have a question how does this rank on battery life? I'm on axiom got 15 hours. With 12% left with moderate use.. Is this Amy better?
Only way to be able to compare is run it and see... To be honest... I flash stuff all day and am in twrp a lot of the day too... So my battery life is always horrible... Haha... Sorry buddy but I'm just not a good judge.
- romma1 likes this
#45
Posted 12 July 2013 - 06:15 PM
I've run every AOSP ROM out there right now, and they're all similar on battery life. The best battery I saw, though, was on AOKP.
- timpohladthomas likes this
#46
Posted 17 July 2013 - 05:32 AM
Sent from my DROID Razr M
#47
Posted 17 July 2013 - 05:34 AM
I'm running this now, chameleon os kept freezing up and I had to force reboot. Only thing with this revolt is when you turn on wifi tether it reboots phone.
I have heard that from other people... Hopefully Razrqcom will fix that soon and I will sync up and rebuild.
- CamoCustom likes this
#48
Posted 17 July 2013 - 06:08 AM
Yeah I'm getting the reboot too when turning wifi tether on..
#49
Posted 17 July 2013 - 06:55 AM
Hey mr Tim, would you happen to know how to get the Nav and Status bar transparency to go away? its only on the launcher homescreen, when going into apps it gets dark, currently though, its transparent.
#50
Posted 17 July 2013 - 06:58 AM
I think it is in revolt control/navbar
#51
Posted 17 July 2013 - 07:01 AM
Yea its there, but only on the launcher home screen it reverts back to transparent, very odd.
#52
Posted 17 July 2013 - 07:02 AM
#53
Posted 17 July 2013 - 07:19 AM
Example :
Oooh, that's meant to be like that. It would look weird with transparent bars in an app. Also, you can change that in hybrid properties/interface/per app color
#54
Posted 17 July 2013 - 07:24 AM
i was wanting the transparent part gone, thats all. no big deal, just wondering if I was missing something
#55
Posted 17 July 2013 - 07:45 AM
You have to go into either revolt control/general ui and change transparency options or in hybrid properties per app color and change the options for your launcher
#56
Posted 20 July 2013 - 02:23 PM
Hey guys im loving this rom. ive tried a few others but the customization on this is so far superior. The only hitch is the one thing that I absolutely must have. Whether through Apollo or Google Music there is no sound coming from the left side of my car or left earbud, even on max volume. Ive installed from stock twice now, once with mounting the system and once without, and it still will not work. If anyone knows whats going on please help me out Id like to keep this rom.
#57
Posted 21 July 2013 - 05:31 AM
#58
Posted 21 July 2013 - 06:07 AM
Need help...no soft keys. Did I missed something?
They are disabled by default... Go into settings/hybrid properties/interface and move the navbar slider to the right.
#59
Posted 21 July 2013 - 12:28 PM
ok so i thought this should be pretty basic to flash this.... i mounted system, then wiped, and then mounted again, then flashed and I got stuck in a boot loop. What am i missing?
#60
Posted 21 July 2013 - 12:55 PM
Bad DL possibly. That should have worked.ok so i thought this should be pretty basic to flash this.... i mounted system, then wiped, and then mounted again, then flashed and I got stuck in a boot loop. What am i missing?
