[ROM][JB 4.3][AOKP/CM10.2/PA] ReVolt JB xt907 [ALPHA][09/29][ReVolt-Control]
104 replies to this topic
#21 Noigel
Noigel
  • 197 posts
  • LocationUkraine, Ivano-Frankivs`k
  • Current Device(s):Motorola Razr M XT907 / Motorola Razr I XT890
Posted 09 July 2013 - 09:41 PM
Can I get performance control on ReVolt?
And what about reboot options - is it normal - I have only options "recovery" & "reboot".. May be I flash something wrong?
Motorola Droid Razr M XT907 / ROM: KitStalk by GraberRoms
post-103018-0-11429500-1388984908_thumb.
#22 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 09 July 2013 - 10:05 PM
If performance options aren't in the menu settings, use an aftermarket app for that.  With most of the newer AOSP ROMs, you have to enable the "advanced reboot" options in the Developer Options menu.
#23 Noigel
Noigel
  • 197 posts
Posted 09 July 2013 - 10:08 PM
Thanks, sir!
#24 Noigel
Noigel
  • 197 posts
Posted 09 July 2013 - 10:09 PM
All for you, Sir!
UPD - on Russian forum 4PDA one man flash just ROM + Gsm-fix & have GAPPS..
It means it intergated.. X_O
Hm... I`m reflash ROM & it have not GAPPS included!.. x_O
I tried PA GSM fix - still FC "com.android.phone"..
AOKP GSM-fix have the same..
When I try to open mobile networks settings it have FC
#25 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 09 July 2013 - 10:12 PM
AOSP ROMs don't have GAPPs included. This should be pretty common knowledge by now.
Tim, you're on roll, I'm definitely looking forward to checking this out.
  • Noigel and timpohladthomas like this
#26 pbanj
pbanj
  • 64 posts
  • Current Device(s):razr m
Posted 10 July 2013 - 09:42 AM
did you try a fresh flash with wiping everything before you tried each gsm fix? you can also try the cm10.1 gsm fix
#27 x60centenergyx
x60centenergyx
  • 45 posts
  • LocationAtlanta, GA
  • Current Device(s):XT907
Posted 10 July 2013 - 02:49 PM
Just flashed and love this ROM! Thanks for this!
Quick question.. How do I enable the navbar? I can get Pie to work but after properly flashing and a couple reboots I can't get the navbar to work..
#28 BwingG
BwingG
  • 140 posts
  • LocationSeattle
  • Current Device(s):RazrM
Posted 10 July 2013 - 02:56 PM
Was using this Rom just fine then tried listening to music with Google app and bricked phone. Any ideas
#29 pbanj
pbanj
  • 64 posts
Posted 10 July 2013 - 04:38 PM
can you get into recovery?
#30 BwingG
BwingG
  • 140 posts
  • LocationSeattle
Posted 10 July 2013 - 04:46 PM
the first 2 tries no.  third time was a charm though.  needed phone so just reverted back to DR.  liked the rom fine till that.  ill be back im sure
#31 BwingG
BwingG
  • 140 posts
  • LocationSeattle
Posted 10 July 2013 - 08:06 PM
User error I think. When tibu restores Google music an error happens. I just installed and reinstalled out of market. No problems now
  • neckchop likes this
#32 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 10 July 2013 - 08:52 PM
This why it's recommended to clean install apps.  TiBU is good for restoring data to certain apps, but restoring everything with TiBU seems to cause issues.
#33 lowvolt
lowvolt
  • 478 posts
Posted 10 July 2013 - 08:55 PM
So many roms. What to do? Lol
  • timpohladthomas likes this
#34 Noigel
Noigel
  • 197 posts
Posted 11 July 2013 - 03:15 AM
I wipe everything - no results..  But with CM10.1 GSM-fix it works perfect! )
#35 BwingG
BwingG
  • 140 posts
  • LocationSeattle
Posted 11 July 2013 - 05:25 AM
Ok I was wrong. When my phone connects to Bluetooth it freezes and then reboots. When it restarts Bluetooth is still on so it freezes and restarts again. Was able to get to recovery. Back to rage I goo I need Bluetooth in my life.lol
#36 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 11 July 2013 - 05:37 AM
Sorry buddy. As soon as I here if a fix I will update this rom.
  • BwingG likes this
#37 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 11 July 2013 - 05:43 AM
Yep, this is prevalent across all the AOSP ROMs right now.
  • neckchop, jesseg91631 and timpohladthomas like this
#38 BwingG
BwingG
  • 140 posts
  • LocationSeattle
Posted 11 July 2013 - 05:54 AM
NO worries Tim. Thanks RikRong. I'll bee watching this Rom. it's been my favorite 4.2 room so far.
#39 lowvolt
lowvolt
  • 478 posts
Posted 11 July 2013 - 11:17 AM
I flashed this and had no nav bar. Did I miss something? Rebooted a couple times to no avail.
#40 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 11 July 2013 - 11:39 AM
It is hidden by default.. Go into hybrid properties/tools/expert mode then go to interface and change the navbar percent.
  • RikRong and lowvolt like this
