safestrap?
7 replies to this topic
#1 FrankrBionic
FrankrBionic
  • 78 posts
  • Current Device(s):Galaxy Nexus
Posted 08 July 2013 - 04:55 PM
ok so ive had my bionic for a while now. and ive noticed after a while my roms bog down and get slow. so i went back to stock it was lightning fast compared to cm10.1 but after a while it got slow. like unusable slow. i went back to cm10.1 without wiping or anything. just back to my old rom slot. and it was as fast as stock was when i first started using it? anyone know why? will there be a new version of safestrap to fix this? what can i expect
#2 Guest_BDH_*
Guest_BDH_*
Posted 08 July 2013 - 09:22 PM
The problem isn't safestrap. The problem is how many processes are running on your phone and what those processes are. When you first boot, there are only a few processes going on, after using your phone for a while, processes start to add up and your phone will begin to slow down. There's really nothing you can do to fix it other than use less apps and have less stuff running at the same time, or upgrade your phone.
#3 FrankrBionic
FrankrBionic
  • 78 posts
Posted 08 July 2013 - 11:36 PM
No. I have both stock and cm10.1 running without anything installed. All I have dine to both is flashed gapps and all I do is go to the browser and look around. And its still slow
Sent from my XT875 using Tapatalk HD
#4 FrankrBionic
FrankrBionic
  • 78 posts
Posted 08 July 2013 - 11:38 PM
And I was told by someone who replayed to a comment I put on blurry rom that its a problem with safe strap I think his name was Bama or something
#5 Guest_BDH_*
Guest_BDH_*
Posted 08 July 2013 - 11:45 PM
Well then this is probably a question you should bring up to Hashcode0f since he made Safestrap. I can say with 80% certainty that it's not safestrap causing the issue.
#6 johnthehillbilly
Posted 09 July 2013 - 12:25 AM
You can also try this ... autokiller memory optimizer ...
Set to aggressive (or above) it should speed you up quite a bit........
#7 FrankrBionic
FrankrBionic
  • 78 posts
Posted 09 July 2013 - 05:28 AM
ill give it a try. and another thing. i never had any of these issues on ics when  i was using safestrap 3.05
#8 nitephlight
nitephlight
  • 82 posts
Posted 17 July 2013 - 05:26 PM
fwiw : i run project lense recovery for this exact reason (though i have no proof of safestrap causing the issues).
it's actually CWM bootstrap for RAZR so be VERY careful. i can confirm that most mods install successfully, but you have to be extra vigilant- never blind flash always view the updater script to make sure it is not doing something heinous (AC!D sound is one
#not responsible for damages etc though i have modded some portions to get around some minor headaches. feel free to PM for those, can't post for liability and all lol
