[4.2.2][3.12.21] MIUI v5 [Multi-Language]
240 replies to this topic
#1 Tquetski
Tquetski
  • 156 posts
Posted 04 July 2013 - 04:18 PM
// XT907 Droid Razr M
// Android 4.2.2
// Current Version [ 3.12.21 ]
// All Languages
MIUI ROM 3.12.20/21 Full Changelog
[Home screen]
New - App location function added in Global Search (12-17)
Optimization - Auto-complete search: User doesn't need to enter the full name of the app or file they are looking for to view search results (12-17)
[Calendar]
New - New version (new day view and month view, transparent black and full white widgets added) (12-19)
Fix - Fixed display issue with description on calendar details page (12-19)
[Contacts]
Optimization - When user is not signed in to Email account, tapping a contact's picture on their cover page will display their Email address (12-17)
Fix - When an unknown number was added to contacts, sometimes the list view would not be displayed correctly (12-17)
Fix - Sometimes, when syncing contacts from SIM card to phone, app would FC (12-17)
Fix - When user had no contacts, the "Select all" button could still be tapped (12-17)
Fix - On contact's detail page, birthday was displayed incorrectly (12-17)
Fix - When contact's detail page had 3 tabs, the triangle indicating the current tab would not align properly (12-17)
Fix - When airplane mode was on, user would be reminded to re-sign in to their Xiaomi Account (12-17)
Fix - When using the +17951 and +86 prefixes to dial the same number, the number would display as two separate numbers in call history (12-17)
[Clock]
Optimization - Updated 2014 holiday info for China ("work days" for alarm settings) (12-19)
[Downloads]
Fix - File formats and links to apps were incorrect (12-17)
[Phone]
Fix - Some parts of the dial pad were displayed incorrectly (12-17)
[Messaging]
Fix - Outing going message status icon displayed incorrectly (12-18)
[MiCredits]
New - Horizontal view added for pop-up payment windows (12-18)
New - Details page for user purchase and top-up history (12-18)
New - After top-up card QR code is read, app will complete top-up automatically (12-18)
Optimization - When user needs to enter a password, keyboard appears automatically (12-18)
Optimization - Lock screen hides user account info (12-18)
[MiCloud Back ups]
Optimization - Only apps that have been used on the day of the back up are backed up to cloud (12-19)
[Music]
New - Sync playlist feature (12-17)
New - Song select feature for Leishi KTV consoles (12-17)
New - Baidu High Quality Music service (pay per month) (12-17)
[Security Center]
Optimization - After check process is complete, new title displayed at Cache Clean Up page (12-19)
Optimization - In Permissions, user can view blank pages display format (12-19)
Fix - After check process was complete, tapping the Clean up button would cause app to FC (12-19)
Fix - After apps were designated as risks or viruses during scan, when user tapped app to view details, the app size would display as "0" (12-19)
[Video]
Fix - Sometimes when user was streaming content, app would FC (12-19)
Fix - User couldn't delete items in "My videos" list view (12-19)
MIUIv5 3.12.21 Download
12-24-2013:
Working:
- Everything
* Make sure to enable ADB debugging if you encounter MTP issues.
MIUI General FAQ
Q: How do I root this?
A: Enable root in the perm manager, which can be found in the security folder.
Q: Why is G-Apps not listed for Download?
A: Too Bloaty, add a Google account and install the play store as an APK, I suggest using Aptoide to find it.
Q: 4G LTE isn't working
A: Load the Phone, dial *#*#4636#*#*, goto Phone information, Set preferred network type to LTE/CDMA auto (PRL).
Q: Help! Phone/SystemUI/Keyboard Isn't working/Is Force Closing!
A: Make sure to do a completely clean wipe, also I'm not sure how well this will work if flashed in CWM.
Q: The Browser looks terrible.
A: Settings -> Advanced -> User agent string -> MiOne (It Renders much better & more naturally!)
Q: My Filesystems won't mount/My PC can't see my device/My phone won't act as a MTP/USB Mounting isn't working!
A: Settings -> Developer Options -> Enable Development / USB Debugging (switch both to on)
  • neckchop, KaChow, Noigel and 7 others like this
#2 brandon71
brandon71
  • 553 posts
  • Google+:tbd7171@gmail.com
  • LocationKodak, TN
Posted 04 July 2013 - 04:43 PM
This is gonna be great awesome work
#3 Tquetski
Tquetski
  • 156 posts
Posted 04 July 2013 - 04:45 PM
I have a build of this I'd like tested, updating OP now, please leave feedback
#4 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 04 July 2013 - 06:15 PM
Cool I'll give it a go when my phone charges up
  • neckchop likes this
#5 neckchop
neckchop
    pluh!
  • 477 posts
  • Locationatlantic City
Posted 04 July 2013 - 07:35 PM
Its been a while since I've tried miui, I'll give it a shot too, soon as a charge up. Haha. Thanks!
#6 aokifay
aokifay
  • 22 posts
Posted 04 July 2013 - 08:03 PM
how to flash
#7 Tquetski
Tquetski
  • 156 posts
Posted 04 July 2013 - 08:19 PM
the same way you flash CM10
#8 aokifay
aokifay
  • 22 posts
Posted 04 July 2013 - 08:32 PM
i need chinese
#9 aokifay
aokifay
  • 22 posts
Posted 04 July 2013 - 08:33 PM
CWM,fail..........
ss3,ok!
#10 Noigel
Noigel
  • 197 posts
  • LocationUkraine, Ivano-Frankivs`k
  • Current Device(s):Motorola Razr M XT907 / Motorola Razr I XT890
Posted 04 July 2013 - 10:16 PM
What about GSM usage? Is Cm10 GSM-fix have compatibility with MIUI?
Motorola Droid Razr M XT907 / ROM: KitStalk by GraberRoms
post-103018-0-11429500-1388984908_thumb.
#11 RandumAccess
RandumAccess
  • 28 posts
Posted 05 July 2013 - 05:39 AM
I kept getting a sim toolkit popup that wouldn't go away, other than that popping up every second it seemed good lol
#12 lowvolt
lowvolt
  • 478 posts
Posted 05 July 2013 - 05:53 AM
Downloading now
I will report back.
#13 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 05 July 2013 - 07:08 AM
Flashed a few minutes ago and I'm getting the SIM toolkit msg too I remember getting that on cm10
Also in preferred network mode you need to add the option to choose lte/cdma/evdo so I can get 4g
Your only options are lte/cdma and cdma
Other than that it's pretty awesome great work
#14 lowvolt
lowvolt
  • 478 posts
Posted 05 July 2013 - 07:09 AM
My initial findings are.
Only get 3g
When going into settings and trying to change ringtone it never loaded a list
I received a call no ringtone was heard and I could not answer.
When I tried to call back phone was very laggy. Never was able to complete call.
A notification pops up asking about open sim channel yes or no.
I will play more in a bit
#15 yelson13
yelson13
  • 58 posts
Posted 05 July 2013 - 09:30 AM
some apps like Flashlight don't work either and the emojis in messaging app won't show.
#16 Tquetski
Tquetski
  • 156 posts
Posted 05 July 2013 - 12:05 PM
This is not a 'complete' release, just an alpha to test stability in general; all Razr roms will need a MIUI kernel which I'm working on atm in order to fully incorperate Shelld and allow for CM10.1 based ports which everyone really wants
  • neckchop, yelson13 and brandon71 like this
#17 gemini7
gemini7
  • 46 posts
Posted 05 July 2013 - 12:12 PM
would be nice to see a release for droid razr cdma 912xt, hope it can be a possibility I really liked miui when I had ics
#18 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 05 July 2013 - 12:51 PM
The only major bug I seen was not being able to switch to lte/cdma/evdo which allows 4g but for an alpha your doing good
  • neckchop and shane1 like this
#19 Tquetski
Tquetski
  • 156 posts
Posted 05 July 2013 - 03:02 PM
You can but you need to do an APN procedure, I'll post more on it in a bit
#20 lowvolt
lowvolt
  • 478 posts
Posted 05 July 2013 - 03:48 PM
so are you able to make and receive calls?
