[ROM] [xt912] [JB .16] Blurry 2.2 (Official Build 10-18-13)
1287 replies to this topic
#1 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
Posted 28 June 2013 - 10:15 AM
  234.88KB   1410 downloads
  303.94KB   1422 downloads
  89.91KB   1406 downloads
  283.52KB   1349 downloads
Blurry Link:
*Must be on JB .16*
Features:
-Deodexed -thanks mhous33
-Debloated
-1% Battery -thanks kryptonite
-Toggles -thanks kryptonite
-Extended Power menu -thanks kryptonite
-Blurry Boot Animation -thanks Markus
-Blurry Theme -thanks Markus
-init.d support at boot
-Governors / schedulers loaded
-Scripts
-Blurryzips and Wallpapers on /sdcard/blurryzip
-Superuser
-OTA Updater
-Tether - thanks TLS
-Apps
-Blue Notification light - thanks vtwinbmx
-2 Themed 4.2 Keyboards (change the default)
-Battery Mod switch
-Baked in AC!D music
-Removed Bug2Go
-Aosp Dialer / Contacts - thanks Nitro
-CPU Control - thanks Team Fuzion
-Transparent Messenger - thanks Zack
-Transparent App Drawer
How to Install Blurry:
Boot into Safestrap v3.11
Select any Slot
Wipe Data / Factory Reset
Wipe cache and dalvik cache
Wipe System
Install Blurry.zip
Reboot System
Initial install takes atleast 5 minutes
Let the 1st boot settle for 5 minutes
Reboot
Enjoy
  • cmorty72, Groundhound, fastfoodfred and 19 others like this
#2 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
Mods
Settings Background:
Settings Background 1:
Settings Background 2 (by Zack):
Settings Background 3 (by Zack):
Restore Black Background:
*Just Flash, no need to wipe anything*
Few Wallpapers by Zack:
  • prosaschi, papanut and Zack like this
#3 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
Pro Tips
Pro tip #1
-Change your keyboard to
 keyboard.  For now, don't take the Google Keyboard update.  It breaks the theme.
Pro tip #2
-Swipe down on left part of screen for pulldown menu.
-Swipe down on right part of screen for quick settings menu.
Pro tip #3
-Change lock screen "Blurry" branding to whatever you want. Using a file explorer, go to /
/eri.xml. Edit the file and change ALL (multiple areas) the "Blurry" branding to whatever. Save it. Make sure its permissions are still rw-r-r. Reboot.
  • prosaschi and papanut like this
#4 Ethan82691
Ethan82691
  • 113 posts
  • Google+:blindside7x@gmail.com
  • LocationIdaho
Posted 28 June 2013 - 10:20 AM
Where can i download!?
Ethan82691
#5 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 28 June 2013 - 10:36 AM
Looks good! Another new ROM in the same day! XT912 crackflashers will be in heaven! :D
  • zooyork0721 likes this
Donate? Click on signature :)
#6 prosaschi
prosaschi
  • 313 posts
  • Google+:paulrosaschi@gmail.com
  • LocationTucson, AZ
Posted 28 June 2013 - 10:47 AM
No download yet?
#7 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
Posted 28 June 2013 - 11:04 AM
Link is up!
Remember this is an Alpha build and only about 25% complete.  I know some things are broken.  If your hesitant to flash alpha builds, then wait for the official release.
#8 Ethan82691
Ethan82691
  • 113 posts
  • LocationIdaho
Posted 28 June 2013 - 11:05 AM
Do we need to be on the JB leak? and which kernel? .16 or .8?
Ethan82691
#9 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
Posted 28 June 2013 - 11:07 AM
*Must be on JB .16*
  • Ethan82691 likes this
#10 fatmando2
fatmando2
  • 235 posts
  • LocationMichigan
Posted 28 June 2013 - 12:07 PM
First rom where I've actually liked the theming, :p  I'm gunna have to try it out! Thanks!
Edit: It doesn't seem like the theming worked for me and I also don't have the Blurry settings. Any ideas?
  • Kyle06 likes this
#11 charlie115
charlie115
  • 50 posts
Posted 28 June 2013 - 02:13 PM
I don't have theme or Blurry settings either seems like stock ROM with Pandora cache cleaner and Twitter added?? I'm I missing a zip to install or something??
#12 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
Posted 28 June 2013 - 04:17 PM
Didn't miss anything. Again this is only 25% finished. The guts of the ROM are there and now I am adding the theme. Just give it a few days...
#13 fatmando2
fatmando2
  • 235 posts
  • LocationMichigan
Posted 28 June 2013 - 04:22 PM
Oh I see.. I look forward to it!  ;)
#14 justblan1984
justblan1984
  • 8 posts
Posted 28 June 2013 - 04:41 PM
just installed this rom, it runs smooth but the theme is not there
#15 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
Posted 28 June 2013 - 09:06 PM
Build 17 is up.  Most of the theme has been added now.  I need to edit some xml files to completely finish it.
I still need to add some apps that have shortcuts in the Setting menu.  You may get a fc if you try to open an app that is not installed yet.
  • fatmando2, Sinju33 and bradg24 like this
#16 melfunn
melfunn
  • 165 posts
  • LocationNashville, TN
Posted 29 June 2013 - 06:20 AM
For an alpha build, very smooth rom. A few glitches, but I like it. Just became my daily. Cudos.
  • prosaschi and eye__dea like this
#17 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
Posted 29 June 2013 - 06:29 AM
All feedback is welcome. What glitches?
#18 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
Posted 29 June 2013 - 01:09 PM
Alpha 21 link is up!
This will be the last alpha.  All theming is done.
There will be a few beta builds next.  The official build should not be long now.
  • fatmando2 likes this
#19 charlie115
charlie115
  • 50 posts
Posted 29 June 2013 - 01:16 PM
Hey eye the beats controls not working properly.I have a DPS zip file I used to flash in ss fixed it right up if you need it let me know or pm me. ROM is coming together nicely
#20 charlie115
charlie115
  • 50 posts
Posted 29 June 2013 - 01:22 PM
Oh I have modules and overclock zips for ss if you need them to.
