1077 replies to this topic
#161 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 10 July 2013 - 12:52 PM
Its all good now ZKK. I mustve flashed the earlier release. Also, another interesting sidenote.....now my messaging app is called "MMS Push" instead of "Messaging". Sort of odd, but no biggie.
Yeah, that's a CM change. I'm not sure what's going on there, but I'll probably change it on the next nightly. Thanks for confirming that, I'll put the link back up :)
Donate? Click on signature :)
#162 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 10 July 2013 - 01:01 PM
I just looked and the messaging app label is pulled from a .xml. It looks like CM decided to rename the app from here, but it's a quick edit to rename it. I'll be changing it to messaging in my future builds :)
#163 Maxxaholic
Maxxaholic
  • 628 posts
  • LocationWashington, USA
Posted 10 July 2013 - 09:38 PM
I'm on 7/9 nightly finally lol. Wiped cache/dalvik ( habit even though script does that) flashed, fixed permissions. My mms wasn't working... Tried apn backup & restore app on stock side, making it a system app, then backup apn, then do the same on cm side but no luck so tried the other trick I saw on cm posts... made a new apn named verizon and Viola :)
#164 rnh
rnh
  • 294 posts
  • LocationA Ct Yankee living in the land of Mass-oles
  • Current Device(s):Razr,
Posted 11 July 2013 - 03:15 AM
It may not last a reboot. My wife has cm on her phone and that process for mms doesn't last after rebooting. The apn one does but you must make apn backup and restore a system app on the cm side also and make sure to check ics disable, which I'm sure you did. She had trouble with 7/9 so I downgraded her phone to 7/8  shich definetly works better.
#165 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 11 July 2013 - 03:49 AM
Update 9 is not to stable... Lock ups & Reboots...first noticeable not to stable update in a while
Sent from my DROID SPYDER using Xparent Cyan Tapatalk 2
#166 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 11 July 2013 - 05:38 AM
Working on nightly 11 as I write this :)
#167 Maxxaholic
Maxxaholic
  • 628 posts
Posted 11 July 2013 - 05:40 AM
Exactly what I did with apn backup & restore. That's weird mine did survive after rebooting. Only issue I've had is my wifi quit working. It'd say connected But no signal. Reboot fixed that. I noticed modules r in the coding too but don't actually load. I'm sure that's still a cm issue though.
#168 islandfever
islandfever
  • 353 posts
Posted 11 July 2013 - 06:04 AM
Hey guys....Havent been in here in a while...still running 3.0.3 strong for months....but a question:
Do we HAVE to do a full wipe with every nightly? Or can you dirty flash over....
#169 cmh714
Posted 11 July 2013 - 06:26 AM
I have been doing dirty flashes with no problems so far.
But when you say you are on 3.0.3 that means your using Aviator Blur not this Aviator.
#170 islandfever
islandfever
  • 353 posts
Posted 11 July 2013 - 06:31 AM
  Oh yes I know. But was going to switch. Is it stable enough as a daily? I need wifi to work well, and bluetooth as well. Camera? Any MAJOR things not available yet?
#171 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 11 July 2013 - 06:32 AM
Blur is over here:
This is CM10.1 JB 4.2.2 which can only be installed in slot 1. As for full wipes, I always recommend it since it gives you the cleanest slate you can get, which should mitigate any issues. However, the installation scripts will wipe cache, dalvik cache, and system, so you could do dirty flashes and be just fine. But if you do have issues, then try a clean install with full wipes. In essence "No Wipe, No Gripes" :p
  • islandfever and cmh714 like this
#172 cmh714
Posted 11 July 2013 - 06:33 AM
Stable for me, and everything seems to be working fine. If you dont want the Nightlies then just stick with the Stable release,, but so far the nightlies have been bug free for me.
#173 islandfever
islandfever
  • 353 posts
Posted 11 July 2013 - 06:36 AM
Thanx guys....
ZK are the stat battery files in same place so I can replace them manually with the larger DIGITAL ones from your BLUR scripts?
Also, what are the benefits over BLUR? Battery life? Anything?
#174 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 11 July 2013 - 06:42 AM
Thanx guys....
No, don't use the Blur utility on this. But, there are a few different battery icons to choose from, Go to Settings>System>Status Bar>Battery status style and see if there is anything you like in there. :)
#175 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 11 July 2013 - 06:44 AM
I'm uploading 20130711 Nightly now :)
#176 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 11 July 2013 - 06:48 AM
sir when u r going to make a stable versions..:m waiting...
#177 islandfever
islandfever
  • 353 posts
Posted 11 July 2013 - 06:53 AM
No I meant are they in the same places on the UI, I normally do them manually myself without the utility
#178 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 11 July 2013 - 06:57 AM
Yes, the icons are in SystemUI.apk>res>drawable-hdpi and the coding which pulls the icons is in SystemUI.apk>res/drawable/stat_sys_battery.xml and stat_sys_battery_charge.xml.
#179 islandfever
islandfever
  • 353 posts
Posted 11 July 2013 - 07:01 AM
bingo
  • ZKK007 likes this
#180 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 11 July 2013 - 07:05 AM
I build these straight from CM source. Do you know how CM is organized in order to get a stable release? Basically builds will go through these steps:
  • Nightly: Usually generated every 24hrs, experimental, and may have new features. Unstable (but in our case it is pretty stable)
  • Milestone: More stable than nightly, but there could still be issues.
  • Release Candidate: Last build before stable release. Few minor issues, but mostly stable.
  • Stable: All, or almost all issues are fixed.
CM released a stable version and that is what my stable build is built from. Since then, CM have been putting out nightly builds to add/experiment new things. I am taking those nightly builds and adding in the Aviator personality. Hopefully you now understand why I'm only adding nightly build at this stage. You can follow the CM builds here:
  • johnthehillbilly likes this
