1077 replies to this topic
#121 Einsteindks
Einsteindks
  • 340 posts
Posted 05 July 2013 - 09:42 AM
I don't think I've heard that one before, but can you check that the image is the correct size (540x960) and that the permissions are correct.
Something about a failed bitmap? Permissions ok
sent via RazrMaxx over Tapatalk, y'all!
#122 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 05 July 2013 - 09:53 AM
Make sure they were saved as .png files. I will make a flashable zip file at some point today to make it easier :)  Any recommendations for the splash images?
Donate? Click on signature :)
#123 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 05 July 2013 - 10:05 AM
Aviator_CM10.1_20130705_NIGHTLY build is in the OP!
The only changes made between the Nightly builds are from CM.
I will be sending out an OTA Update notification for those of you who are running a nightly build.
Enjoy! :D
#124 Einsteindks
Einsteindks
  • 340 posts
Posted 05 July 2013 - 10:52 AM
Didn't get the chance to 'save as'. They were defaultly saved as JPEG files, and I changed the file name and extension to reflect the directions.
#125 OldBaldy
OldBaldy
  • 425 posts
  • LocationSouth Carolina
Posted 05 July 2013 - 03:29 PM
Ok. Report on the 04. Had a few glitches, but after about the 4th fix permissions every thing has run ok all day. Good battery (see attached and remember this is an OG Razr, not a maxx.) uvavu7ub.jpgdu7y4atu.jpg Am now installing 05. Sent from my XT912 using Tapatalk 4 Beta
  • tyscheff likes this
#126 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 06 July 2013 - 07:41 AM
Aviator_CM10.1_20130706_NIGHTLY is in the OP!
Enjoy! :D
#127 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 06 July 2013 - 07:49 AM
Enjoy! :D
is this stable version
#128 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 06 July 2013 - 07:54 AM
No, it has the word "NIGHTLY" in the title.
  • Einsteindks likes this
#129 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 08 July 2013 - 11:22 AM
Aviator_CM10.1_20130708_NIGHTLY build is in the OP!
Enjoy! :D
#130 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 08 July 2013 - 12:07 PM
You're a Good Man ZKK007...
"Patience as Strong As Steel" ;)
#131 rswizz
rswizz
  • 7 posts
Posted 08 July 2013 - 02:06 PM
Been trying to get into camera but keeps force closing saying gallery error anyone knows y
#132 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 08 July 2013 - 02:12 PM
From the CM10.1 OP. I'll add this to this OP too.
*** IF YOU HAVE A GALLERY FC ISSUE, PLEASE TRY MOVING THE CONTENTS OF "DCIM" FROM BOTH SDCARD AREAS OFF OF THE DEVICE ***
#133 rswizz
rswizz
  • 7 posts
Posted 08 July 2013 - 02:53 PM
Thanks I just cleared the gallery data and working fine now
#134 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 08 July 2013 - 04:14 PM
Good to hear it worked! :)
#135 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 08 July 2013 - 10:01 PM
sir when u r going to make new stable builds ..
#136 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 09 July 2013 - 03:14 AM
If you like Stable...
Stock is your Best choice :)
Its Bubba
#137 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 09 July 2013 - 04:10 AM
Whenever CM deems the build to be stable :) All I do it build CM from their source. I don't work on making it stable since it is a bit too advanced for me. I am slowly learning, but for now I leave it to the professionals :)
#138 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 09 July 2013 - 04:19 AM
The nightly builds are pretty stable though. Try one out if you haven't done so already. :)
#139 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 09 July 2013 - 04:28 AM
If you're Learning thats all that matters... try the update suggestions
Keep the fire burning to learn all you can...
Awesome :)
Its Bubba
#140 Maxxaholic
Maxxaholic
  • 628 posts
  • LocationWashington, USA
Posted 09 July 2013 - 06:28 AM
I'm gonna try yesterdays update. If I I fail ill b back on aviator blur lol love ur roms.
