1077 replies to this topic
#101 Maxxaholic
Maxxaholic
  • 628 posts
  • LocationWashington, USA
Posted 03 July 2013 - 06:38 PM
I'm doing it! Lol
#102 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 03 July 2013 - 06:56 PM
sir what you mean again i need download new zips and  delete slot 1 and flash nightlay and flash Gapps...? explain pls
#103 Maxxaholic
Maxxaholic
  • 628 posts
Posted 03 July 2013 - 09:10 PM
That's what I did. It hot booted a lot so had to force restart, wipe cache & dalvik fix permissions and now all is good
#104 OldBaldy
OldBaldy
  • 425 posts
  • LocationSouth Carolina
Posted 03 July 2013 - 09:16 PM
Decided to live dangerously so just dirty flashed the the nightly over the original. Booted and running fine. No problems yet. Will ruin for 24 hrs and let you know of any problems.
Sent from my XT912 using Tapatalk 4 Beta
#105 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 03 July 2013 - 09:28 PM
pls say how Rican install new nightly???
#106 Einsteindks
Einsteindks
  • 340 posts
Posted 03 July 2013 - 09:40 PM
Yep, that's usually how most update their CM installs. Some also wipe caches before rebooting. Not 100% safe, but quite low on risk.
#107 OldBaldy
OldBaldy
  • 425 posts
Posted 03 July 2013 - 09:59 PM
You don't even need to wipe caches, the install script does it for you.
#108 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 03 July 2013 - 11:41 PM
pls kindly tell me how to install new update of this rom... explain with steps
#109 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 04 July 2013 - 03:54 AM
This isn't an official update. This is a "nightly" which means there is potential that it can be unstable.
I personally would follow the installation instructions in the OP. Some people have flashed straight over top of the ROM, but that can be risky if some important files have been removed from the build since flashing overtop will not remove them. I will put a link to the CM change log later today so you can see exactly what is different.
You do not have to flash this though. It isn't an official update yet. But you can flash if you want.
Donate? Click on signature :)
#110 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 04 July 2013 - 06:11 AM
Just in case anyone wants to review to latest CM10.1 Spyder change log:
Since there was a lot of changes made with the 20130704 build, I will begin to make Aviator CM10.1 based on that nightly and hopefully get that out to you guys sometime today :)
  • aneeshmbabu likes this
#111 Maxxaholic
Maxxaholic
  • 628 posts
Posted 04 July 2013 - 06:26 AM
Ur killing me Lol! :)
#112 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 04 July 2013 - 06:36 AM
Haha, I don't think I've ever fully set up my phone the way I like it because I'm always flashing a new build! :p
#113 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 04 July 2013 - 09:20 AM
Aviator_CM10.1_20130704_NIGHTLY build download is in the OP! Installation instructions are still the same.
Please read the Updates section under the Notes banner just so you know what updates you will get from now on via OTA Updater.
Enjoy! :D
#114 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 04 July 2013 - 04:06 PM
sir what's the difference between stable downloads and nightly download ...presently I run stable download version 1 ..I flashed this on the 1st day u posted this ROM...but now I can't understand what's the nightly downloads ...kindly explain...
#115 Einsteindks
Einsteindks
  • 340 posts
Posted 04 July 2013 - 06:31 PM
Getting a code 3 error using the Aviator safesrap splash screens. What'd I do wrong?
sent via RazrMaxx over Tapatalk, y'all!
#116 OldBaldy
OldBaldy
  • 425 posts
Posted 04 July 2013 - 06:47 PM
Ok, so I didn't ruin the 03 update for 24 hrs, cause you came out with the 04 too fast. I did, however run it on battery for 12 hrs with 53% battery remaining. Moderate use with just under 1 1/2 hrs screen time on my OG Razr. I'm now on the 04 update. Same dirty flash. If I have problems I'll post the, but won't blame you or the Rom. (No wipe, no complaints.)
#117 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 05 July 2013 - 04:06 AM
I don't think I've heard that one before, but can you check that the image is the correct size (540x960) and that the permissions are correct.
#118 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 05 July 2013 - 04:10 AM
CM have different levels of releases. Go here to read what the differences are between nightly, milestone, release candidate, and stable.
#119 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 05 July 2013 - 04:13 AM
Just a quick note for anyone looking to try 20130704 nightly, I've noticed that I have to reboot after installing apps or else the app will force close. WiFi also has trouble reconnecting once entering the WiFi area. I normally have to reboot to get it to connect.
#120 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 05 July 2013 - 05:28 AM
Update 4 with CM 10.1
has a few clitches in general in addition to what you mentioned... nothing to do with you my friend
It's Bubba
"Stubborn In Your Bones"
