Yup, now I'm starting to see the signal drops more often. Just a few quick toggles of airplane mode and I'm good to go again .
#1041
Posted 23 February 2014 - 05:54 AM
#1043
Posted 24 February 2014 - 08:03 AM
I'm assuming the changelog is something similar to what CM has posted for this build? It's running very well . *Internet High Five
#1044
Posted 24 February 2014 - 11:28 AM
@ZKK007, would you recommend staying on Dalvik, rather than trying ART? Is it really worth it?
#1045
Posted 25 February 2014 - 08:38 AM
Does the new update fix the lockup issue when going to sleep? I really want to switch back to this ROM but every time I do, After a few hours it locks up and I get frustrated and switch back
#1046
Posted 25 February 2014 - 09:06 AM
I would but you are always free to try it. You might find issues using apps that aren't ART compatible and sometimes it means you will have to reflash.
#1047
Posted 26 February 2014 - 06:21 AM
All you have to do is change the screen animation to *Fade Out* under Display & Lights. That way your screen doesn't flash when u shut it off and it locks up !
- tyscheff and MeltingPlastic like this
#1048
Posted 26 February 2014 - 06:30 AM
- tyscheff likes this
#1049
Posted 27 February 2014 - 08:13 AM
Thanks!! Now time to redo the install and give it another go!
#1050
Posted 28 February 2014 - 12:31 PM
hi all-
Been away for a while -health issues, but all is back and I am ready to update this old Dec 2013 Rom. It constantly loses signal and messaging. Read lots of stuff about this Rom running as stock. If u r using it as stock pls let me know. If not, can I just reflash the newest lightly and give it a whirl on slot1? If it sucks, I can always start a new with wipes ans such. Figured I'd go small, then big:-) Pls let me know because VZ signal went from great to awful. Losses are annoying. Any suggestion is appreciated.
PS> Tried Gummy in another slot....not too shabby:-)
#1051
Posted 28 February 2014 - 12:34 PM
#1052
Posted 02 March 2014 - 08:23 AM
Hey, if I recall correctly, you're on PagePlus. After every reboot, you have to go to settings, wirelass networks and change it from ruim to NV only for your messaging.
If this message was for me, I am not a PagePlus person .
#1053
Posted 02 March 2014 - 10:45 AM
I'm on Verizon with XT912 and this happens to me too. So you're not the only one
#1054
Posted 03 March 2014 - 01:36 PM
So setting it to Fade Out did not fix this issue. Instead of it freezing showing the screen now it just freezes on a black screen. It's done this 3 times already today so even though I love this ROM and KitKat, I just have to switch away again
#1055
Posted 03 March 2014 - 04:23 PM
#1056
Posted 04 March 2014 - 10:54 PM
There is finally a solid fix for the signal loss in the 20140301 CM Nightly. I have been on the test build it was made from for 4 days now without a single loss of signal. The next build ZK does should have these kernel changes and fix the signal loss. Just wanted to let everyone know it is out there.
also, 3/4 version of JBX has merged Stargo's kernel fixes for the signal loss.
Droid Razr Maxx | SS3.6 AviatorBlur / CM11 N10 | RastaKat Xoom Wifi | Big Part 4.3 N7 | MultiROM / RastaKat OG Droid | kfazz CM10 port
#1060
Posted 06 March 2014 - 10:27 AM
Thanks for keeping us in the loop! Can't wait to give it a shot!
