10.2.1 Fixes all my problems!
#981
Posted 07 February 2014 - 11:16 AM
#982
Posted 10 February 2014 - 09:19 AM
Hello,
I bricked my xt912 phone. I had Aviator_CM11_KitKat_NIGHTLY_20140118 running on slot 1 with safestrap 3.65. I changed my boot to the stock rom slot and tried to restore a backup of slot 1 to the stock slot. Now I can't get the phone to boot. hard reset does not help. I see the motorola screen and then nothing.
I think my mistake was the I didn't have safestrap installed in the stock rom slot
I have a backup of 11.1 on slot 1
I have safestrap installed on slot 1
The backup and safestrap boot roms are on the external SD card.
Is there any way to get my phone to boot back to slot 1 or install a bootable image into the stock rom slot?
I had been running 11.1 and upgrading to the nightly updates for months. The 11.1 rom has been working great.
Any help on this would be greatly appreciated. Thanks
#983
Posted 10 February 2014 - 10:45 AM
Are you getting the Safestrap Splash screen at all...Hello,
It's Bubba
"Stubborn In Your Bones"
#984
Posted 10 February 2014 - 10:57 AM
#985
Posted 13 February 2014 - 05:33 AM
If not, No worries with Bricking your phone... Couple of Threads to Review and Read up on before you move forward... * House Of Moto or * Matt's Utility These two will get you up an running again... It's Bubba "Stubborn In Your Bones"
Bubba,
I really appreciate your help. The House of Moto re-image worked great. As soon as I heard that first "droid" I knew I was good to go. Now I have my stock 4.1.2 rom working. I installed safestrap 3.65 so that I won't hose it again. I'm back to running CM 11.1 on rom slot 1, which is working really well.
#986
Posted 13 February 2014 - 06:59 AM
This ROM will be One of your Daily Drives...
Its Bubba
#987
Posted 14 February 2014 - 02:00 PM
Got my ringer sound back. UGH!
Phone keeps losing ringer sound settings. Very annoying. Lots of missed calls.
Thinking of trying Gummy or pure CM11.
What is the difference between Aviator and pure CM11?
Yes, I see the wallpaper:-) - But, what exactly has Zk added to mod this rom?
#988
Posted 14 February 2014 - 02:10 PM
Both Awesome ROMs...
* Gummy sometimes will Lock up... But a Solid Daily Drive..
* CM11...tight as a Rope for being another Daily Drive
* The Differences...
Having a Hard time which to chose...Sooo I will use Gummy for a Week than CM 11 for a week...results...
"All Good Under The Hood"
Both a Thumbs Up
Its Bubba
- Redalert likes this
#989
Posted 14 February 2014 - 03:56 PM
The majority is under the hood stuff. Tweaks, etc. Then minor theming changes such as blacked out menu, see through backgrounds, etc as well as the Aviator settings optionsGot my ringer sound back. UGH!
- The Persuader, cmh714 and Redalert like this
#990
Posted 15 February 2014 - 09:47 AM
The majority is under the hood stuff. Tweaks, etc. Then minor theming changes such as blacked out menu, see through backgrounds, etc as well as the Aviator settings options Sent from my XT907 using Tapatalk 4
Thank so much! So, am I correct in assuming that you are actually tweaking the CM11 build? That's what is enabling the goodies in the Aviator build. So, is ist safe to also assume, that u r modding the nuts and bolts of CM11? What is the basic difference between Gummy and Aviator Cm? Asking so many questions because I would love to use one of this instead of stock.
My old Gnex is running Shiny Rom as stock and it works great. But, the GNEX didn't require Safestrap:-)
#991
Posted 15 February 2014 - 09:49 AM
#992
Posted 15 February 2014 - 09:54 AM
Question:Thank so much! So, am I correct in assuming that you are actually tweaking the CM11 build? That's what is enabling the goodies in the Aviator build. So, is ist safe to also assume, that u r modding the nuts and bolts of CM11? What is the basic difference between Gummy and Aviator Cm? Asking so many questions because I would love to use one of this instead of stock.
Why is it so important to replace the Stock ROM...
If it's for "More Space" not sure that's the right reason's
It's Bubba
- ZKK007 and Redalert like this
#993
Posted 15 February 2014 - 10:08 AM
Good reply..bubsterQuestion:
It's Bubba
I'm thinking space only thing that makes sense to me.
Sent from the MAXX using Tapatalk4
#995
Posted 15 February 2014 - 11:27 AM
It can be used instead of stock anytime! I just recommend to use it on a different ROM slot than stock
Zk you are saying to wipe stock from device and just roll with the rom, correct? Or you saying copy stock to diff slot, and rolling with the rom on stock slot( this can't be what ur saying, too many coronas for me????) I'm just thinking keep stock for if there's a problem with rom so u can run it.. Myself has had absolutely no problems with the rom, but if there's an update that makes something not work correctly on the rom which I think could happen, u got a failsafe. Like I said I never had any problems with ur silky smooth, buttery slick work on kit kat rom... My only problem of why I had to get rid of it and not use it, was a space issue. But then wiping stock, using rom as stock would clear that mess.
#996
Posted 15 February 2014 - 11:33 AM
#997
Posted 15 February 2014 - 11:43 AM
#999
Posted 15 February 2014 - 01:42 PM
I'm very tempted to throw ur kit kat back on.... Just need to figure a space option out... I don't have many apps, a lot of $hit is on my SD and email s and small things are deleted. So I'm thinking I must have a few huge apps, and a ton of temp and or fragmented files.. Idk..
You may also want to Foot loose back to Stock and Remove any Apps you No longer use...Caution with the Verzion Updater if its not Frozen in Titatium ...
Now Goto:
- Settings....
- Apps....
- All
- Chose Menu
- Sort by Size
- Backups should be in External SD...
This brings up All the Heavy's MB Apps first...Nice place to start to do a Little Dusting n Cleaning
Remember to Reboot after you've Removed...
#1000
Posted 15 February 2014 - 02:15 PM
Removing apps from you stock rom won't get you any extra space for this one. The apps you remove are on the stock rom. The stock rom partition knows nothing about safestrap slots. They are located at /data/apps on the stock rom. Not on the internal storage. The stock rom is on it's own partition. All you'll gain is space on the stock rom slot.
