#961
Posted 05 February 2014 - 02:18 PM
Sent from my Amazon Kindle Fire using Tapatalk 2
#962
Posted 05 February 2014 - 02:30 PM
Space...I'm pissed... I want this rom back.. Had to uninstall, ran out of space....wish it was just cm11 and not Daisey chained off of cm10... Damn...
Sent from the MAXX using Tapatalk4
* Do a Drive by and Delete Apps you don't use...
* Delete Emails that is not needed or Sent and Delete folder
* Delete Titanium Backups
* Delete Downloads and in CM Updater...delete old Updates
* Delete unnecessary backups in your External & Internal SD
* Backups should go on External anyways
* Delete Lost Files
* Reboot...
Those are some for starters...
Its Bubba
"Stubborn In Your Bones"
#963
Posted 05 February 2014 - 02:48 PM
Can you help me with my problem? I'm sorry I'm freaking out I need my phone for tomorrow lolSpace... * Do a Drive by and Delete Apps you don't use...* Delete Emails that is not needed or Sent and Delete folder* Delete Titanium Backups* Delete Downloads and in CM Updater...delete old Updates* Delete unnecessary backups in your External & Internal SD* Backups should go on External anyways* Delete Lost Files* Reboot...Those are some for starters...Its Bubba"Stubborn In Your Bones"
#964
Posted 05 February 2014 - 02:57 PM
Awesome...
Its Bubba
#965
Posted 05 February 2014 - 03:25 PM
Battery Life is Awesome...aggressive usage today...It did very well so far
Its Bubba
#966
Posted 05 February 2014 - 03:28 PM
#967
Posted 05 February 2014 - 04:48 PM
I'm kinda having a big problem. I go to Reflash this rom and the gapps and after it tells me there is no OS installed? I'm running stock right now, but I'd love to get me feedback lol
Buck...
If you want 4.4 than your on CM11 which can be Flashed to any Slot...however, is Stock working for you Now?
- Do you have a Backup to Restore CM 11? or CM Aviator
- Can you get into Safestrap to Restore Or
- As you Know CM 10.1 is for Slot 1 Only...just throwing this out there....
- Original Post gives you the Update to Aviator CM 11... 2014-1.18
- Gapp 2013-12.08
- Options to use a Stable Update or Nightly...No Issues with either IMO...
Do you have a Active Slot Now or do you need to create one?
#968
Posted 05 February 2014 - 05:01 PM
I have a backup but it won't let me restore it. I can get into SS. I have an active slot, but like I said it keeps telling I have no OS after I flash. Stock is working fine. Though I must ask a note question. I bought a ten foot charger on eBay and whenever I plug it in I can't use my touchscreen is that normal?Buck...
If you want 4.4 than your on CM11 which can be Flashed to any Slot...however, is Stock working for you Now?Do you have a Active Slot Now or do you need to create one?
- Gapp 2013-12.08
#969
Posted 05 February 2014 - 05:46 PM
* Is your Backups in External or InternalI have a backup but it won't let me restore it. I can get into SS. I have an active slot, but like I said it keeps telling I have no OS after I flash. Stock is working fine. Though I must ask a note question. I bought a ten foot charger on eBay and whenever I plug it in I can't use my touchscreen is that normal?
* First Backup All your ROMs to the External SD...than Delete All your Backup if their on your Internal SD
* Redo or Create a New Slot...1 GB is fine
* After...Wipe Both Caches...Wipe Factory... Wipe System...
* Flash your ROM...than Gapp 2013-12.08
* Nandroid your Stock to External... If Stock is a Solid ...Also CM Aviator if its working to your likings...
* Only use compatible charges for your phone...could cause other issues later on...
Its Bubba
#970
Posted 05 February 2014 - 06:13 PM
Thanks man, but I did the clear and still no space.. My internal ain't big, that's the priblem
#971
Posted 05 February 2014 - 06:35 PM
Check this out at XDA.
Folks are flashing CM11 KitKat to stock slot!
Very interesting.
A few have even flashed Gummy to stock.
I run Shiny Rom on my Galazy Nexus via CWM -it's the only system on the phone and boot up time is great. I guess running anything as stock is faster.
#972
Posted 05 February 2014 - 07:35 PM
I got everything working again. Thanks man. About the chargers it was meant for an LG, but said it worked for all using the same scheme.* Is your Backup in External or Internal
Its Bubba
#973
Posted 06 February 2014 - 02:42 AM
Use Cables specific to your phone my friend...I got everything working again. Thanks man. About the chargers it was meant for an LG, but said it worked for all using the same scheme.
Glad you're up and running...
Awesome ROM to boot...
Buck,
Try this App...
Cache Cleaner NG...set to 12 hours...
-this will help with the Performance and Lags...if any at all...
Have an Awesome Day!!!
It's Bubba
#974
Posted 06 February 2014 - 03:35 AM
Did you Reboot after Deleting the Unneccessaries Stuff...Look for the Larger MB Files and Delete...If you dont use these Apps anymore...
Note,
Do you have any or All ROMs currently backup on your External SD now?
Personally, Backup as much as you can on External...Your very limited to Internal...Plus you still can Restore ROMs from your External SD with No problem...
Your External SD is Jammed Full of Sheet my guess...or Both Ex / In...Maybe
#976
Posted 06 February 2014 - 03:56 AM
Have you Powered Down your Phone...than restart....
If you have an App called Quick Boot plus... You can go into one of their choices like Hot Boot which Refreshes your UI System and should fire up your sound issues...
For me making Sound Changes I always use Media Storage seems to have No issues...
Its Bubba
Thx. I have powered down numerous times. Still no sound on anything. this leads me to believe that something is wrong whatever it is that controls sound for phone calls because other sunds are working.
Any more suggestions are appreciated. Dont want to trash the rom, but....should I dirty flash an update, and if so which one has been least troublesome?
#977
Posted 06 February 2014 - 04:03 AM
Wouldn't hurt...your issue is Sound only...Thx. I have powered down numerous times. Still no sound on anything. this leads me to believe that something is wrong whatever it is that controls sound for phone calls because other sunds are working.
Did you have any Interruptions Downloading the ROM?...
It's Bubba
#978
Posted 06 February 2014 - 05:04 AM
I've had that problem. All you need to do is wipe caches and fix permissions. Worked for me before, hopefully it'll work for you.Wouldn't hurt...your issue is Sound only...
It's Bubba
#979
Posted 06 February 2014 - 11:17 AM
Need more space? Here, save yourself 6gbs of wasted space taken by the stock slot, which you probably don't use.
How to install aviator cm11 on STOCK partition - by me - on xda
P.S. It would be nice for the developer to fix/explain the dual core bug.... Running only one core, speeds up the phone... Everything gets snappier...
#980
Posted 06 February 2014 - 11:43 AM
I wouldn't touch Stock to get more space...not recommendedNeed more space? Here, save yourself 6gbs of wasted space taken by the stock slot, which you probably don't use.
It's Bubba
- Redalert likes this
