1077 replies to this topic
#921 mistaheatmiser
mistaheatmiser
  • 8 posts
Posted 24 January 2014 - 01:09 PM
Can someone please explain to me how they have the storage capacity to install multiple ROMs using safe strap? My phones internal memory has less than 2g available and won't let me install just one ROM, and some on here are talking about having all 3 aviator versions.
#922 roach38122
roach38122
  • 75 posts
  • LocationChampaign Illinois
  • Current Device(s):LG Optimus Dynamic, Droid Razor Maxx
Posted 24 January 2014 - 01:12 PM
I have a 16GB phone. I'm running Stock ROM, Aviator CM10.1 and Aviator Gummy. I still have two more slots for ROM'S to GI into.
#923 mistaheatmiser
mistaheatmiser
  • 8 posts
Posted 24 January 2014 - 01:15 PM
You sir are monopolizing my phone! I now have Aviator running in slots 1,2 and 3 (3 being blur). Great roms all.Sent from my XT912 using Tapatalk 4 Beta
Can you please explain how you have the internal memory to install multiple ROMs in Safe strap? Sorry noob question but I don't even have enough room to install just one ROM, let alone 3. If I remember correctly, my xt912 has 8g of Internal memory, and a Rom takes about 2g? Is this correct or am I completely screwing something up?
#924 mistaheatmiser
mistaheatmiser
  • 8 posts
Posted 24 January 2014 - 01:17 PM
I have a 16GB phone. I'm running Stock ROM, Aviator CM10.1 and Aviator Gummy. I still have two more slots for ROM'S to GI into.Sent from my XT912 using Tapatalk
I could have sworn mine was 16 gigs as well but my phone is only saying 8 I think. I have a RAZR Maxx xt912
#925 roach38122
roach38122
  • 75 posts
Posted 24 January 2014 - 01:26 PM
I have a RAZR Maxx xt912 as well.
#926 mistaheatmiser
mistaheatmiser
  • 8 posts
Posted 24 January 2014 - 07:02 PM
It looks like whatever partitions I have are only allowing for 8 gigs as use for apps and the other 8 as use for storage...is there a way to combine them as one?
#927 roach38122
roach38122
  • 75 posts
Posted 24 January 2014 - 07:13 PM
When you create a ROM slot you can adjust memory settings for the partition. I haven't adjusted any of mine and I have the same phone as you. Also what version of SafeStrap are you running. I'm running 3.6x
#928 mistaheatmiser
mistaheatmiser
  • 8 posts
Posted 24 January 2014 - 07:21 PM
When you create a ROM slot you can adjust memory settings for the partition. I haven't adjusted any of mine and I have the same phone as you. Also what version of SafeStrap are you running. I'm running 3.6xSent from my XT912 using Tapatalk
Yea I have as 3.6, but I have only 1.8 gigs of memory. The lowest partition as will let me make is 2 gigs
#929 roach38122
roach38122
  • 75 posts
Posted 24 January 2014 - 07:24 PM
I just looked in my SafeStrap. Each one of my settings per ROM slot are as follows
System Partition
700MB
Data Partition
2000MB
Cache Partition
300MB
#930 roach38122
roach38122
  • 75 posts
Posted 24 January 2014 - 07:26 PM
Have you wiped your phone and start from fresh?
#931 cmh714
Posted 24 January 2014 - 07:27 PM
you dont have enough room on your "internal" sdcard. maybe too many slots or backups, thats usually an issue
  • The Persuader likes this
#932 mistaheatmiser
mistaheatmiser
  • 8 posts
Posted 25 January 2014 - 07:12 AM
I guess I need to wipe my phone amd start fresh. I have a titanium backup of my downloaded apps, is there anything else I need to backup? I've only ever wiped my tablet but I'm nervous about wiping my phone as its a bit more essential to me.
#933 roach38122
roach38122
  • 75 posts
Posted 25 January 2014 - 07:27 AM
Maybe import your contacts to SIM card or Google backup.
#934 ondabirdhouse
ondabirdhouse
Posted 25 January 2014 - 08:28 AM
Anyone else having trouble seeing the wireless Mac address? I read a bunch on it but couldn't find a fix. Its causing me WiFi connection issues.
#935 mistaheatmiser
mistaheatmiser
  • 8 posts
Posted 25 January 2014 - 08:30 AM
Yea those are all backed up on Google.
#936 roach38122
roach38122
  • 75 posts
Posted 25 January 2014 - 08:33 AM
I believe that in an earlier post someone had mentioned something about there maybe being a duplicate Mac address. I believe you have to use BuildProp editor to look and see.
#937 roach38122
roach38122
  • 75 posts
Posted 25 January 2014 - 08:42 AM
#938 king12yan
king12yan
  • 17 posts
Posted 26 January 2014 - 08:52 AM
I installed the 1/18/2014 CM11 kitkat and all seemed well but after a day I cant make calls or receive them I get to mobile network but I still have data I just cant make or get calls.  Anyone got an idea of what is going on?
#939 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 26 January 2014 - 09:20 AM
My guess you haven't taken All the Updates...#25 is on Deck for Flashing...
Speaking of Flashing you may have a Bad Download... Start from Scratch again...Create a New Slot and Restore your Backup...
It's Bubba
"Stubborn In Your Bones"
#940 king12yan
king12yan
  • 17 posts
Posted 26 January 2014 - 02:24 PM
It's Bubba
I found that I need to go to wireless and networks, go to more and select Mobile Networks.  In there I need to change the Preferred network type to Global instead of LTE.  Why would that change on its own.  Do I need it to be LTE or Global?  LTE I get no mobile network available but Global I do.
