1077 replies to this topic
#901 roach38122
roach38122
  • 75 posts
  • LocationChampaign Illinois
  • Current Device(s):LG Optimus Dynamic, Droid Razor Maxx
Posted 20 January 2014 - 04:12 AM
Arkir and fellow PagePlus users. I installed Aviator Gummy and didn't have to adjust any of my *#*#4636#*#* settings. When you initially flash and you're running your stock ROM, yes you need to adjust those settings. I haven't learned what the difference is in the ROM's, but don't adjust them. As soon as I disconnect my Wi-Fi I immediately pull 3g. I know, I know, we're CDMA. it doesn't make sense to me either. I upload a screen shot.
#902 roach38122
roach38122
  • 75 posts
Posted 20 January 2014 - 04:17 AM
PagePlus
#903 roach38122
roach38122
  • 75 posts
Posted 20 January 2014 - 04:20 AM
I have found that if you use messaging instead of Hangouts or Talk, whichever it is, MMS SMS will work.
#904 roach38122
roach38122
  • 75 posts
Posted 20 January 2014 - 04:21 AM
How do you upload screenshots?
#905 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 20 January 2014 - 05:07 AM
Hold the Power Button & Volume Down Button at the same time... That will give you your Screenshot
Its Bubba
"Stubborn In Your Bones"
#906 scott2020
scott2020
  • 5 posts
Posted 20 January 2014 - 06:57 AM
Usually if you go into System settings, About phone, Status, where you can see your phone number, signal, etc, if you can see your phone number, PRL version, MIN then all is well.  Everything including 3G and MMS works fine no matter what app you use.  If they say 'unknown' then some things work, some do not.  ON Aviator Blur 3.0.3 running andriod 4.1.2 I had to switch settings to CDMA auto PRL and everything worked.  With this one that doesn't fix it.  I have tried pretty much all of the settings with no luck.
The strange thing is that everything was great after my initial load of this ROM on a fresh slot, and everything showed in 'About' like you would expect, and without making any changes somehow it broke.  I am not a dev but if there is something I can test for someone I'm game!
#907 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 20 January 2014 - 08:45 AM
:p
Sorry man.. Forgot the other piece...
Reply via Quote... Choose the camera icon next to the Discard... It will prompt you to gallery to chose the screenshots... Submit
Its Bubba
#908 arikr
arikr
  • 61 posts
  • Current Device(s):XT912
Posted 20 January 2014 - 08:50 AM
Yeah this problem is applied to KEXEC only ROM's.. Stock based ROM's do not have this issue "Avaitor Blur" "ArtMOD" etc... But something with the boot up of the CM ROM's does this.. I haven't figured it out all the way or a bypass fix for the mean time.. But that's why I'm running 4.1.2 instead of many other great CM ROM's..
ArtMOD 4.31 - Droid RAZR Maxx XT912
[Carrier: PagePlus 3G(2G)]
Dev/Tester/Senior Programmer
#909 roach38122
roach38122
  • 75 posts
Posted 20 January 2014 - 04:07 PM
:p
Reply via Quote... Choose the camera icon next to the Discard... It will prompt you gallery chose the screenshots... Submit
Its Bubba
#910 roach38122
roach38122
  • 75 posts
Posted 20 January 2014 - 04:11 PM
I went to the quotes as you can tell by above post, no icons other than reply
#911 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 21 January 2014 - 04:13 AM
Located next to the Discard...Camera Icon
It's Bubba
#912 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 21 January 2014 - 04:35 AM
It's Bubba
I'm using TapaTalk...not sure if that make a different layout
It's Bubba
#913 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 21 January 2014 - 04:38 AM
This is my menu to reply back to you...
It's Bubba
#914 patchm00
patchm00
  • 48 posts
Posted 21 January 2014 - 05:48 AM
If I'm in reply, my menu has attach picture
  63.01KB   30 downloads
#915 roach38122
roach38122
  • 75 posts
Posted 22 January 2014 - 06:57 PM
If I'm in reply, my menu has attach picture http://www.droidrzr.com/public/style_images/dark_matter/attachicon.gif
  72.15KB   24 downloadsI finally figured it out. Thanks
#916 king12yan
king12yan
  • 17 posts
Posted 23 January 2014 - 08:00 AM
Just curious is anyone having any issue with the xfinity app not working with this rom?  I tried to run the xfinity player app and I could not get it to play a video on KitKat.
#917 roach38122
roach38122
  • 75 posts
Posted 23 January 2014 - 02:23 PM
Are you running the latest version of Aviator Gummy, an update was pushed through on Tuesday. If you were on a previous build, the camera and video was not working. New download in OP.
#918 roach38122
roach38122
  • 75 posts
Posted 23 January 2014 - 02:26 PM
Nevermind. Seems I'm lost on my threads since I'm running CM 10.1 and GUMMY.
#919 king12yan
king12yan
  • 17 posts
Posted 24 January 2014 - 09:05 AM
Thanks i was running the older version so I did update the CM version to the 1/18/14 version and now its working.
#920 roach38122
roach38122
  • 75 posts
Posted 24 January 2014 - 09:17 AM
Cool, good deal.
