1077 replies to this topic
#881 buckeyestilidie
buckeyestilidie
  • 288 posts
  • Twitter:buckeyestilidie@yahoo.com
Posted 18 January 2014 - 03:19 AM
Busybox isn't really an app that you use. It's needed by certain apps for those certain apps to function correctly. Titanium backup is one that comes to mind (although I think it comes with it's own verion of busybox). Anyway, it's a container (so to speak) of many Unix utilities. Apps that require one or more of them will use them. The app you download from the playstore should really be called Busybox updater (IMHO). Some apps require a certain version of Busybox. You can use the updater to install whatever version of Busybox you want or need. That's about all it's really good for for the average user. That's enough though. You can get the right version when an app says it needs a certain version. This probably doesn't make a lot of sense but it's kind of hard to explain. Best I can do. Maybe a dev can step in and answer better. :)
Yeah that was okay I got the pro version so hopefully that should be good lol
#882 buckeyestilidie
buckeyestilidie
  • 288 posts
Posted 18 January 2014 - 03:21 AM
#883 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 18 January 2014 - 07:32 AM
A new build is in the works! Should be ready in an hour or so :)
  • The Persuader likes this
Donate? Click on signature :)
#884 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 18 January 2014 - 08:30 AM
New build has been uploaded! I'l push this out via OTA Updater later on today.
Enjoy!
#885 dwh2o13
dwh2o13
  • 79 posts
  • LocationSt Louis, MO
  • Current Device(s):Droid RAZR MAXX
Posted 18 January 2014 - 08:52 AM
Enjoy!
Thanks ZKK!
#886 DroRzr
DroRzr
  • 97 posts
  • Current Device(s):XT912, Nexus7
Posted 19 January 2014 - 04:34 AM
Been running 12-21 build with minor freeze issues, and its time to move on. I kinda hate to replace what's not broken and gives me great battery results. Battery, Phone calls, txt, and searches are my main focus.
A few questions Pls?..
1. Can I flash on top of 12-21
2. Which is the most trouble free nightly. I am not absorbed with HD camera and video. A long as I can take a pic, life is good.
3. Can I flash Gummy version and give it a whirl over this rom on Slot 1. Some say yes, others say no. What say u?
4. Have u used this on stock side?
5. Can it be used via CWM as stock. (Flashed Shiney Kitkat on older Gnex as daily rom and it rocks! Would Luv to run Aviator as primary if possible.)
Thanks for any help,u may provide.
#887 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 19 January 2014 - 04:47 AM
1, I always recommend a clean flash and I wouldn't flash on top of an older build. You will run into issues.
2. Hopefully someone else can answer this one for you. My XT912 is my backup phone and is on the latest build without any issues that I found in the short time I used it
3. Aviator Gummy can go on any slot. So can Aviator CM11. It is only the Aviator CM10.1 that must go in slot one. But if you use Aviator Gummy, start with a clean slot.
4. I haven't but others have. I wouldn't recommend it.
5. I haven't used CWM since my Droid X days and am unsure of its use for the XT912. Safestrap is the way to go and these 4.4 builds need safestrap 3.6x (3.65 is the latest).
Hope that helps!
#888 DroRzr
DroRzr
  • 97 posts
Posted 19 January 2014 - 05:02 AM
Hope that helps!
Sure does! Thanks loads for such a prompt Sunday response. the 12/21 freezes are now annoying, so I guess I should move on, Z. Since u post all versions, do ya think I should give Gummy shot on Slot2? My real,issue is lack,of space on internal. UGH!
#889 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 19 January 2014 - 05:10 AM
Yes...Its Awesome
Its Bubba
"Stubborn In Your Bones"
#890 scott2020
scott2020
  • 5 posts
Posted 19 January 2014 - 06:51 AM
Just popping in to say I flashed yesterday's version and everything is working great for me.  I am a Page Plus 3G user, and SMS/MMS/3G data/Wifi all is working great so far.  Still playing and re-loading apps fresh.  Started in Slot 2 with clean everything, fresh flash.  Great work!
  • The Persuader and Redalert like this
#891 arikr
arikr
  • 61 posts
Posted 19 January 2014 - 10:36 AM
I haven't tried Gummy yet, I been only testing ZKK's CM11.. Thats the only ROM that ZKK had me test much of.. But good news tho.. And does gummy still have the 2 min wait time for network data to turn on?..
ArtMOD 4.31 - [Droid RAZR XT912] - Maxx'd
[Carrier - PagePlus (3G/2G)]
Dev/Tester/Senior Programmer
#892 scott2020
scott2020
  • 5 posts
Posted 19 January 2014 - 04:38 PM
I also have not tried Gummy.  Also, I guess I spoke too soon.  MMS isn't working now but it did after the initial install.  I was running Aviator blur 3.0.3 before, and I did the *#4636.... and changed my settings to CDMA Auto (PRL) on Page Plus to get MMS to work.  I did that on this ROM and it didn't help.  When I go into about phone, look at the status, I would see my MIN and such if all was well, but it says unknown.  I'll need to dig back and see what other settings I changed.
#893 arikr
arikr
  • 61 posts
Posted 19 January 2014 - 04:41 PM
With all 4.4 you can't change the network type, needs to be set on "Global"... Which sucks..
#894 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 19 January 2014 - 05:24 PM
Not so,
I have mine set at CMDA/LTE/EVO...
On GLOBAL, I had to many Internet Disconnects
Its Bubba
#895 scott2020
scott2020
  • 5 posts
Posted 19 January 2014 - 05:32 PM
Got it.  I switched back to global but still no good.  I'm not sure how it worked after my first flash, but at some point during one of the reboots, it quit.
#896 arikr
arikr
  • 61 posts
Posted 19 January 2014 - 05:38 PM
I would just factory reset/wipe and leave the network settings alone..
#897 arikr
arikr
  • 61 posts
Posted 19 January 2014 - 05:39 PM
Not so,
Its Bubba
Yeah I set mine to that too but I have a 2 min connect time after the next reboot... 4.4 is wonderful but still needs work for sure.. That's why I'm still on 4.1.2..
#898 scott2020
scott2020
  • 5 posts
Posted 19 January 2014 - 05:52 PM
The thing is everything was working after my initial flash, and then stopped somewhere along the way without me touching any of the network settings.  I only started messing with the network settings after I found MMS not working today.  I can't remember what it was set to in the initial flash.
#899 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 19 January 2014 - 05:55 PM
Perseverance usually prevails
Its Bubba
#900 arikr
arikr
  • 61 posts
Posted 19 January 2014 - 09:46 PM
Well... I got service again.. I will begin testing Gummy and ZKK's builds probably tomorrow night, anything fellow PagePlus users want me to look into, let me know.. Either PM or on here...
ArtMOD 4.31 - Droid RAZR Maxx XT912
[Carrier: PagePlus 3G(2G)]
