1077 replies to this topic
#841 drewski11
drewski11
  • 186 posts
  • LocationSF Bay Area, CA
Posted 15 January 2014 - 03:19 PM
I can see those. I just can't see them in the app like gallery or Apollo
I know you said you tried some SD scanners. Apparently there was a change with KitKat so the method older programs use doesn't work on 4.4
This is one claims to work with KitKat. If you haven't tried it, maybe give it a whirl.
#842 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 15 January 2014 - 04:01 PM
Drewski...
Hope all is well...May I ask what SD Scanner does...Just ran the App...Its Scanned but what does it do...No Options or Retrieve at least that I was looking for...
What did I miss my Friend
#843 drewski11
drewski11
  • 186 posts
Posted 15 January 2014 - 04:13 PM
Drewski...
it scans your storage and checks to see if the existing media databases are complete and adds missing media files to them.
if you don't have issues like Buckeye (with music & photo files on SD that don't show up in gallery / music apps), then it won't really do anything because you don't have anything to fix :)
#844 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 15 January 2014 - 04:27 PM
Drewski...
Now you're talking Dirty... Makes sense... Hopefully it worked for Buck
Its Bubba
#845 buckeyestilidie
buckeyestilidie
  • 288 posts
  • Twitter:buckeyestilidie@yahoo.com
Posted 15 January 2014 - 04:30 PM
Drewski...
Its Bubba
Nope every app FCed on me that involved SD scanning
#846 buckeyestilidie
buckeyestilidie
  • 288 posts
Posted 15 January 2014 - 04:31 PM
Drewski...
Its Bubba
#847 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 15 January 2014 - 04:40 PM
Buck...
Is CM 10.1 Up and Running Well other than Pics & Music
#848 drewski11
drewski11
  • 186 posts
Posted 15 January 2014 - 04:41 PM
I read that you had tried some, but did you try this specific one?
#849 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 15 January 2014 - 04:47 PM
By chance, Do you have any of your Pics & Music on your Laptop/Computer?  B)
#850 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 15 January 2014 - 04:51 PM
;) Piggyback to this Post...
If this ROM is working well without the Pics and Music...Nandroid this Sucker....(Backup) another words so you have a Solid ROM to fall back onto...
Told you earlier in this Thread How to do the Dance... :p
#851 robocuff
robocuff
  • 415 posts
Posted 15 January 2014 - 05:07 PM
It did and everything is fine I'm just having a issue with my SD. I see be pictures and music but none are showing up. In the gallery app or my music app. I then tried downloading a scan SD app but everyone FCed
Sent from my Amazon Kindle Fire using Tapatalk 2
How do you see the pictures and music?  Using a computer or using an app on the phone?  If a computer, have you checked in system settings>storage to see if sd card is mounted?
  • The Persuader likes this
#852 dwh2o13
dwh2o13
  • 79 posts
  • LocationSt Louis, MO
  • Current Device(s):Droid RAZR MAXX
Posted 15 January 2014 - 06:08 PM
Try these steps :
* Open ES
* Up Top look for / sign
* Click on it
* Goto System
* Find build. Prop... Click on it
* Chose ES note Editor
* Right corner 3 dots
* Click on it chose Edit
* Goto your ro to edit to 240
* then back out the reboot
Its Bubba
Sorry for the delay Bubba. Didn't get to this until just a minute ago. The steps above worked like a charm. Much appreciated! Have a nice evening my friend.
#853 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 15 January 2014 - 06:18 PM
dwh...
You very Welcome my friend...
Glad it worked... ;)
  • Redalert likes this
#854 buckeyestilidie
buckeyestilidie
  • 288 posts
Posted 15 January 2014 - 07:25 PM
Through ES
I did and it worked, but I can't find all my music. I know it's in different areas, but it's  hard trying to find the exact area.
I do
#855 buckeyestilidie
buckeyestilidie
  • 288 posts
Posted 15 January 2014 - 07:28 PM
What do you mean go to your ro to edit 240? I don't understand what you mean.....
Nevermind found out how.
Edited by buckeyestilidie, 15 January 2014 - 07:38 PM.
#856 buckeyestilidie
buckeyestilidie
  • 288 posts
Posted 15 January 2014 - 07:33 PM
Changing Screen Resolution (DPI):
Want to change the screen resolution back to the regular resolution?
  1. Use a file explorer to edit system/build.prop.
  2. Search for ro.sf.lcd_density.
  3. Change the value to 240.
  4. Save file and reboot.
CM change Log:
I tried this and when I did it said it couldn't save.
#857 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 15 January 2014 - 08:08 PM
Didn't know you had a Font issue
Its Bubba
#858 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 15 January 2014 - 08:11 PM
Check out Post 856
Its Bubba
#859 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 16 January 2014 - 06:27 AM
New build is up! Built this morning. I wont have time to push this out via OTA for a day or two so just ignore any OTA notification if you flash this.
On a different note, I am finding development time more difficult to come by. So development is slowing down for the Aviator series of ROMs. I am not stopping development, but builds will take longer to come out.
Thanks for supporting the Aviator series! :D
  • drewski11, Redalert and BigCWIshon like this
Donate? Click on signature :)
#860 buckeyestilidie
buckeyestilidie
  • 288 posts
Posted 16 January 2014 - 07:11 AM
Check out Post 856Its Bubba"Stubborn In Your Bones"
You sure post 856 will help with the small lettering and such? Lol and also what is Android media process? It seems like that's the culprit behind my battery draining so fast.
