1077 replies to this topic
#821 buckeyestilidie
buckeyestilidie
  • 288 posts
  • Twitter:buckeyestilidie@yahoo.com
Posted 15 January 2014 - 08:41 AM
Buckeye good Buddy... Follow the process with Wipes No Advance wiping is Involved... All your choices for Wipes are shown on your Safestrap Screen.. Follow those steps your Bootlooping issues will come to an end Its Bubba"Stubborn In Your Bones"
It did and everything is fine I'm just having a issue with my SD. I see be pictures and music but none are showing up. In the gallery app or my music app. I then tried downloading a scan SD app but everyone FCed
Sent from my Amazon Kindle Fire using Tapatalk 2
#822 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 15 January 2014 - 09:23 AM
Did you backup on your Prior Backup you flashed
Its Bubba
#823 buckeyestilidie
buckeyestilidie
  • 288 posts
Posted 15 January 2014 - 09:50 AM
Its Bubba
I have no backups. Erased them all
#824 king12yan
king12yan
  • 17 posts
Posted 15 January 2014 - 09:51 AM
hopefully this works. the zip works on Gummy 4.4.2 as well :)
Thanks I tried this file before.  I notice that there was a hotspot option built into the rom.  I wasn't using that before I was using the wifi tether app.  I went back and tried the hotspot tether in the rom and it works no problem.  Is there a difference between the wifi tether app and the one built in?
#825 drewski11
drewski11
  • 186 posts
  • LocationSF Bay Area, CA
Posted 15 January 2014 - 10:24 AM
Not sure about 3rd party apps.
The Zip fixes the hotspot tether built into the ROM.
#826 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 15 January 2014 - 11:18 AM
Buckeye...
I've learned the Hard way not backing up my ROMs... So now before I even think about getting Balzzie I backup...
End of Story :-)
Its Bubba
#827 buckeyestilidie
buckeyestilidie
  • 288 posts
Posted 15 January 2014 - 12:08 PM
Buckeye...
End of Story :-)
Its Bubba
I did and when I went to restore it and it showed like fifteen 0's so I erased it. Is the backups why my music won't show or my pictures??
#828 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 15 January 2014 - 12:25 PM
Those Zero's...
If you would've click on it one more time... You would have seen your backups...
Its Bubba
#829 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 15 January 2014 - 12:40 PM
For Sheets and Giggles...Last ditch effort :)
Check to see if maybe you saved them to your External SD Card...
Goto Root Explorer
  • Scroll to sdcard-ext
  • Then to TWRP
  • Click on it and chose Backups
  • You will see your Wonderful Zero's...Click on it
  • Those would be your Backups on your External SD Card...Are they There :) if Not, History :(
  • You should backup your ROMs to external anyways...to saves Data Space in the future
  • If you when Bowling with All those Zeros and wipe them out chances are Those Backups are ar Gonna'
Next time you back up in Safestrap you will see 2 Clear Circle...chose the one on the left by clicking on it till it turns Blue than Backup...Its says: External
#830 buckeyestilidie
buckeyestilidie
  • 288 posts
Posted 15 January 2014 - 12:53 PM
Goto Root Explorer
  • Then to TWRP
They're not there, but is this serious because I didn't keep my backup? I also have my phone getting super hot and he battery is draining rapidly. Also do you know which one is the Ext?
#831 drewski11
drewski11
  • 186 posts
Posted 15 January 2014 - 01:28 PM
TWRP Backup doesn't back-up your personal files like music & pictures. You have to back those up manually.
#832 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 15 January 2014 - 01:54 PM
They're not there, but is this serious because I didn't keep my backup? I also have my phone getting super hot and he battery is draining rapidly. Also do you know which one is the Ext? Sent from my XT912 using Tapatalk 2
Hot Phone and Draining Battery is usually an App or Apps running in the background...
Widgets, are your nasty culprits in the background...
Go to Settings... Apps... Running SD...
It will be mostly System Apps...
Then to... All and Remove any Apps that requires lots of Sycing of Data that you Do Not use any longer... Start there
Its Bubba
#833 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 15 January 2014 - 02:08 PM
Serious only if those Pictures & Music is important to you... Hopefully you have a Backup on your computer...
Now Ext...
Depends where your at... Safestrap or File Explorer/Root Explorer /ES
Its Bubba
#834 buckeyestilidie
buckeyestilidie
  • 288 posts
Posted 15 January 2014 - 02:15 PM
Hot Phone and Draining Battery is usually an App or Apps running in the background... Widgets, are your nasty culprits in the background... Go to Settings... Apps... Running SD...It will be mostly System Apps... Then to... All and Remove any Apps that requires lots of Sycing of Data that you Do Not use any longer... Start thereIts Bubba"Stubborn In Your Bones"
Okay got that one down now one to go lol I'm at about two and a half hours and I'm at 40%. So on to the mystery of the missing music and pictures.
#835 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 15 January 2014 - 02:30 PM
All of my Backups for Pictures and Music is shown in Root Explorer...ES... or File Manager...
#836 buckeyestilidie
buckeyestilidie
  • 288 posts
Posted 15 January 2014 - 02:32 PM
I can see those. I just can't see them in the app like gallery or Apollo
#837 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 15 January 2014 - 02:56 PM
Dude your Battery Life Sucks to be Honest ;) but that said, if your Happy with the Set up with your Phone...Many Widgets, All the Apps you Love to Keep Who cares about your Battery Life...
Wall chargers & Car Adapters are my Life using my phone they way it should be...Most people that post 20+ hours or Days of Service is putting on a Bench and using very little...Its like watching Paint Dry...No Sheet... Now Really, who are they kidding with miss Noma for usage
Serious note,
I'm a heavy user (10-12 hours (Tops) * (Hard Usage) with Lots of Widgets going...to mention a few...Next Launcher, SMS, Swiftkey, 3 Emails Choices, Calendar, Weather, CPU, Juice Defender Ultimate...Not counting System Apps as well...I'll stop there...
Oh!!!
Cache Cleaner NG will help with Lags and Performance in addition to Busy Box Lining up the Ducts in the UI System keeping the Wind in the Sail for Ocean Vista Cruises
Now,
Lets talk about Juice Defender...Wasn't an Advocate for this App but, I'll get an Extra 2 hours Battery Life with this App...Believe it or Not
Music & Pictures should be in one of your Explorers...Search and Find...Their there... B)
#838 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 15 January 2014 - 03:09 PM
Open Root Explorer or Explorer of choice for Pics and Music:
For Music...
  • sdcard
  • Chose the Camera that took the Pics
  • Mine... Zoom Camera
  • All my Pics for that Camera are shown
#839 buckeyestilidie
buckeyestilidie
  • 288 posts
Posted 15 January 2014 - 03:18 PM
Serious note,
Oh!!!
Now,
I have no widgets and like 20 apps.... Lol I have cache cleaner but I don't have busy box and I'll look into it. I just don't understand JD lol
#840 buckeyestilidie
buckeyestilidie
  • 288 posts
Serious note,
Oh!!!
Now,
