Buckeye...
Sounds like some LOL going on from Post 800
Amen Brother Ben....Buckeye
Posted 13 January 2014 - 01:37 PM
Buckeye...
Posted 13 January 2014 - 03:26 PM
I can seem to get the wifi tether app working is there a certain device profile I need to set it as? I tried downloading flashing the CM11 WifiAP file and it still doesn't work. It just spins saying starting tethering. This is on CM11 Kitkat
Posted 13 January 2014 - 03:27 PM
Posted 13 January 2014 - 04:12 PM
HD Video recording fix has been merged.
Droid Razr Maxx | SS3.6 AviatorBlur / CM11 N10 | RastaKat Xoom Wifi | Big Part 4.3 N7 | MultiROM / RastaKat OG Droid | kfazz CM10 port
Posted 13 January 2014 - 04:14 PM
It was a late night.... LolBuckeye...
Posted 13 January 2014 - 04:44 PM
Drew...
Can you get the Fix for WiFi Tethering for King 12...I can't seem to Post the Link for some reason...really I suck at it to be honest...
Posted 13 January 2014 - 06:59 PM
Speaking of kitkat I will be flashing it tomorrow night and post results. Hopefully it's a winner lolDrew...
Posted 14 January 2014 - 01:30 PM
Drew...
Posted 14 January 2014 - 07:23 PM
Okay,, sorry about this question... may have been covered earlier.. I've just flashed the latest nightly for KK and want to change the screen resolution. Here is my problem... I go into es file explorer, access the buildprop with editor and attempt to change the value to 240 as per instructions. When I hit the save button in the upper right corner of the editor, it sends a pop up at the bottom of the screen stating that this operation needs elevated permission try changing root access mode. In other words, it won't let me save the file. I've granted ES file explorer root access...so i'm not sure why I can't save..
Posted 15 January 2014 - 02:44 AM
Did you open to r/w to make sure your able to allow the Save..Okay,, sorry about this question... may have been covered earlier.. I've just flashed the latest nightly for KK and want to change the screen resolution. Here is my problem... I go into es file explorer, access the buildprop with editor and attempt to change the value to 240 as per instructions. When I hit the save button in the upper right corner of the editor, it sends a pop up at the bottom of the screen stating that this operation needs elevated permission try changing root access mode. In other words, it won't let me save the file. I've granted ES file explorer root access...so i'm not sure why I can't save..
Posted 15 January 2014 - 04:30 AM
Did you open to r/w to make sure your able to allow the Save.. If you're settings are still set at r/o that may be the reason for your message Its Bubba"Stubborn In Your Bones"
Posted 15 January 2014 - 05:31 AM
Try these steps :Yes. In es explorer settings, I tapped on root explorer, chose Mount r/w, and then selected the r/w option for each item. Still unable to save
Posted 15 January 2014 - 06:24 AM
Posted 15 January 2014 - 06:40 AM
Just redo your process to Reflash from scratch or Create a New Slot and Flash your Nandroid (Backup)I think I'm stuck in a boot loop. I always have the red kit kat boot logo showing. I was on 10.1 and was trying to go to KK.
Sent from my Amazon Kindle Fire using Tapatalk 2
Posted 15 January 2014 - 06:56 AM
I did three times with a new slot and still nothing. Is it okay it's on my SD?Just redo your process to Reflash from scratch or Create a New Slot and Flash your Nandroid (Backup)
Its Bubba
Posted 15 January 2014 - 07:06 AM
Yes its okay...I did three times with a new slot and still nothing. Is it okay it's on my SD?
Posted 15 January 2014 - 07:12 AM
Not factory but I'll try.Yes its okay...
Not sure why this is not working...
Crazy question:
After you Create a New Slot are you doing the following before flashing your choice of ROM:
* Wipe Cache
* Wipe Data
* Wipe Factory
* Wipe System
* Reboot
Its Bubba
Posted 15 January 2014 - 07:15 AM
Do I just swipe to factory reset then I do advanced Wipe and check all the other boxes?Yes its okay...
Crazy question:
* Wipe Cache
* Wipe Data
* Wipe Factory
* Wipe System
* Reboot
Its Bubba
Posted 15 January 2014 - 07:27 AM
Buckeye good Buddy...Do I just swipe to factory reset then I do advanced Wipe and check all the other boxes?
