#781
Posted 10 January 2014 - 04:08 AM
#782
Posted 10 January 2014 - 04:26 AM
Yes, I'm noticing mostly when your screen goes Dormant or with Lock Screen... Been on my target list to find out WhyDoes anyone else have a problem with the phone freezing and having to do a hard reboot running this ROM?
Its Bubba
"Stubborn In Your Bones"
#783
Posted 10 January 2014 - 05:05 AM
#784
Posted 10 January 2014 - 09:08 AM
True...I notice it happens when I'm running my WiFi tethering and texting people, in between checking my messages at some point it freezes. Its done it without WiFi tether on as well. I am running as my stock ROM slot.
Also happens with Incoming Calls & Texts that Freeze the Screen when going into a dormant screen...
Conflicts between Receiving & Shutting Down..
I don't Tether often to notice
Its Bubba
#785
Posted 10 January 2014 - 04:52 PM
I've had a couple of freezes with dormant screen and calls as wellTrue...
Its Bubba
#786
Posted 10 January 2014 - 05:05 PM
I posted this same situation many months ago... Using Lock screen seems to compound this issue a little more as wellI've had a couple of freezes with dormant screen and calls as well
That's where I've narrow it down to...
It's Bubba
#787
Posted 10 January 2014 - 09:10 PM
I have a couple problems. The main one being my GPS not working. Having to go into safestrap to activate my stock slot for my GPS sucks pretty bad. I read someone said there's a fix, but I couldn't find it. Another is tethering not working. Also about 30% of the time my bluetooth doesn't work. I use my bluetooth for my stereo headset, so this is a biggie. All these problems have made me consider jumping back down to 4.1.2 but I love the battery life and speed. If I could get a fix for these problems I'd be in a very happy state with this ROM.
#788
Posted 11 January 2014 - 10:09 AM
tethering has a fix. there's a zip file in ZKK's main xt912 folder
Bluetooth is semi working for me too. I can pair my BT Keyboard, but not my headset (Jawbone Icon)
Haven't had any GPS issues <knocks on wood>
Droid Razr Maxx | SS3.6 AviatorBlur / CM11 N10 | RastaKat Xoom Wifi | Big Part 4.3 N7 | MultiROM / RastaKat OG Droid | kfazz CM10 port
#789
Posted 11 January 2014 - 12:22 PM
Do I just download the zip and install?tethering has a fix. there's a zip file in ZKK's main xt912 folder
Sent from my Amazon Kindle Fire using Tapatalk 2
#790
Posted 11 January 2014 - 06:00 PM
#791
Posted 11 January 2014 - 06:53 PM
yup
Sent from my Nexus 10 using Tapatalk
#792
Posted 11 January 2014 - 10:02 PM
#793
Posted 12 January 2014 - 04:52 AM
Yes
#795
Posted 12 January 2014 - 01:34 PM
Thanks for the quick response and great work you do! Also for the update do you know which is the most stable build? I'm on the most rent stable build, but I'd enjoy having good Bluetooth use and the tethering fixed. Not to mention sometimes my wifi won't connect.The tethering fix should've been included in the latest build and I will include it in future builds
#796
Posted 12 January 2014 - 10:30 PM
Thanks for the quick response and great work you do! Also for the update do you know which is the most stable build? I'm on the most rent stable build, but I'd enjoy having good Bluetooth use and the tethering fixed. Not to mention sometimes my wifi won't connect. Sent from my Amazon Kindle Fire using Tapatalk 2
If you download the newest gummy version that was released on 12/31 it has everything working but some have had screen freezing problems. Or if you want 4.2.1 aviator blur works great with no problems
#797
Posted 13 January 2014 - 07:03 AM
is the battery life better?If you download the newest gummy version that was released on 12/31 it has everything working but some have had screen freezing problems. Or if you want 4.2.1 aviator blur works great with no problems
#798
Posted 13 January 2014 - 08:12 AM
#799
Posted 13 January 2014 - 10:08 AM
The only way to get the Best Battery Life from Any Phone is Few Apps and No Widgets plus No Tethering Period to mention a few or the return of the Flip PhoneDepending on what kind of usage it's being put through. I tether 24/7 so my batter life gets sucked down the drain pretty fast but normal the battery is good.
In addition, the Internal Battery is getting Older and not holding a Hard charge...
I'm a Heavy User...
10-12 hours Tops... That means using the Phone Not Dormant...
Its Bubba
#800
Posted 13 January 2014 - 12:49 PM
And the GPS and tethering and bluetooth work?The only way to get the Best Battery Life from Any Phone is Few Apps and No Widgets plus No Tethering Period to mention a few or the return of the Flip Phone In addition, the Internal Battery is getting Older and not holding a Hard charge... I'm a Heavy User... 10-12 hours Tops... That means using the Phone Not Dormant... Its Bubba"Stubborn In Your Bones"
