1077 replies to this topic
#701 buckeyestilidie
buckeyestilidie
  • 288 posts
  • Twitter:buckeyestilidie@yahoo.com
Posted 31 December 2013 - 10:13 AM
* Settings...
* Sounds
* Phone Ringtones
* Chose your Tone
* Might ask you with 3 options
* Chose Media Storage
Back out of settings...I always Reboot after System changes... Should work
Its Bubba
"Stubborn In Your Bones"
I use my go sms for Ringtones because the Ringtones I download go into that app. Also the go launcher seems to drain some battery really quick lol is that normal??
Sent from my Amazon Kindle Fire using Tapatalk 2
#702 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 31 December 2013 - 11:15 AM
New build is in the OP! Enjoy! :D
  • The Persuader and Redalert like this
Donate? Click on signature :)
#703 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 31 December 2013 - 11:18 AM
Aviator has a Very Good Launcher...try using ZKK007 for a while and compare it to GO Launcher...
Whatever Launcher I am on, I will use the Built-In Ringtones within the System...I pretty much stay with Media Storage...for me its has the least amount of issues...I cant remember the last time I had issues with RIngtones other than 3 Parties Apps...
Go Launcher is pretty good No issues with their Launcher...Next Launcher is pretty Awesome...Takes you to a New Element of change within your ROM of Choice...
As far as Battery Drainage...check out Apps running in the background...Or Apps/Widgets that require on going Data updates...Apps IMO are the first thing I will check to see which could be my culprit ...Process of elimination...
  • Redalert likes this
#704 buckeyestilidie
buckeyestilidie
  • 288 posts
Posted 31 December 2013 - 11:39 AM
Go Launcher is pretty good No issues with their Launcher...Next Launcher is pretty Awesome...Take you to a New Element of change within your ROM of Choice...
It isn't bad I just liked the way stock felt. Go pro makes me feel like my phone belongs to a teenager with all the bubble app icons lol I'm looking at Nova now and buzz. I have watchdog downloaded as well and no notifications so far.
#705 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 31 December 2013 - 11:43 AM
If you like All the bells and Whistles...Next launcher...Tons of stuffs...Give it a try..You won't be disappointed Promise
#706 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 31 December 2013 - 11:46 AM
Next launcher is good! There are some nice themes for it too!
#707 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 31 December 2013 - 11:50 AM
ZKK007...
Wanted to Point Out something I noticed in your Avatar...
Its shows 2 Images...
  • One as a Robotic Android Guy
  • The Other...A Fighter Jet
#708 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 31 December 2013 - 12:51 PM
Dirty Flashed Update #31...Not recommended...
Any Performance Issue I will do the Necessary Wipes...Just trying to see if any changes or issues occur...
#709 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 31 December 2013 - 12:54 PM
ZKK007...
I only see that plane in my Avatar :p
#710 buckeyestilidie
buckeyestilidie
  • 288 posts
Posted 31 December 2013 - 01:07 PM
Loving next launcher. Btw is the update a stable release?
#711 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 31 December 2013 - 01:09 PM
The update that came in via OTA updater is the same build that I put in the OP. You can either download it here, or using the OTA updater app. You flash it the same (in Safestrap).
#712 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 31 December 2013 - 01:14 PM
:) Work with me now will yaa  :) ...
Okay, see the number 29  :huh: ...That's the Body of your mysterious Dude...Now that said, now that you know the body is 29...Look at  Armored Head with the Body...If you dont see it...Shift your head to the right...
:rolleyes: Nooo, I haven't smoked any in years...but maybe the side effects are starting to Kick in and Show up Now
Man, I haven't started drinking Wine yet either...Now I am starting to see Sheet.. :o .Now I know Why Gerry Garcia saw stuff we couldn't see... I guess my calling is to start Making Ties like I see in your Avatar... :wacko:
  • ZKK007 and Redalert like this
#713 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 31 December 2013 - 01:22 PM
Don't think so, but you'll be okay Promise...
I did a Dirty Flash...(Didn't Wipe) which is recommended and I am not having any Issues at all...
I've always said, these Guys from Next Launcher are way ahead of its time...You'll be busy trying things let me tell you...Oh! If you change Theme with Next Launcher you're Okay...However, if you want to change do a different Theme Outside of Next Launcher...suggestion would be to Wipe Cache and Dalvik...
If not, you'll Think your Phone is Possessed by the Unknown...
#714 BigCWIshon
BigCWIshon
  • 34 posts
  • LocationKansas
  • Current Device(s):Motorola Droid RAZR MAXX
Posted 31 December 2013 - 02:50 PM
So when the new update comes out, how do we update when we download it? Do we just boot into SS and find the updagr file and flash it? Then just reboot back into the normal system? Or do we have to factory reset, recreate ROM slots and all that bull?
#715 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 31 December 2013 - 02:54 PM
Your best bet is to do all that bull :p I'm about to push the update via OTA updater. You can always freeze OTA Updater if you don't want the notificatipn :p
#716 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 31 December 2013 - 02:56 PM
Oh, I've already pushed the OTA on this one. Must be Gummy that I'm thinking of :p
#717 BigCWIshon
BigCWIshon
  • 34 posts
  • LocationKansas
So will it download this time? Or will we get that "MD5 Error" again?
#718 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 31 December 2013 - 02:57 PM
It should be OK, but I am using Google drive to host the file instead of dropbox so let me know if there any issues.
#719 BigCWIshon
BigCWIshon
  • 34 posts
  • LocationKansas
Posted 31 December 2013 - 03:00 PM
in still getting the MD5 Error....I just downloaded the update off the forum instead of the OTA Updater. It started to download and then stopped Cuz of the MD5 Error..
  • ZKK007 likes this
#720 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 31 December 2013 - 03:04 PM
Are you talking about an error that happens in safestrap? If so, uncheck "check md5sum"
