1077 replies to this topic
#661 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 29 December 2013 - 07:01 AM
Thanks!  I did upgrade Safestrap, followed your instructions above and in OP.
I can boot into stock with no problem.  However, after installing Rom and flashing gapps, the phone does not boot into Aviator.
I have let it sit for quite a while, but it just wont boot into new ROm.  Again, any suggestions are very appreciated.
In the meantime, I will delete Slot 1 again, and I assume KK can now be installed on slot 2, correct?
Also, phone will not start unless using 3 finger salute to get back to SS to allow stock or Tom reboot.
My mistake directing you to the wrong post...
It was...
Goto post #654...KK...
CM 11 can post into any slot you wish... Create a New Slot than flash
But your up and running...
#662 Redalert
Redalert
    Half Man, Half Amazing
  • 1,198 posts
  • Current Device(s):Note 3 / Razr Maxx / Droid2 / LG Ally / Moto Q / Nexus 10
Posted 29 December 2013 - 09:16 AM
Zk ....smooth, smooth, smooth.. Its bad a$$, and gel works now using Ur ROM.... Awesome work bro, thanks.... Now I got to configure later, when kids go to bed, I'm stoked...
Sent from the MAXX using Tapatalk4
#663 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 29 December 2013 - 09:25 AM
Glad your liking it! I should have time to get another update out on the 31st (or sooner, but we'll see) so keep and eye out!
  • The Persuader and Redalert like this
Donate? Click on signature :)
#664 Redalert
Redalert
  • 1,198 posts
Posted 29 December 2013 - 09:38 AM
I understand the ROMs taken up internal storage, needing files from stock to work, is this correct? but Unfortunately I'm close to no room.. To bad they can't get brought over to SD, or can it? Lil noobish to this with ROMs. Thanks.
#665 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 29 December 2013 - 09:41 AM
No the ROM is stand alone aside from needing gapps. It will use the same folders on your internal SD card though. Those are common between stock and any safe strap ROM.
#666 Redalert
Redalert
  • 1,198 posts
Posted 29 December 2013 - 09:47 AM
Gotcha, thanks.... Guess ima need to get rid of some apps on stock side..
#667 Redalert
Redalert
  • 1,198 posts
Posted 29 December 2013 - 09:54 AM
Thought I read some one wiping 10.1 on slot 1, but then 11 won't work, cause it needs 10.1.... Unless I thought I read, or miss read, or was drinking while thinking I was reading.. This has to be wrong cm10 needs to be there for cm11 to run or is this just for initial install...?
#668 Redalert
Redalert
  • 1,198 posts
Posted 29 December 2013 - 10:08 AM
Disregard that last comment, that makes no sense, if I read that somewhere, I think it was meaning something else.
#669 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 29 December 2013 - 12:31 PM
Create a New Slot for either one...
* CM 10.1 Slot 1 only
* CM 11 any Slot including Slot 1
It's Bubba
#670 Redalert
Redalert
  • 1,198 posts
Posted 29 December 2013 - 01:44 PM
Create a New Slot for either one... * CM 10.1 Slot 1 only * CM 11 any Slot including Slot 1It's Bubba "Stubborn In Your Bones"
Yup, got it thanks, bro
#671 Redalert
Redalert
  • 1,198 posts
Posted 29 December 2013 - 01:49 PM
Hey bubster, Im curious what device are u using?
#672 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 29 December 2013 - 02:31 PM
Hello my Friend...
Quite sure you asked me this question and I never gave you a straight up answer...
Well Its the:
Razr Maxx...and GEL-ing :p to Boot... :p...Does Yellow make me look Fat?
  • Redalert likes this
#673 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 29 December 2013 - 02:40 PM
ZKK007-
Nothing but Net my friend...No issues at All...
Question for ya..
I am using an App called Awesomeon...Its really the Balzz...Never have to hit the Power Button to active your phone...Just a Tilt of the phone...
Well, is it possible to do the same or emulate the same application or copy as a Built in App in Aviator...Just throwing it Out their...One less step
The App: "Awesomeon" give it a Drive by...
Chow  Awesome ROM...Daily Drive Dude...
#674 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 29 December 2013 - 02:44 PM
How's it going for yaa good Buddy with Aviator...Not bad...Its The Stealth ROM that just becomes the Leader of the Flight Deck for take Offs...
So far Red...Its a Keeper....Still on CM too...Can not tell a lie...
#675 Redalert
Redalert
  • 1,198 posts
Posted 29 December 2013 - 03:17 PM
How's it going for good Buddy with Aviator...Not bad...Its The Stealth ROM that just becomes the Leader of the Flight Deck for take Offs...
It is by far the best ROM, I've flashed. Not a single problem, butter a$$ smooth, nice migration. Ive flashed others, with different problems.. None here, ive seen. My only downside, is I got to make some internal storage room. I have not too many apps, so I need a few hours to figure what it is that needs to be uninstalled, and stuff that needs to be moved to SD. Nice work zk.
  • The Persuader likes this
#676 Redalert
Redalert
  • 1,198 posts
Posted 29 December 2013 - 03:20 PM
I'm going to be looking into johns free up space, thread.. Just haven't done it yet.. Sent from the MAXX using Tapatalk4
#677 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 29 December 2013 - 03:38 PM
Disk Usage works really well on CM...but Aviator theirs is some issues...Cleaned Data, Cache and Forced Closed...Still give you some details but not a keeper on this ROM...
Make sure you clean up your Emails too...Pending, Sent, Drafts, Unnecessary Unread emails for example...they take up Data which purged will give you some additional MB...depending with Apps and Emails...
Make sure you Reboot after you've made your deletions...Kinda Lines up the Ducts for better performance...
Chow my good friend...
#678 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 29 December 2013 - 03:39 PM
Curious about John's Free Space...
#679 robocuff
robocuff
  • 415 posts
Posted 29 December 2013 - 06:23 PM
#680 He Hate Me
He Hate Me
Posted 29 December 2013 - 06:34 PM
This is my first ROM, and not sure if it's just common or if something isn't working right, but my home button isn't working at all with this?
