Are your contacts not backed up to your Google account?.......
Not that I know of, but seriously thanks for pointing out the obvious hahaha! I'll give that a try.
Posted 27 December 2013 - 07:24 PM
Posted 27 December 2013 - 07:27 PM
Sorry for having to post again -- I switched to the stock ROM and re-synced my verizon backup. Went back to KitKat, and was able to login to Verizon "Cloud", which is now syncing my info onto KitKat. Thanks john, I'll also backup to google!
Posted 28 December 2013 - 03:46 AM
Yes... Had a momentGel the hair product, man, come on.....lmfao
No i mean.. Gel = Google experience launcher.
Sent from the MAXX using Tapatalk4
Posted 28 December 2013 - 09:10 AM
Now I'm having one. Is that a yes Ur running gel, on zk's rom cm11? If so, what phone do u have?Yes... Had a moment
Its Bubba
Posted 28 December 2013 - 11:39 AM
Gel is driven by CM 11...Now I'm having one. Is that a yes Ur running gel, on zk's rom cm11? If so, what phone do u have? Sent from the MAXX using Tapatalk4
Posted 28 December 2013 - 02:27 PM
ZK... Is piggybacking KK off of CM to offer KK
Its Bubba
Posted 28 December 2013 - 03:01 PM
Hope u can help:-)
Well, downloaded Cviator KitKat CM11
Deleted old CM on Slot 1 in Safestrap
The did advanced wipe and took care of the 4 wipes.
Rebooted.
Loaded Rom, and install fails.
Did above 3x and 3 failures.
Any ideas?
Posted 28 December 2013 - 03:05 PM
Hope u can help:-)
Rebooted.
Any ideas?
Posted 28 December 2013 - 03:19 PM
It seems that the MD5 is issue...No MD5 file found
E; Error executing updater binary in zip
Error flashing Zip
Updating partition details FAILED
Appears file is bad. Do u agree?
Posted 28 December 2013 - 03:23 PM
Grabbed file from site in below link. Trying another download.
ZKK007's Public Folder:
CM11:
NIGHTLY DOWNLOADS:
The only changes made between these Nightly builds are from CM.
---------->Aviator_CM11_KitKat_NIGHTLY_20131221:
Posted 28 December 2013 - 03:24 PM
Error flashing Zip
What version of safestrap and what build number are you using? The file is good, but the file isn't compatible with the version of safestrap that you are using. If you have safestrap 3.63 or 3.65 then you should be ok to flash the 20131221 build.
Posted 28 December 2013 - 03:33 PM
I am not using the Ss versions u mentioned. I am using SS 3.53
Any other suggestions are appreciated.
Posted 28 December 2013 - 03:35 PM
There is an error executing updater binary in zip. Yuck! Ihave no idea of what to do. I have flashed CM10 roms on this device many times. Moved file from ext sd to internal sd and still having issue.
Posted 28 December 2013 - 03:40 PM
You need to upgrade to safestrap 3.65.
Posted 28 December 2013 - 07:26 PM
Thanks! I did upgrade Safestrap, followed your instructions above and in OP.
I can boot into stock with no problem. However, after installing Rom and flashing gapps, the phone does not boot into Aviator.
I have let it sit for quite a while, but it just wont boot into new ROm. Again, any suggestions are very appreciated.
In the meantime, I will delete Slot 1 again, and I assume KK can now be installed on slot 2, correct?
Also, phone will not start unless using 3 finger salute to get back to SS to allow stock or Tom reboot.
Posted 28 December 2013 - 07:45 PM
Goto post #654...KK...
CM 11 can post into any slot you wish... Create a New Slot than flash
It's Bubba
Posted 28 December 2013 - 07:56 PM
- Download the new apk:
- Boot into stock and open the safestrap app.
- Click "Uninstall recovery".
- Use a file explorer to delete the safestrap folder on your internal SD card. Move any back ups! This will delete any backups and ROM slots.
- uninstall the safestrap app like a normal app. Settings>apps>safestrap>uninstall.
- Install the new safetrap app.
- Open the new safestrap app.
- Click "Install recovery".
- Reboot into safestrap.
- Create a NEW ROM slot. Any old ROM slots will give you errors.
- Flash the ROM and follow the instructions
All installations have failed with new rom and older rom as u suggested. It seems that the MD5 file cant be found.,a nd the zip signature can't be verified.
I have tested another rom and it installed without any issues.
Perhaps u can help?
Posted 28 December 2013 - 08:07 PM
As I said in the other thread, there is no md5 file, so that's normal. Turn off signature verification in SS options to correct the other error and the Rom will flash correctly.All installations have failed with new rom and older rom as u suggested. It seems that the MD5 file cant be found.,a nd the zip signature can't be verified.
Perhaps u can help?
Posted 29 December 2013 - 06:17 AM
Posted 29 December 2013 - 06:37 AM
This ROM is working great for me. Thanks for the advice on peeve us posts. I have a quick question about using Google search with this ROM. The ROM's launcher allows for the use of "ok google" voice search activation all the time. If I use another launcher like apex, it doesn't seem that I can do that. Is it possible only with the launcher loaded with the ROM or can it work with other launchers too?
That feature is part of the Google Experience Launcher (GEL). I don't know of another launcher that will have that feature yet.
