I'm having problems with my wifi connecting and showing blue. It'll connect but just show Grey. I'm also wondering what files do I move to my SD card for upgrading to SS 3.65. Lastly for wifi tethering it says connecting but never connects. Other than that I'm getting great battery and loving the rom and the support with it.
You have to let the WiFi kick on and do its thing. Mine runs perfectly I recommend rebooting and wiping cache and dalvik cache (you can also do this in the Settings> CPU Control > and swipe all the way to the right and theres and option for it to wipe all that for you and your phone will automatically reboot)
ZK posted up above about if you have a WiFi Tethering problem and how to fix, so I'd read that aslo.
