1077 replies to this topic
#41 outpost31
outpost31
  • 6 posts
  • Current Device(s):razr maxx over ROM'ed
Posted 30 June 2013 - 02:18 PM
I actually downloaded this on the 28th -- anyway, the only issue i have/had is the heating up/freezing which i then have to reboot.  I did notice that at times it would appear to bootloop, (and with my impatience i kept forcing the boot) but after two or three 'automatic' reboots it went into the boot screen and no problems (so now i just let it reboot as long as it takes --it will eventually get there).  Love it otherwise, i even flashed the JBX-Hybrid kernel and i don't know if that made a difference, but man the battery life is great!  Woulda posted a screenshot however i just reset my phone back to stock so i am back to rebuilding the ROMs... <sigh>.. Not sure of the Radio comments, seems to work for me radio wise... but like i say, not sure if that's also cuz of the kernel hack....(IDK) I tried all the Aviator ROM's --seems like i like this one the best!
--Keep up the great work!!
#42 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 30 June 2013 - 03:02 PM
At your convenience I would Reflash this ROM...Go back to the Original OP or (Post) and start again...It will get worse as time goes on...
Just a Thought
#43 Einsteindks
Einsteindks
  • 340 posts
Posted 30 June 2013 - 03:34 PM
My microSD card just tanked!!!!!!
sent via RazrMaxx over Tapatalk, y'all!
#44 outpost31
outpost31
  • 6 posts
Posted 30 June 2013 - 03:46 PM
thanks for that advice, yeah, i JUST got it all set up again.. froze some more apps etc... tweaks etc.. gotta run for a while.. i like this one better than the 'original' CM10 tho...   (ask me in a week how i feel! lol)
#45 outpost31
outpost31
  • 6 posts
Posted 30 June 2013 - 04:10 PM
Kinda jealous, mine didn't but i was ironically looking at getting a new one... I know you can get a 32GB for about $20 on a certain site with a jungle name!!!
#46 Einsteindks
Einsteindks
  • 340 posts
Posted 30 June 2013 - 05:41 PM
Limited lifetime warranty, I'll be getting another one, my 3rd.
#47 lazer
lazer
  • 287 posts
  • LocationWestern PA
Posted 01 July 2013 - 10:22 AM
Built in "Tether" options and my external Wifi Tether apps no workie in this rom :(
#48 Einsteindks
Einsteindks
  • 340 posts
Posted 01 July 2013 - 11:36 AM
Paid for a 64Gb 'virtually indestructible' microSD card, and that's what I want out of SanDisk! My family has a sort of history with exercising warranties to get what we paid for. Like, when the tranny in my 2007 G5 GT 'detonated', I got a new tyranny + clutch on GM's dime because I had an extended coverage warranty.
  • outpost31 likes this
#49 outpost31
outpost31
  • 6 posts
Posted 01 July 2013 - 12:21 PM
NICE!!  I have the opposite luck.. seems everything went my way until i got married...... *just kidding
  • The Persuader likes this
#50 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 01 July 2013 - 03:56 PM
It's working fine for me. Have you checked all of your settings?
Donate? Click on signature :)
#51 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 01 July 2013 - 03:57 PM
#52 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 01 July 2013 - 04:45 PM
Never used Tether before...What are the Settings so I can Nail it the first time...
#53 mattkilla
mattkilla
  • 187 posts
  • Google+:mattkilla420
  • LocationNorth Carolina
  • Current Device(s):Droid Razr Maxx xt912 , Samsung Droid Charge (FP8)
Posted 01 July 2013 - 08:36 PM
How do you obtain a GPS fix on stock ROM like stated in the install instructions?
sent from my Droid RAZR Maxxfrom another dimension...
#54 Einsteindks
Einsteindks
  • 340 posts
Posted 01 July 2013 - 10:43 PM
Easiest way I know of is to turn on navigator (blue arrow), provided you have Google Maps installed, then choose the map option. Once the faint blue circle gets small and then disappears under the arrow, you are locked. You can also zoom all the way in to confirm there is no more faint blue circle under the arrow.
#55 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 02 July 2013 - 03:12 AM
Go settings>more...>tethering and portable hotspot. Check your password and security under "set up WiFi hotspot" then turn it on by pressing "portable hotspot". Connect your device and you should be all good :)
#56 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 02 July 2013 - 04:07 AM
Thank you
👍Awesome ROM my friend
Its Bubba
#57 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 02 July 2013 - 04:46 AM
hellow is any one getting weak network..I'm feeling so ..
#58 lazer
lazer
  • 287 posts
Posted 02 July 2013 - 05:03 AM
Been trying it as an open network. Cleared Cache & Dalvik - Fixed Permissions. Tablet says it's connecting and obtaining IP but never gets a lock. If I boot into "Stock" and use the external Tethering app, all is well. Can't figure out what's wrong. :(
Tried setting up "Security & Password options" also to no avail. Right now the damn thing is greyed out and I can't even untick it and is stuck on the phone as "Turning hotspot on..." :o
#59 SoccerRef12
SoccerRef12
  • 529 posts
  • Twitter:@SoccerRef12
  • LocationLampasas, TX
Posted 02 July 2013 - 05:43 AM
You have to use the pull down notification and "allow" the connection.
Sent from my Droid Razr Maxx using TapaTalk 2
"If you truly learned from your mistakes, I would be a genius by now!"
#60 lazer
lazer
  • 287 posts
Posted 02 July 2013 - 05:47 AM
But I'm not getting any Pull down notification.... ??? Everytime I select to turn hotspot on, it just greys out and says "Turning hotspot on..." and then I noticed I can't even deselect it or turn my wifi back on until a reboot.
Have tried another Cache/Dalvik wipe. Fix permissions... and dirty flashed Rom over ontop again to no avail. Even uninstalled my other Wifi Tether apps and FoxFi which I had restored with TIBU before.
Booting into AOKP now to see if it is also continuinig the problem in the same manner as it was yesterday.
