1077 replies to this topic
#561 xxplosive
xxplosive
Posted 17 December 2013 - 01:59 PM
Does this ROM have AVRCP 1.3 included? I know that it was added for Android 4.3 so logically it should also be included in 4.4. I'm trying to get track info pushed out to a bluetooth stereo and it still doesn't seem to work even though I'm on KitKat.
#562 GTIM2L8
GTIM2L8
    A Man On A Mission!
  • 89 posts
  • Twitter:@GTIM2L8
  • Google+:gtim2l8
  • LocationThe Southern State That Started It All.
  • Current Device(s):Raspberry Pi, Droid Razr Maxx HD XT926 - Droid Razr XT912 - TF201 Asus Transformer Prime
Posted 17 December 2013 - 02:38 PM
Great ROM love everything about it. Only problem I've had is WiFi tether starts but doesnt work. I am not able to find the hotspot. Has anyone else had a similar issue or knows how to fix it
Found this for a CM11 ROM on another sight. Try
Edit: Just used it on CM-11 12-16 and confirmed it works.
If you would like to thank the Dev for this you can go
 and thank him.
I hope this helps, it was the only thing in CM 11 ROM's that was holding me back from using CM 11.
Edited by GTIM2L8, 17 December 2013 - 05:21 PM.
''Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.'' - Albert Einstein
#563 andymac111
andymac111
  • 27 posts
Posted 17 December 2013 - 03:45 PM
This ROM is working pretty well for me but I do have a few questions.
Has anyone had problems with GMail not downloading attachments? I can't get it to download attachments anymore. Any thoughts? I tried rebooting. I had the Email app frozon but have been using the Gmail app. I unfroze it to see if that might have anything to do with it.
One other thing I noticed is when the camera is in the quick access ribbon or tiles of the notifications bar and you press it, it opens the camera in the ribbon. Is this something with the ROM or is this how CM works? I am new to it.
Lastly, is there anyway to get your pics from the camera saved to the External SD card?
Thanks for the work you do on this ROM.
#564 BigCWIshon
BigCWIshon
  • 34 posts
  • LocationKansas
  • Current Device(s):Motorola Droid RAZR MAXX
Posted 17 December 2013 - 07:20 PM
So I'm having a couple issues with this ROM. This is a AMAZING ROM and I love how flawless it runs just except a few bugs in having.
Apollo won't open at all. Force Closes every time. Don't know what to about that...
This has only happened to me twice now but ive left my phone locked for a bit and when I got to hit the unlock button the phone stays black and doesn't unlock even though the notification light is on. Had to force it to power down and back up each time.
I getting this error that keeps flashing up saying "No APN specified on this device" this just started happening and I'm gonna do a reboot and see if that helps...
If anyone knows how to fix any of these issues please lemme know..
#565 drewski11
drewski11
  • 186 posts
  • LocationSF Bay Area, CA
Posted 17 December 2013 - 09:29 PM
and thank him.
Works on Gummy too :D
Sent from my Nexus 10 using Tapatalk 4
#566 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 18 December 2013 - 06:40 AM
A new build is in the OP. Built this morning and should have the WiFi tether fixed. Enjoy! :)
  • GTIM2L8 likes this
Donate? Click on signature :)
#567 BigCWIshon
BigCWIshon
  • 34 posts
  • LocationKansas
Posted 18 December 2013 - 08:05 AM
(Aviator CM10.1 Current Version 1.0.2. Aviator KitKat Current Version: NIGHTLY 20131218)
Hi all,
Fly higher with Aviator! Please do not post this anywhere else without prior permission.
Other Aviator Versions:
Click on icon to got to that Aviator Version OP.
I am not responsible for anything that may happen to your device. (... nothing should happen)
These screenshots show Aviator CM10.1
Click to
  • Deodexed.
  • Zipaligned.
  • 4.2.2/4.4 System.
  • Init.d tweaks - Battery and Performance based.
  • ADBD.
  • 1% battery.
  • Reboot in power menu.
  • Volume rocker change music track mod.
  • Titanium Backup (Can be uninstalled, not a system app).
  • Battery Calibration (Can be uninstalled, not a system app).
  • No Frills CPU Control/Performance Control (Baked into settings. I.E. go into settings).
  • CPU Sleeper (Baked into settings. I.E. go into settings).
  • OTA Updater (Baked into settings. I.E. go into settings).
  • Beats Audio (Baked into settings. I.E. go into settings).
  • Superuser.
  • Apollo Music Player.
  • GPS tweaks.
  • Build.prop tweaks.
  • Ad blocker - via modified /system/etc/hosts file.
  • Inverted Calender.
  • Inverted MMS.
  • Custom theme – Wallpaper, boot animation, 3G/4G icons, and semi-transparency.
STS-Dev-Team and Cyanogenmod - Source.
Previously thanked people in Aviator Blur OP.
Testers
arikr - 3G PagePlus Tester
If I have forgotten anyone, PLEASE PM me.
AVIATOR CM10.1 MUST BE INSTALLED IN SLOT 1 ON SAFESTRAP.
Aviator KitKat can go on any slot.
  • Transfer ROM and gapps zip files to SD card.
  • Reboot into SafeStrap (3.07, 3.11, or 3.6x).
  • Delete ROM slot 1.
  • Recommended: Boot into stock system and attain a GPS fix in Maps. Then reboot back into Safestrap.
  • Create ROM slot 1.
  • Install Aviator ROM file.
  • Flash gapps on top of ROM.
  • Reboot after installation.
  • Setup phone. NOTE: If phone hot reboots at WiFi addition, reboot into Safestrap, wipe cache, dalvik cache and fix permissions.
  • Finish phone setup.
  • Let phone settle for 5-10 minutes.
  • Go into Settings>CPU Sleeper. Check "Enable auto-start on reboot" (First Line), then "Start Service" (Second Line) (Press twice).
  • Charge to 100% for battery calibration or use battery calibration app.
  • If you want the 1% Aviator battery icon which is in the screenshots, go to settings>system>statusbar>Battery status style and select "Icon."
  • Enjoy!
Don't forget to read the "Bugs" list for bug fixes.
ZKK007's Public Folder:
CM11:
NIGHTLY DOWNLOADS:
Aviator_CM11_KitKat_NIGHTLY_20131218:
Aviator_CM11_KitKat_NIGHTLY_20131207:
Aviator_CM11_KitKat_NIGHTLY_20131205:
Aviator_CM11_KitKat_NIGHTLY_20131202:
Aviator_CM11_KitKat_NIGHTLY_20131126:
Aviator_CM11_KitKat_NIGHTLY_20131122:
4.4 GAPPS DOWNLOADS:
Stock GAPPS 20131208:
Stock GAPPS 20131206:
Stock GAPPS 20131120:
CM10.1:
STABLE DOWNLOADS:
Aviator_CM10.1_v1.0.2:
- Based on CM10.1.3.
Aviator_CM10.1_v1.0.2 MIRROR:
Aviator_CM10.1_v1.0.1:
- Based on CM10.1.2
Aviator_CM10.1_v1.0.0:
NIGHTLY DOWNLOADS:
The only changes made between these Nightly builds are from CM.
for CM Nightly change log.
Aviator_CM10.1_20130718_NIGHTLY:
Aviator_CM10.1_20130714_NIGHTLY:
Aviator_CM10.1_20130711_NIGHTLY:
Aviator_CM10.1_20130709_NIGHTLY:
Aviator_CM10.1_20130708_NIGHTLY:
Aviator_CM10.1_20130706_NIGHTLY:
Aviator_CM10.1_20130705_NIGHTLY:
Aviator_CM10.1_20130704_NIGHTLY:
Aviator_CM10.1_20130703_NIGHTLY:
4.2 GAPPS DOWNLOADS:
Aviator GAPPS:
(These gapps have updated playstore and gmail in it.)
Regular GAPPS:
WALLPAPER:
4.2:
4.4:
SEE POST 3 FOR EXTRAS!
Updates:
CM has its own update system; however, if you choose to take a CM update, you may lose some of the Aviator tweaks, etc.
Aviator has it's own OTA updates via OTA Updater:
When an Aviator CM update is available, you will get a notification. You will then download the update using the app. Once downloaded, you will have to manually reboot into safe strap. The download location is sdcard/OTA-updater/Download/[filename].zip
Here is how the Stable and Nightly Updates for Aviator CM will work:
  • If you are on a Stable Aviator CM build, you will only get stable build updates.
  • If you are on a Nightly Aviator CM build, you will get Nightly and Stable updates.
Bugs:
  • WiFi addition makes phone reboot: See installation for fix.
  • Third party Keyboards wont install correctly. Using Titanium Backup, change the AOSP keyboard from a system app to a user app. Reboot and wipe cache and dalvik cache. Install third party keyboard.
  • Status bar icons are not changing: Reboot to see change.
  • WiFi tether stuck on "Turning on...": Reboot. Turn off regular WiFi, then turn on portable hotspot.
  • IF YOU HAVE A GALLERY FC ISSUE, PLEASE TRY MOVING THE CONTENTS OF "DCIM" FROM BOTH SDCARD AREAS OFF OF THE DEVICE.
  • Possible MMS Fix:
    • Dial *#*#4636#*#*, Scroll down and set preferred network type to LTE/CDMA, then exit back to home screen.
    • Open Menu>Settings>More... >Mobile Network>Network Mode and select LTE/CDMA/EvDo
    • Exit back to home screen and reboot.
  • OR TRY:
Click to
4.4 CM11 KitKat Bugs:
  • 3 G may drop out: Go into Settings>More>Cell Broadcasts. Then, uncheck all of the boxes.
  • Some people have been reporting intermittent no audio: No fix yet.
Want to show your Aviator Support with a custom Aviator signature image?
Instructions:
Edit your droidrzr.com profile and go to the signature option.
Copy and paste this text:
Save and enjoy!
Kanging Policy:
Please feel free to use anything here for your personal, or public use. If you do use something from this thread, all I ask to to be given credit where it is due. You do not need to ask for written permission unless it is otherwise stated as part of a forum's kanging policy.
Don't forget to "Like" -->
Or if you want to Donate, click on signature image. Thanks!
What all changes and problems were fixed with the new update ? I can't seem to open the Change Log over my phone lol
#568 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 18 December 2013 - 08:20 AM
What all changes and problems were fixed with the new update ? I can't seem to open the Change Log over my phone lol Sent from my XT912 using Tapatalk
CM11 change log:
P.S. You might want to edit you post and remove the quote of the OP if you can, it just takes up a lot of space :p
#569 arikr
arikr
  • 61 posts
Posted 18 December 2013 - 01:44 PM
CM11 change log:
Sadly 3G is still sketchy for me.. Due do using a odd APN setting (PagePlus's fault).. And since I broke my WiFi network by downloading speeds of 2MB/s.. I can't keep up with the builds right now..
ArtMOD 4.31 - [Droid RAZR XT912] - Maxx'd
[Carrier - PagePlus (3G/2G)]
Dev/Tester/Senior Programmer
#570 ArcaneChaos
ArcaneChaos
  • 18 posts
  • LocationCT
  • Current Device(s):Razr Maxx
Posted 19 December 2013 - 06:39 AM
I get an error status 6 when trying to flash the latest 12/18 nightly.
Using SS3.11, I've redownloaded and verified checksums match.
#571 arikr
arikr
  • 61 posts
Posted 19 December 2013 - 06:46 AM
Use the 3.63 version (i think is the correct up-to-date version)..
#572 arikr
arikr
  • 61 posts
Posted 19 December 2013 - 07:00 AM
Here's the download link to Safestrap 3.63..
#573 drewski11
drewski11
  • 186 posts
Posted 19 December 2013 - 07:49 AM
3.65 is the latest. you can get it here if Goo cooperates :rolleyes
#574 ArcaneChaos
ArcaneChaos
  • 18 posts
  • LocationCT
Posted 19 December 2013 - 07:56 AM
That was it.. thanks guys! I've been flashing every nightly without issue until now so didn't think to get the new version of SS.
#575 vanwho
vanwho
    VanWho
  • 55 posts
  • LocationNorth Carolina
  • Current Device(s):razr maxx xt912
Posted 19 December 2013 - 08:16 AM
I think for the latest builds you have to upgrade to SS 3.65.
#576 tyscheff
tyscheff
  • 71 posts
  • Twitter:tyscheff
  • LocationBaltimore, MD
  • Current Device(s):Droid Razr MAXX_Aviator Blur
Posted 19 December 2013 - 04:44 PM
I forget how to upgrade my SS (Still on 3.11). Last time I made an attempt and I royally screwed up my phone somehow. Is SS 3.65 stable, and I'm loving this ROM
#577 buckeyestilidie
buckeyestilidie
  • 288 posts
  • Twitter:buckeyestilidie@yahoo.com
Posted 19 December 2013 - 05:00 PM
^^^ Is upgrading to 3.65 absolutely necessary or is 3.11 fine?
#578 dwh2o13
dwh2o13
  • 79 posts
  • LocationSt Louis, MO
  • Current Device(s):Droid RAZR MAXX
Posted 19 December 2013 - 05:04 PM
My question as well. Also wondering the preferred/recommended method to upgrade
#579 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 19 December 2013 - 05:20 PM
I'm on 3.63 and it works fine, but I would recommend going to 3.65.
To Upgrade SS:
  1. Make any backup of ROM slots you want to keep.
  2. Boot into stock and open SS.
  3. Uninstall recovery.
  4. Uninstall SS app like a normal app.
  5. Install the new SS.
  6. Open the new SS and install recovery.
  7. Before you reboot, use ES file explorer to copy and ROM backup out of the safestrap folder on your SD card.
  8. Delete the safestrap folder.
  9. Reboot into SS.
  10. Create a new ROM slot. It must be a new ROM slot. Using an existing ROM slot will cause issues.
  11. Flash a new ROM or restore your ROM from your backup.
  • tyscheff likes this
#580 dwh2o13
dwh2o13
  • 79 posts
Posted 19 December 2013 - 06:47 PM
Thanks so much. Is step 7 necessary if I already have nandroid backups of ROMS I want to keep on my external sd card?
