#522
Posted 09 December 2013 - 06:26 AM
Hello all,
I just flashed: Aviator_CM11_KitKat_NIGHTLY_20131207
I cleared the cache and dalvik cache and rebooted
I keep getting the error:
unfortunately andriod keyboard(AOSP) has stopped.
I can't get the keyboard to work for any apps. Any way to fix this?
#523
Posted 09 December 2013 - 06:36 AM
Hello all,
Just download "Google Keyboard" from Play Store and set it as default keyboard..
ArtMOD 4.31 - [Droid RAZR XT912] - Maxx'd
[Carrier - PagePlus (3G/2G)]
Dev/Tester/Senior Programmer
#524
Posted 09 December 2013 - 07:20 AM
I had the Android.System actually stop. Unless I'm typing this incorrectly. I couldn't do anything with the system even after a wipe and re-install. Same problem still occurs.
#525
Posted 09 December 2013 - 07:57 AM
#526
Posted 09 December 2013 - 08:15 AM
the Official/Experimental CM 12/7 is 4.4.1
in About Phone, yours says 4.4 is this a typo or is yours based on a different build?
Droid Razr Maxx | SS3.6 AviatorBlur / CM11 N10 | RastaKat Xoom Wifi | Big Part 4.3 N7 | MultiROM / RastaKat OG Droid | kfazz CM10 port
#527
Posted 09 December 2013 - 11:52 AM
It is 4.4.1. I probably just used parts of the 4.4 build.prop that had the 4.4 number in there. I'll correct it next time
#528
Posted 11 December 2013 - 10:00 AM
Any docs available on the settings-profiles and triggers for aviator cm11?
#529
Posted 12 December 2013 - 08:48 AM
I am really enjoying this ROM. It's been the best I've used so far! A quick question, I have been using the Kit Kat launcher. When I updated to the 12/7 build it went away. Did I screw something up or was it removed? Thanks!
edit: cm11 Aviator 4.4 rom btw.
#530
Posted 12 December 2013 - 09:14 AM
Oops! Never mind, I forgot I needed to re-install gapps after the update.
#531
Posted 12 December 2013 - 07:55 PM
Thanks again
#532
Posted 13 December 2013 - 03:14 AM
Hey ZK..really enjoying the ROM. I have only noticed one thing. I'm using a theme that has inverted contacts (people). I'm seeing the photo, but the names held onto a black font color. As such, I'm unable to see the names. Would this be a ROM tweek or a theme issue?
Thanks again
It's more of a theme tweak. Was the theme made for 4.4? There might be some changes through the versions that will cause that.
#533
Posted 13 December 2013 - 04:49 AM
Thanks ZK. I can check into theme. It worked fine on your original release of the ROM though. This just happened after flashing your latest nightly.
#534
Posted 13 December 2013 - 06:51 AM
Hmm... Well I didn't mess with the contacts at all so I don't think anything I have done would cause that. Let me know how it goes
#535
Posted 14 December 2013 - 09:17 AM
- ZKK007 likes this
#536
Posted 14 December 2013 - 06:15 PM
Would you guys recommend this for a daily driver? I'm looking for a new DD since BW 4.1 is buggy and this looks pretty cool. Do I have to update to a new stock 4.2 first? Do I also need to put this in the first slot? My current rom is in my first slot would it be okay to delete it then install new CM while in SS?
#537
Posted 14 December 2013 - 08:12 PM
4.1.2 needs to be in Slot 1 while 4.4 is ok in any slot. 4.1.2 and 4.4 still has it's small bugs (read the bugs list in the OP) but it should be ok for a daily driver depending on your needs.
#538
Posted 15 December 2013 - 05:53 AM
This is 4.1.2 or 4.2.2? I'm talking about 4.2.2 CM. I seen the bugs, but the bugs BW has is sometimes it won't show pictures on Facebook or Twitter until I clear the cache in SS and sometimes MMS won't send and many others. Plus I wanted to get updated to a new version. BW is 4.1.2 and the CM is 4.2.2
#540
Posted 15 December 2013 - 06:34 AM
You're right, typo on my behalf This is 4.2.2 and 4.4
No biggie, but I do have to convert my stock rom to 4.2.2 or can I just flash this coming from black widow 4.1.2?
