1077 replies to this topic
#501 islandfever
islandfever
  • 353 posts
Posted 06 December 2013 - 05:15 PM
OK, so now after using the Offline APN program and doing what I said above. I have no data signal at all!
I am in a very strong 4G area...tried rebooting etc
#502 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 06 December 2013 - 05:19 PM
Change it back! :p Out of curiosity, what did you change the APN settings too?
Sent from my DROID RAZR using Tapatalk 4
Donate? Click on signature :)
#503 islandfever
islandfever
  • 353 posts
Posted 06 December 2013 - 05:23 PM
I followed the directions when I used the program. It said I had multiple APNs for 311 480 verizon APN and to select the one for verizon wireless. It then said since I am running ICS I had to manually create the changes etc. So I created a verizon wireless APN to match the values in the example in the proggy.
I have multiple APN selections for verizon
five different EHRPD selections and five LTE selections.
The only one that seems to work is the LTE-Verizon Internet one.
The program tells me to create one called "verizon wireless" copy and paste the data. But it doesnt work
#504 arikr
arikr
  • 61 posts
Posted 06 December 2013 - 06:15 PM
Haha you just use the "Go to APN Settings" button to bypass the block.. After that you're on your own..
ArtMOD 4.31 - [Droid RAZR XT912] - Maxx'd
[Carrier - PagePlus (3G/2G)]
Dev/Tester/Senior Programmer
#505 PHSsenior12
PHSsenior12
Posted 06 December 2013 - 09:57 PM
Unable to take screenshots, other than that, great ROM!
#506 drewski11
drewski11
  • 186 posts
  • LocationSF Bay Area, CA
Posted 07 December 2013 - 08:27 AM
there is now an Official / Experimental build out
#507 drewski11
drewski11
  • 186 posts
Posted 07 December 2013 - 08:30 AM
also dhacker29 released a new GApps for OMAP4 devices
#508 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 07 December 2013 - 09:25 AM
I haven't even flashed this myself, but I have to jump on the plane. SystemUI might FC on boot. If it does, I know what I need to fix, but I wont have time until tomorrow. system ui crashed. Linked removed
  • drewski11 and tyscheff like this
#509 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 07 December 2013 - 05:47 PM
I posted the fix 20131207 build is in the OP! (At least it should be fixed :p )
  • gvfd65 likes this
#510 islandfever
islandfever
  • 353 posts
Posted 07 December 2013 - 06:41 PM
What is the nightly based off of? The newest CM unnoff?
  • roach38122 likes this
#511 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 07 December 2013 - 07:45 PM
The OP just messed up really bad. I'll fix it tomorrow.
#512 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 08 December 2013 - 05:18 AM
Here is the download link for the 20131207 build:
ROM:
Gapps:
I'll fix the OP later :p
#513 islandfever
islandfever
  • 353 posts
Posted 08 December 2013 - 08:36 AM
What's this based off of?
#514 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 08 December 2013 - 08:51 AM
CM Source
#515 islandfever
islandfever
  • 353 posts
Posted 08 December 2013 - 08:54 AM
CM Source
Yes, but the newest Unofficial build? or dhackers?
#516 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 08 December 2013 - 11:49 AM
Yesterday's latest build.
#517 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 08 December 2013 - 11:51 AM
Battery isn't too bad, but of course not as good as blur.
Non maxx with about 1 hour of screen time and 65% remaining.
#518 tyscheff
tyscheff
  • 71 posts
  • Twitter:tyscheff
  • LocationBaltimore, MD
  • Current Device(s):Droid Razr MAXX_Aviator Blur
Posted 08 December 2013 - 06:03 PM
Great job :). Loving it! I don't live necessarily in an area that requires 3G, but everything else works
#519 jfranklyn
jfranklyn
  • 8 posts
  • Current Device(s):droid razr maxx
Posted 09 December 2013 - 01:55 AM
Hello all,
I flashed these ROMS and they are working well. You guys did a great job:
aviator_CM11_kitkat_nightly_20131205
gapps-kk-20131120-no_set_metadata
data, wifi working great. I really liked the addition of titanium backup. I was able to restore all the apps from my stock rom.
I have a couple of questions:
Is there any documentation on the functionality like profiles and other settings?
When I select the OTA updater I get this message under available updates:
error fetching update info: invalid ROM aviator CM11-razr & device cdms_spyder combo
Do I need to go back to the CM10 ROM or just keep up with the CM11 and gapps updates manually?
#520 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 09 December 2013 - 03:18 AM
Hello all,
Update Manually...
When a Update is available...It will be Posted...
