#481
Posted 04 December 2013 - 05:20 PM
ArtMOD 4.31 - [Droid RAZR XT912] - Maxx'd
[Carrier - PagePlus (3G/2G)]
Dev/Tester/Senior Programmer
- gvfd65 likes this
#482
Posted 05 December 2013 - 12:13 PM
I was driving most of the night. In a few areas, I did not have LTE, but I still had a slower internet connection. I'm not sure if it was 3g, 1g, 2g? but it worked. It never dropped the signal entirely like some of the earlier builds were doing to me. I'll test in a known 3g area soon, to verify if it works or not.
#484
Posted 05 December 2013 - 01:05 PM
Thanks for the continued dedication to fix this. Also, I just saw that they created a new thread for dtrail on XDA. He has another 20131205 build up now that someone said 3g was working, but other bugs popped up. Others said 3g was not... Probably similar issues.
#486
Posted 05 December 2013 - 05:32 PM
Uploading a new build!
Go ZK go! Go ZK go!.. Lol..
#488
Posted 06 December 2013 - 03:40 AM
I might have some free time at work today to flash the new nightly. Will report back later tomorrow (if available) to let you know what's up . Still running your 4.1 Aviator Blue and loving it (btw), but ready to help ya with this one!
[Edit/Update] - So far everything is all good in the hood. Super slick, data working (4g), camera works fine, GPS locked on quickly. Haven't made any phone calls yet, but I'm just going to go ahead and assume that it's all good in the hood. MMS worked after #*#* fix. Will check back later this evening
#489
Posted 06 December 2013 - 07:21 AM
Does the 1% battery work for anyone?
When you click the phone icon is there a way to have it go directly to the dialer?
#490
Posted 06 December 2013 - 07:22 AM
Try that. Link is in the OP.
Still no data for us Pageplus customers.. -sigh-.. Maybe its just not meant for it..
#491
Posted 06 December 2013 - 08:05 AM
Great job ZK,
I haven't had time to put my normal battery icon in there, but 1% is working. There is a circle icon with numbers in the status bar settings.
As for the dialer, I haven't looked into that too much yet. I don't mind the new interface.
- saycbone and tyscheff like this
#492
Posted 06 December 2013 - 08:27 AM
Great job ZK,
Can confirm: 1% Battery Mod works
- saycbone likes this
#494
Posted 06 December 2013 - 02:07 PM
#495
Posted 06 December 2013 - 02:28 PM
Cycling means? On off?
Correct.. And use "Offline SIM Database" app from the play store to override the block accessing APN's.. And also the bug is dealing with trying to pick the right APN for it to use.. I tinker with it for like 5-10 mins then I get solid 3G..
#496
Posted 06 December 2013 - 02:57 PM
So I ran this ROM for the whole day, and loved it. For it being in such early stages, major props to the devs. Here's my very small list of things I had issues with:
1. Voicemail icon wouldn't go away
2. Couldn't get any calendars to sync
And that's all I've had problems with so far
#497
Posted 06 December 2013 - 03:32 PM
Flashed this last night and its very much improved! When I didn't have 4G, 3G was available, which is a huge step up from previous. Encountered the audio bug for the first time but reset my phone twice and it went away. Other than that, everything seems great!
#498
Posted 06 December 2013 - 04:21 PM
My APNs I think are correct at 311 and 480 being on Verizon Wireless in US.
How are they getting blocked?
Does this ROM allow use of the JBX kernal like Dtrails Build off of latest dhacker build?
#499
Posted 06 December 2013 - 04:24 PM
Yeah, you can use the JBX kernel.
The APN setting is blacked out so you can't change it without hacking into it using that app, or manually doing it with the apns.config file in /system/etc.
#500
Posted 06 December 2013 - 04:34 PM
I already changed it through the APN file fix from a while ago.
HOw do we use that proggy? I just created a new APN called "verizon wireless" after following the instructions about having to manually paste file data because we are using JB. Used the data under APN search for USA Ver wireless.
Mine was using the APN Verizon Internet, but now I switched it to the new one I created with more data in it..
Does your latest build have anymore bells and whistles than what dtrail has put out? I hate the battery circle! Cant even read the numbers!
