1077 replies to this topic
#381 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 26 November 2013 - 03:47 PM
Yes have the 4g, but all black, its not the wallpaper....
Does it look anything like this:
Donate? Click on signature :)
#382 islandfever
islandfever
  • 353 posts
Posted 26 November 2013 - 03:53 PM
Not at all.
#383 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 26 November 2013 - 03:57 PM
This one shows the transparency a bit better.
What happens if you tap the status bar?
  • The Persuader likes this
#384 islandfever
islandfever
  • 353 posts
Posted 26 November 2013 - 04:01 PM
I just did another dirty flash....will let you know.
#385 islandfever
islandfever
  • 353 posts
Posted 26 November 2013 - 04:08 PM
  Same
#386 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 26 November 2013 - 04:12 PM
  Same
Bugger. I guess a clean flash will do it. If it's not too important, I would probably wait since I'll be putting out these NIGHTLYS fairly often depending on work. It will save you having to set up your phone again :p
#387 JerryB
JerryB
  • 11 posts
Posted 26 November 2013 - 04:43 PM
Only issue I am currently getting is that I am not getting audio from any of my apps (Youtube, Apollo), additionally I can not hear when someone calls but they can here me.  Otherwise, great work and really fast.
Anyone else have these issues or know how to resolve?
#388 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 26 November 2013 - 04:46 PM
Did you do a clean install including deleting the ROM slot?
#389 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 26 November 2013 - 05:04 PM
Just wanted to let you guys know that the 1% battery is working, I just haven't managed to change the icons yet.
  • drewski11 likes this
#390 islandfever
islandfever
  • 353 posts
Posted 26 November 2013 - 05:09 PM
Awesome...
Just did clean install and all is well.
Can you do the battery icons as an update.zip as well when you change them?
#391 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 26 November 2013 - 05:11 PM
Awesome...
It depend on where they are. They aren't in the usual place (framework-res, SystemUI). I'll let you know when I find them :)
#392 islandfever
islandfever
  • 353 posts
Posted 26 November 2013 - 06:46 PM
ZK, that status bar issue seems to be when I use Apex Launcher.....when I use the other included launchers...the status bar is transparent....weird
Updated to a version that had KitKat Fixes....
Stock Messaging has a dark theme that I cant get to work....you?
#393 JerryB
JerryB
  • 11 posts
Posted 26 November 2013 - 09:28 PM
I did a clean install, deleted the ROM slot, locked a gps (per earlier instructions) in stock, created a new ROM slot, did full wipe, flashed.  After everything was up and running and I realized the issue I also went back in and wipe cache and dalvik and fixed permissions.
The issue is intermittant and I know not an issue with audio over all because I can still her my ringtone, notifications, etc.  Any ideas or anyone else having similar issue?
Amazingly smooth ROM otherwise!  Fastest I've had on phone yet.
#394 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 27 November 2013 - 04:48 AM
The MMS dark theme is only for the quick reply feature. I will black out the MMS with time.
As for Apex, it must pull the status bar background from another image. So I think you'll be stuck with it if you use Apex.
#395 vanwho
vanwho
    VanWho
  • 55 posts
  • LocationNorth Carolina
  • Current Device(s):razr maxx xt912
I found a possible fix over at XDA Forums to try to get 3g to stop dropping out .  It says to go into the "More" section of Settings and go to the "Mobile Broadcasts" option.  Then, uncheck all of the boxes.  I'm not sure if it works or not, but it's worth a try.  I'll see if it helps or not.
I have been on this "fix" for a couple days now, and it appears to be working.  I drive through 3g areas on the way to work.  It used to go to No Service, and not come back without a reboot.  Now, It does not drop service.
#396 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 27 November 2013 - 04:51 AM
Thanks for the information! I'll add it to the OP Bug fix list :)
#397 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 27 November 2013 - 05:42 AM
For this fix, is it "More">Mobile Networks" and then uncheck the boxes?
#398 islandfever
islandfever
  • 353 posts
Posted 27 November 2013 - 06:28 AM
Nvm
#399 vanwho
vanwho
    VanWho
  • 55 posts
No, you go to "More" >"Mobile Broadcasts" and then uncheck all of the boxes.  It is all of the Amber alerts and such that you uncheck.  I'm not sure how or why it works. I just read it in a thread on XDA Forums and figured it was worth a try.  So far it seems to be working, don't ask me why or how though?  Maybe you know more about why this would work?
#400 islandfever
islandfever
  • 353 posts
Posted 27 November 2013 - 06:33 AM
I also get a wallpaper cropper error and FC when trying to switch wallpaper to a gallery picture.
