1077 replies to this topic
#21 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 29 June 2013 - 02:17 PM
pls help me today I flashed this ROM and booted nicely...I am using gsm in droid RAZR xt 912.in india...I made the APN setting but still no data I can make calls SMS but no data
I put gsm only mode and everything connect data in roaming connect data in 2G etc but nothing works.....??what I need to do..??
#22 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 29 June 2013 - 02:24 PM
You might need a GSM patch. Most ROMs do need it since these are CDMA. I know there is a base one somewhere on xda.
Sent from my XT912 using Tapatalk 4 Beta
Donate? Click on signature :)
#23 dwh2o13
dwh2o13
  • 79 posts
  • LocationSt Louis, MO
  • Current Device(s):Droid RAZR MAXX
Posted 29 June 2013 - 04:37 PM
Just have one question prior to installing as I have not had to do this yet and have been wondering about it.  A nOOb question I'm sure, but I've never had to fix permissions. Can someone please describe the process??  I very much appreciate the help.
#24 rnh
rnh
  • 294 posts
  • LocationA Ct Yankee living in the land of Mass-oles
  • Current Device(s):Razr,
Posted 29 June 2013 - 04:48 PM
passionate
  • Please Login or Register to see this Hidden Content
  • 97 posts
  • Locationindia
Posted 15 June 2013 - 03:34 AM
I hate this ROM full of problems
passionate
  • 97 posts
  • Locationindia
Posted 15 June 2013 - 11:45 AM
hey stupids who replied my post this ROM full of problems....I believed its a waste ROM I ever see...I told this directly that's all okk....
Aneesh. You posted this about regular cm 10.1. If you hate cm10.1 so much this version of the rom isn't going to be of your liking either.
#25 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 29 June 2013 - 04:55 PM
passionate
  • 97 posts
  • Locationindia
passionate
  • 97 posts
  • Locationindia
no sir normally I'm using rage ROM and working greatly without any problem.. but today morning I flashed this ROM and working nicely...but problem with data ..I m using gsm sim on xt912 in india...I set the APN but still no use...
actually I told my problem that's all I am expecting some help from others nothing more.. I am not abusing or calling crap to anyone..sorry don't miss understand me..I am a noob in custom ROM area ... .. I think u understand what I said ...
#26 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 29 June 2013 - 06:14 PM
As I mentioned in an earlier post, GSM users might need a GSM patch since this build.prop is based on CDMA. I do not have a GSM patch for this ROM yet. I believe there is one somewhere on XDA, but I don't have a link handy at this time.
#27 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 29 June 2013 - 06:37 PM
sir I know its cdma ROM but on the same I downloaded rage cdma ROM previously and my data working fine for me..but when I tried this ROM I can possible to make calls text but only data is not working for me..I set the APN but still no use... pls understand my problem...
#28 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 29 June 2013 - 06:44 PM
I do not have much experience with XT910 so I honestly do not know what to tell you other than what I have mentioned regarding the gsm patch.
Do you have an XT910 or XT912? If you have an XT912, then you should be able to flash this ROM and add the correct APN details. If that is not working, then I'm afraid I cannot really help you since I have not personally used this ROM outside of the USA. I know Aviator Blur and AOKP work on XT912 on the GSM network because I have used it outside of the US.
  • aneeshmbabu likes this
#29 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 29 June 2013 - 06:48 PM
sir i having xt 912 verizon cdma working in gsm india
#30 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 29 June 2013 - 08:26 PM
yup finally data got worked  thanks all for valuable support
  • The Persuader likes this
#31 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 30 June 2013 - 12:52 AM
Flashed yesterday...Awesome so far...   Got a little ahead of myself not letting it settle in for 5 to 10 as stated...it was a little jumpy... Its Working Awesome so far
#32 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 30 June 2013 - 03:55 AM
What did you have to do to get it working? Do yon mind sharing just in case anyone else has the same problem? Thanks!
  • livinginkaos likes this
#33 RoaRk
RoaRk
  • 21 posts
  • Current Device(s):RAZR XT912
Posted 30 June 2013 - 05:14 AM
I seem to be getting rather horrendous mobile network coverage with this ROM. I installed following the instructions precisely, just tried to "fix permissions" again, but it's still pretty terrible. I actually had a call lost, which has NEVER happened to me before. Wireless is working flawlessly and so is everything else that I've seen, but for some reason the mobile network signal is super weak.
#34 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 30 June 2013 - 05:22 AM
yes I am ready to share I reflashed this ROM about 3 times ... recreated slot 1 wipe everything ..and finally got worked...thanks great ROM
#35 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 30 June 2013 - 05:40 AM
I known signal is not the best. I have even added signal tweaks to try and improve it. I will be looking for other ways to improve signal strength :)
#36 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 30 June 2013 - 05:43 AM
Good to hear it's working now!
#37 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 30 June 2013 - 07:05 AM
sir can I add ur cdma subscription ( Ruim/sim And Nv) in to any stock based ROM?? if yes tell me how to do..
#38 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 30 June 2013 - 08:56 AM
Can you take a Stronger Radio Frequency from another ROM or copy the apk and swap it out?
Its Bubba
#39 RoaRk
RoaRk
  • 21 posts
Posted 30 June 2013 - 09:22 AM
Good to know that this is a known issue. I love this ROM, but the signal strength is a bit of a deal breaker for me at the moment. Keep up the great work and I'll be back when we see a fix for this :)
#40 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 30 June 2013 - 10:13 AM
RoaRk...
Try this no promises but the reception might be better...
Goto Settings
* Chose More
* Then to Mobile Network
* Mow to Network Mode
Look for...LTE/CDMA/EVO
Back then Reboot and see if those setting work...I'm not having any issues as what you mentioned
Its Bubba
