Okay my friend...going to flip the switch to ARTopposite.
battery life should be better with ART because of the ahead of time compiling.
Its Bubba
"Stubborn In Your Bones"
Posted 26 November 2013 - 10:03 AM
Posted 26 November 2013 - 10:50 AM
Has anyone on the 11/25 CM been able to figure out how to get the stock messaging into the Dark Theme mode? On mine even when selected...it is still light.
Also, when I used ART. I get a force close on Titanium Backup. Should there be anything about ART that makes apps FC? If we install one under Dalvik and then switch will it cause problems or visa versa?
Posted 26 November 2013 - 11:01 AM
Its Bubba
Posted 26 November 2013 - 12:59 PM
Thanks for the quick updates. Quick question though. I have never gone from one Nightly to the next like this. Do I need to do a full wipe of cache, dalvik, system, and data, like a fresh install, or just flash over the top of the rom slot? Also, do I need to re-flash the Gapps again if its a dirty flash?
Posted 26 November 2013 - 01:03 PM
Posted 26 November 2013 - 01:13 PM
Its Bubba
try it on the pure CM build, not Aviator. The custom items in Aviator Settings cause it to Force Close and you won't be able to switch back without a re-flash
Droid Razr Maxx | SS3.6 AviatorBlur / CM11 N10 | RastaKat Xoom Wifi | Big Part 4.3 N7 | MultiROM / RastaKat OG Droid | kfazz CM10 port
Posted 26 November 2013 - 01:14 PM
ZK, I am reading a lot about ART being a battery saver. However, apps seem to FC when I switch over. Do you know anything about how this should work? Should all apps be loaded AFTER the switch?
PS. THis was on the pure CM 11/26 btw....
Posted 26 November 2013 - 01:23 PM
ART is suppose to be better overall, but it is still technically experimental and I think there will be compatibility issues for awhile to come. Some of the apps I put into the settings aren't playing nicely so for now just leave ART off any aviator builds
Posted 26 November 2013 - 02:41 PM
list of ART compatible apps can be found here
EDIT: doh! late to the party!
Posted 26 November 2013 - 03:01 PM
Transparent Status Bar? Am I missing something? Mine is black
Posted 26 November 2013 - 03:11 PM
Change the wallpaper
Nope. Maybe the dirty flash off the new 11/26 CM from dhacker.
Is yours based off of this?
Posted 26 November 2013 - 03:15 PM
Wondering if there is a list anywhere of working and not working stuff in Aviator 11/26 and or just CM 11/26?
Thanks!
Posted 26 November 2013 - 03:16 PM
Yes have the 4g, but all black, its not the wallpaper....
Posted 26 November 2013 - 03:24 PM
Thanks!
Did you read the thread at all?
