1077 replies to this topic
#341 Frostafarian
Frostafarian
  • LocationSeattle
Posted 25 November 2013 - 11:34 AM
Enable "Widget Pages".  Then exit and turn your screen off so it locks.  When you turn on the phone and see the lock screen, scroll to the left and you will see a + symbol.  It will then pop up your list of widgets to choose from.  You can select and hold the page to drag it to the right to be your main lockscreen.  You can, on some ROMs, delete the original page that is now to the left.  Also note, that the page to the right is the camera shortcut.  "Maximize Widgets" will basically open the widgets automatically, then you have to hit the lock button to get the slider to unlock the phone.
Vanwho,
I appreciate the rapid response. I actually already figured out the lockscreen widgets, but I appreciate the info about what "Maximize Widgets" does. What I was actually referring to in my original question is the lockscreen shortcuts that come from your slider, as shown in the below screenshot (see far right image):
Do you have any idea how to make that work? Right now all I can do is swipe right to unlock.
#342 vanwho
vanwho
    VanWho
  • 55 posts
  • LocationNorth Carolina
  • Current Device(s):razr maxx xt912
Posted 25 November 2013 - 11:52 AM
I did not see any options for those in this build.  Sorry for answering the wrong question.  I'm sure later builds will have the options added in by the Aviator team.
#343 vanwho
vanwho
    VanWho
  • 55 posts
Posted 25 November 2013 - 12:02 PM
I found a possible fix over at XDA Forums to try to get 3g to stop dropping out .  It says to go into the "More" section of Settings and go to the "Mobile Broadcasts" option.  Then, uncheck all of the boxes.  I'm not sure if it works or not, but it's worth a try.  I'll see if it helps or not.
#344 Frostafarian
Frostafarian
  • LocationSeattle
Posted 25 November 2013 - 12:06 PM
No problem, I appreciate your willingness to help. So are those screenshots only for the previous build of Aviator for 4.2?
#345 vanwho
vanwho
    VanWho
  • 55 posts
Posted 25 November 2013 - 12:12 PM
If you look at the middle one, it is 4.2.2 version CM 10.1.  I haven't seen those options for the new 4.4 yet.
#346 Frostafarian
Frostafarian
  • LocationSeattle
Posted 25 November 2013 - 01:38 PM
I see. Thanks again for the help. Perhaps I will just use the older version for the time being in that case.
#347 islandfever
islandfever
  • 353 posts
Posted 25 November 2013 - 01:56 PM
The lines when auto-rotating looks to be fixed in the 11/25 build.
Are there any other UI additions to this build? 1% battery?
#348 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 25 November 2013 - 02:04 PM
Most of that will come. CM11 has moved a bit of stuff around so I'll have to dig around more when I get the time :)
Sent from my DROID RAZR using Tapatalk 4
Donate? Click on signature :)
#349 islandfever
islandfever
  • 353 posts
Posted 25 November 2013 - 02:11 PM
It only seems to gage battery at this time in 10% increments so a third party battery wouldnt work right?
#350 dwh2o13
dwh2o13
  • 79 posts
  • LocationSt Louis, MO
  • Current Device(s):Droid RAZR MAXX
Posted 25 November 2013 - 02:23 PM
I'm seeing a pretty big hit on battery drain.  Is that typical  at this point?
#351 drewski11
drewski11
  • 186 posts
  • LocationSF Bay Area, CA
Posted 25 November 2013 - 02:52 PM
doesn't look like any UI additions.
his twitter feed says rotation graphics glitch & screenshots were fixed.
#352 drewski11
drewski11
  • 186 posts
Posted 25 November 2013 - 03:25 PM
the battery meter seems wonky, out of the box.
I lost 40% from full charge in an hour over lunch with 0 use.
it charged to full in <10 minutes.
I installed a battery calibration app (
 same one that's on the Aviator ROMs) and ran it.
now it swung the opposite direction and has been at 100% for about 2 hours, but that could be the 10% increment thing someone mentioned up-thread . . .
we'll see what happens over the course of the evening.
  • dwh2o13 likes this
#353 vanwho
vanwho
    VanWho
  • 55 posts
Posted 25 November 2013 - 03:58 PM
No battery issues for me. I'm at 70% after 9 hours plus of mixed use. After calibration I had no problems.
#354 JerryB
JerryB
  • 11 posts
Posted 25 November 2013 - 04:12 PM
Where am I able to download 11/25 build.  I will be coming from Aviator Blur 3.0.9 and would rather just go directly to 11/25 build instead of 11/22 which is on the home page.
Thanks!
#355 drewski11
drewski11
  • 186 posts
Posted 25 November 2013 - 05:35 PM
Thanks!
11/25 has not yet been Aviator-ized. there's a link in the pure CM thread.
sorry for any confusion.
#356 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 25 November 2013 - 07:27 PM
Are you running Dalvik or ART as one of your Wipes...if its ART...Battery Life will be much less than Dalvik
Its Bubba
"Stubborn In Your Bones"
#357 Mayank
Mayank
  • 11 posts
Posted 26 November 2013 - 03:58 AM
Getting error "Message not sent" I can receive message though but cannot send.
#358 dwh2o13
dwh2o13
  • 79 posts
Posted 26 November 2013 - 04:37 AM
Are you running Dalvik or ART as one of your Wipes...if its ART...Battery Life will be much less than DalvikIts Bubba"Stubborn In Your Bones"
Running Dalvic. Out of curiosity, how have you got location set?
#359 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 26 November 2013 - 05:12 AM
Location... High Accuracy
Its Bubba
#360 drewski11
drewski11
  • 186 posts
Posted 26 November 2013 - 09:05 AM
Are you running Dalvik or ART as one of your Wipes...if its ART...Battery Life will be much less than Dalvik Its Bubba "Stubborn In Your Bones"
opposite.
battery life should be better with ART because of the ahead of time compiling.
  • FrizzleFry likes this
