1077 replies to this topic
#321 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 23 November 2013 - 03:54 PM
The Kit Kat version runs well for an early release, I haven't tried bluetooth yet but everything else works great.  I also notice that the 3G icon does not appear but it appears that it still have it.
Bluetooth is working fine...But my experience with 4.4 is 99% of the time its LTE,.,Not 3G
#322 islandfever
islandfever
  • 353 posts
Posted 23 November 2013 - 04:24 PM
Do you mean 4.4 picks up LTE more often than other builds?
#323 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 23 November 2013 - 05:18 PM
Yes...
Its Bubba
#324 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 23 November 2013 - 05:26 PM
Yes...
Its Bubba
I agree. But I'm definitely happy with how it's going!
Donate? Click on signature :)
#325 vanwho
vanwho
    VanWho
  • 55 posts
  • LocationNorth Carolina
  • Current Device(s):razr maxx xt912
Posted 23 November 2013 - 05:43 PM
I had all signals drop for a second time in a few hours. I might have to wait for a more stable build. Shows promise though.
#326 vanwho
vanwho
    VanWho
  • 55 posts
Back to Aviator Blur 3.0.9 until new build with more fixes is available.
#327 islandfever
islandfever
  • 353 posts
Posted 24 November 2013 - 09:13 AM
Yes...
Its Bubba
Are you running the new nightly? How do you like it?
I am trying to decide whether to stay with this or go back to 3.0.9 or 10.1.3 ...
Sure wish it had the mods for status bar etc
#328 dwh2o13
dwh2o13
  • 79 posts
  • LocationSt Louis, MO
  • Current Device(s):Droid RAZR MAXX
Posted 24 November 2013 - 02:38 PM
About a day into cm10.11 Kk. I have to say I am liking the experience. I have noticed the lines when auto rotating and I do get the suggestion to switch SU when in Tibu.
#329 islandfever
islandfever
  • 353 posts
Posted 24 November 2013 - 02:48 PM
Where is USB debugging in kitkat now? TIBU keeps telling to to che k it but its not in settings anynore
#330 drewski11
drewski11
  • 186 posts
  • LocationSF Bay Area, CA
Posted 24 November 2013 - 03:04 PM
Where is USB debugging in kitkat now? TIBU keeps telling to to che k it but its not in settings anymore
still in Developer Options
if you don't see it, go to "About Phone" and click on Build Number field 7-8 times and it will make the Developer Options visible
#331 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 24 November 2013 - 03:22 PM
Me too with the lines...I'm sure on the next update it could be resolved
Its Bubba
#332 drewski11
drewski11
  • 186 posts
Posted 24 November 2013 - 04:37 PM
Settings Force Close when ART is enabled. I think it's the add ons (CPU Control, CPU Sleeper, etc) because settings work fine on the pure CM11 build with ART enabled
May be like the issue with core GApps FC'ing with ART. GApps builders are Odexing some of the apps for ART compatibility though dhacker29 says in this CM commit deodexed will work fine if done right
#333 islandfever
islandfever
  • 353 posts
Posted 24 November 2013 - 05:00 PM
What is ART? And Thx for the dev tip!
#334 bwat1009
bwat1009
  • 6 posts
  • Twitter:@bwat1009
  • LocationGreenville SC
  • Current Device(s):Droid Razr M rooted stock with unlocked bootloader, BN Nook Color running CM10 Nightlies
Posted 24 November 2013 - 06:20 PM
I have been running this for two days. Really smooth for such an early build. Have seen the reported screen distortion when auto rotating. Also, I can't take screenshots. Says that the "memory may be in use". Googled the error, most common fix was to delete the sdcard0\pictures\screenshots directory and recreate manually with a file explorer app. Tried this but no change. Any ideas?
#335 drewski11
drewski11
  • 186 posts
Posted 24 November 2013 - 09:09 PM
New runtime compiler and future replacement for Dalvik.
You can switch in the Developers Options menu.
Sent from my Nexus 10 using Tapatalk 4
#336 captainxnono
captainxnono
Posted 24 November 2013 - 11:24 PM
Aviator Kit Kat runs amazing considering how recently this build was released!
  • The Persuader likes this
#337 islandfever
islandfever
  • 353 posts
Posted 25 November 2013 - 06:59 AM
Ahh....tech stuff!
I am finding trouble with settings not taking changes in the 10.1.3 ROM unless you change things then reboot. They change but don't show up in settings. For example changing ringtone.
#338 Frostafarian
Frostafarian
  • LocationSeattle
Posted 25 November 2013 - 10:59 AM
Major n00b here (this my first custom ROM), I am absolutely loving the ROM so far and wishing I would have made the move off stock long ago! Thanks for the great work, I am feeling less abandoned right now with the move up to KitKat. One quick question: I can't figure out how to get custom lockscreen shortcuts from my slider. From googling it appears that on stock/Cyanogenmod Kit Kat or JB phones, you should be able to go to Settings - Lockscreen, and then find the option there. However, my Lockscreen settings page appears much more bare-bones, I only have the options to toggle "Maximize Widgets" and "Widget pager".
Is there something wrong with my install or am I just not looking in the right place? Lockscreen functionality was the main reason I made the jump, so I would really appreciate any guidance.
#339 vanwho
vanwho
    VanWho
  • 55 posts
Posted 25 November 2013 - 11:10 AM
Enable "Widget Pages".  Then exit and turn your screen off so it locks.  When you turn on the phone and see the lock screen, scroll to the left and you will see a + symbol.  It will then pop up your list of widgets to choose from.  You can select and hold the page to drag it to the right to be your main lockscreen.  You can, on some ROMs, delete the original page that is now to the left.  Also note, that the page to the right is the camera shortcut.  "Maximize Widgets" will basically open the widgets automatically, then you have to hit the lock button to get the slider to unlock the phone.
#340 drewski11
drewski11
  • 186 posts
Posted 25 November 2013 - 11:18 AM
The lines when auto-rotating looks to be fixed in the 11/25 build.
