1077 replies to this topic
#261 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 25 September 2013 - 11:31 AM
Uploaded the file again. Let me know if it doesn't work :)
Donate? Click on signature :)
#262 Einsteindks
Einsteindks
  • 340 posts
Posted 30 September 2013 - 08:04 AM
Ok, well, tried all I know and can't get the latest to work. Mind you, I'm no expert. No big deal, I like Aviator 305 anyway. No multi-shortcut customizable lock ring there, but everything else is stable.
Ah! The gapps you offer are for 4.3, and are not comparable with 4.2-the source of the most recent stable!
sent via RazrMaxx over Tapatalk, y'all!
#263 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 30 September 2013 - 12:56 PM
? The Aviator gapps are for 4.2 :)
Sent from my DROID RAZR using Tapatalk 4
#264 marty28645
marty28645
Posted 12 October 2013 - 08:06 AM
Love this rom and thaks for all the hard work you have put into all of the Aviator versions. The only problem I am having is mms doesn't work when I am connected to a wifi network. If I want to send a picture or a group message I have to disable wifi before it will send. Does anyone know how to fix this? Thanks in advance! KCCO  :)
#265 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 13 October 2013 - 03:31 AM
Did you try the MMS fix in the OP?
#266 evanlan
evanlan
Posted 15 October 2013 - 10:26 PM
Just rooted & installed SS yesterday, and I sure wish I had done it sooner! Big thanks to the Devs! I think this will be my daily driver. I have one problem on this ROM that also showed up on stock CM and maybe Aviator Blur (can't remember for sure): Is there a way to keep the Hardware Key backlight lit? It goes off after 5 sec., even when the screen is on. Not a big deal, but a minor PITA in the dark.
#267 Einsteindks
Einsteindks
  • 340 posts
Posted 16 October 2013 - 12:40 AM
I used Lux brightness app for that.
Fat-fingered from my D-Maxx.
#268 evanlan
evanlan
Posted 16 October 2013 - 08:03 AM
Thanks, I'll check it out.
#269 roadracer28
roadracer28
Posted 16 October 2013 - 03:42 PM
Thanks for the great ROM. This was my first - and it was super easy.
Ive only found one issue. Any given Wifi tether doesn't work - inc the baked in. Ive tried a few Play ones and my goto app Wifi Tether.
For the baked in tether, I can change the Wifi SSID on the phone and its not updated on the broadcast from my PC's. And it doesn't allow a PC to connect with open authentication.
Is there something that I am missing?
If I change back to my Verizon OTA 4.1.2, I can tether no problem.
Thanks.
#270 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 17 October 2013 - 12:38 PM
Thanks.
Did you turn your wifi off before trying to tether?
Sent from my iPad using Tapatalk HD
#271 DaSarge43
DaSarge43
  • LocationTidewater, Virginia
Posted 06 November 2013 - 11:06 AM
ok having issues with Aviator 3.0.7 on my XT912.  I load the ROM, but when I go to settings and select more --> mobile networks, it says Unfortunately, Settings is not responding
It won't connect up to VZW for service
#272 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 06 November 2013 - 11:31 AM
Aviator Blur 3.0.7? This is the Aviator CM thread but no big deal. Did you flash recently? I suspect it was a flashing error. I would delete the ROM slot and flash it again. Also, which version of safe strap ate you using?
#273 DaSarge43
DaSarge43
Posted 06 November 2013 - 01:25 PM
Yes I did it last night.  3.11 is Safe Strap Version  put it in ROM slot 1.  which ROM would you recommend I put on.  I love the Aviator ROM.  first one I have done.
#274 Einsteindks
Einsteindks
  • 340 posts
Posted 06 November 2013 - 01:37 PM
I'd recommend safely backing out of safestrap 3.11, and install safestrap 3.60. Then create your slots and flash in aviator 3.07 of your choice.
fat-fingered and Maxx-ed out.
#275 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 11 November 2013 - 02:44 PM
Getting Ready to give it a Drive...Read everything....Loooking Gooood....
"All Good Under The Hood" from I can see....
Chow
#276 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 11 November 2013 - 02:59 PM
Chow
Second guessing which to Flash...
Stable Version...I don't think so...or CM 10.1 # 18 than the Gapp...Not sure if their is a Point of Orgin or Start point Flashing this ROM...
Thanks...
#277 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 11 November 2013 - 03:11 PM
I would do stable 1.0.2. This is still based on 10.1, I've been following 10.2 closely and waiting for the first stable of that before I aviate it to the Aviator list!
#278 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 11 November 2013 - 03:17 PM
Awesome!!!!
Thanks for the Heads Up ZKK007...
Looks Awesome my Friend...Not sure Why I havent tried this sooner...I did Flash your First Release not sure why I left...No Worries...
I will be here for a while...
Thanks Bro...
Chow
#279 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 11 November 2013 - 06:06 PM
Awesome!!!!
Looks Awesome my Friend...Not sure Why I haven't tried this sooner...I did Flash your First Release not sure why I left...No Worries...
Thanks Bro...
Chow
ZK...
Wow Wow Wow!!!!!...
Snappy Little Devil...Quick, Fluent, Smooth and No Hesiation what so ever...
Had to move some Slots around but well worth the Real Estate...Park Place maybe will see...So far All The Ducts are Lining up Like Steams flowing to the Oceans,,,Yup...
Its Awesome ;)
#280 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 12 November 2013 - 02:50 AM
Awesome!!!
I will be Driving it around today... Should be a comfortable change
Thanks For the Very Quick ROM
It's Bubba
"Stubborn In Your Bones "
