1077 replies to this topic
#241 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 01 August 2013 - 03:16 PM
Seems this might be a known bug on all CM build
The Hardware Key change does not work. I changed the search to recent app and it still function as search, also updating the .kl file from SEARCH > APP_SWITCH does nothing also.
If most of your choices are not working...Reflash and start over...
Not having any issues your experiencing...all your changes your doing could be compounding your problems...
Its Bubba
"Stubborn In Your Bones"
#242 deboyz1014
deboyz1014
  • 115 posts
Posted 02 August 2013 - 05:44 AM
This is happening on other CM 10 build by other dev too so thats why I'm stating this.  There was a post back in April reporting the same issue on the XDA thread but it never got responded to.  I did the whole delete rom slot 1, create rom slot 1 and went through the whole process and search key > recent app does not work.  Neither is udpating the .kl file.
#243 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 03 August 2013 - 07:44 AM
Is this something that happens a lot? I really like the look and feel of the ROM. After shutting off and getting back into Safestrap I performed a cache/dalvik wipe and rebooted and it would not start the ROM. Just got a black screen. I waited for over a minute for the video splash screen to start and nothing happened.. why this happened??
#244 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 03 August 2013 - 09:29 AM
Have you deleted unnecessary CM Updater files recently?
Could clear Caches & Data...
*Settings... Apps...All...scroll to CM Updater...Reboot...
See if this helps or Reflash
Its Bubba
#245 nocturnalsixer
nocturnalsixer
  • 31 posts
Posted 05 August 2013 - 04:49 PM
Downloading it to try it out
#246 sdlynx
sdlynx
Posted 12 August 2013 - 04:53 PM
Downloaded this and set it up, works great! One small problem, pop-up windows and menus hide the main window when they come up. Is this fixable/normal/what's going on?
First screenshot is from longpressing a song in Apollo, second is the built in SMS pop-up.
Thanks!
SDLynx
  293.35KB   32 downloads
  275.89KB   32 downloads
#247 StealthFox13
StealthFox13
    Gen. Member (Subject to change)
  • 125 posts
  • LocationMinnesota
  • Current Device(s):Droid Razr Maxx (Refurb), Galaxy Note 10.1
Posted 14 August 2013 - 04:03 PM
Can I get some confirms/fixes to some issues. 1. 4g my 4g sucks. It will not stay on for more than a few minutes if at all. 2. Hotspot. Flick on hotspot. Radio shuts off. Fixes?
Sent from my DROID RAZR using Tapatalk HD
#248 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 15 August 2013 - 04:54 AM
WiFi in general is funky on this CM10.1. Every time I want to use the hotspot I need to turn off WiFi, reboot and then run the hotspot. If I then want to use WiFi, I need to stop the hotspot, reboot and turn on WiFi. 4g will sometimes not work upon rebooting, but usually I turn data off then on and it turns out fine. If not a reboot normally solves it. I know its annoying, but we are stuck with it for now :p
Donate? Click on signature :)
#249 StealthFox13
StealthFox13
  • 125 posts
  • LocationMinnesota
Posted 15 August 2013 - 04:16 PM
Does it matter which way you turn it off? It's working pretty good now but I figured I should ask in case I run into the problem later. Secondly Spotify won't stay logged in. Is this also normal?
#250 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 17 August 2013 - 06:09 PM
All I do is turn on Hotspot... End Of Story... Working Great with No Hesitation... Awful Nice u might say... Password on the initial Setup of course It's Bubba "Stubborn In Your Bones"
#251 Einsteindks
Einsteindks
  • 340 posts
Posted 23 August 2013 - 02:40 AM
Who's had good experience in fixing the no-see-SD card issue? Plz delete, got it working via kamikaze technique. sent via RazrMaxx over Tapatalk, y'all!
  • ZKK007 likes this
#252 samtwatson
samtwatson
  • 16 posts
Posted 11 September 2013 - 10:34 AM
Just added this ROM.  I also have the Blur version as well but this CM10.1 version seems to have it all!  WiFi tethering is working.  Signal is just fine.  LED Notification customizations work.  GPS apps are working too.  Multiple volumes can be changed in the volume settings.  All the added goodies from 4.2 without losing too much speed and performance.
This is an outstanding ROM once you delete ROM Slot 1 a few times, wipe the cache and privileges several times as explained in the instructions and you should be good to go!  I did run into several bugs at the beginning.  Home button wouldn't work at all, google speech would crash every time (update to app needed), and a variety of other issues I won't go into because they all got fixed with a reflash/wipe of the cache...etc.  Photosphere isn't in the camera app but hopefully that will be added soon :).
Thank you again 007!  Really great work here.  I do see where its not AS snappy as Blur but honestly its not bad at all.  We'll see how it stacks up once I get all my apps loaded up and see if it slows down then.  Until then...Great job!
Sam
#253 samtwatson
samtwatson
  • 16 posts
Posted 12 September 2013 - 06:31 AM
Alright...got my first bug thats annoying me enough to post it.
I am unable to update the main phone ringtones.  I can open the list to select from but when I actually select the new ringtone I want it will not update from the default values assigned during the initial install.
Any help?
EDIT:  I think my Zedge app messed up the ringtone folder locations.  In the process of fixing now manually but I do not think this is a ROM issue.  Sorry for the false alarm.
#254 samtwatson
samtwatson
  • 16 posts
Posted 17 September 2013 - 11:09 AM
Hello again :)
Is anyone having issues sending images over Text?  I tried the MMS fix listed in the OP but am still unable to send images via text.  I see the image appear and it says "Sending" but the image is never sent.  Hangouts works to send images so I know its not a signal thing...thoughts?
#255 samtwatson
samtwatson
  • 16 posts
Posted 19 September 2013 - 06:13 AM
Man I REALLY like this ROM but I might have to drop this ROM if I can't get the texts to start working.  Group texts are also acting up quite a bit.  Would clearing cache and permissions be a good starting place?
#256 drewski11
drewski11
  • 186 posts
  • LocationSF Bay Area, CA
Posted 19 September 2013 - 09:40 PM
I thought it was a hardware limitation.
No gyroscope that's needed for Photosphere.
Sent from my ASUS Transformer Pad TF700T using Tapatalk 4
  • ZKK007 likes this
#257 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 25 September 2013 - 07:33 AM
The latest stable CM came out on the 23rd so I'm going to get to putting a new Aviator CM out based on the latest stable build! :)
  • Einsteindks likes this
#258 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 25 September 2013 - 10:49 AM
I've added v1.0.2 to the OP. This works with Safestrap 3.60 as well as the old 3.11. You might experience the hot reboot when setting up WiFi just like the older version. The fix is the same: Wipe cache, dalvik cache and fix permissions. I have not inverted the MMS app on the new version. I will do this sometime in the future.
Let me know if anyone has any new issues. I'll give it a day or two before I push this via OTA Updater, so just ignore the OTA Update notification for now.
Enjoy! :)
#259 Einsteindks
Einsteindks
  • 340 posts
Posted 25 September 2013 - 11:04 AM
Website says that file is not available, just fyi.
#260 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 25 September 2013 - 11:15 AM
Ok, I'll upload it again :)
