Aviator_CM10.1_20130711_NIGHTLY is in the OP! I will be pushing this out via OTA updater for those of you who are running a previous nightly build.
Enjoy!
Posted 11 July 2013 - 07:33 AM
Also, what are the benefits over BLUR? Battery life? Anything?
In answer to this question, the best battery and performance will more than likely be on Blur based roms. Aviator Blur gets killer battery and performance.
You will generally find that an AOKP, AOSP, CM or PAC roms with less battery life and a little slower, at least thats what I have experienced.
Posted 11 July 2013 - 07:38 AM
Posted 11 July 2013 - 07:39 AM
Posted 11 July 2013 - 08:10 AM
Posted 11 July 2013 - 06:10 PM
Posted 11 July 2013 - 06:36 PM
Posted 12 July 2013 - 06:55 AM
Posted 12 July 2013 - 02:51 PM
Posted 12 July 2013 - 03:13 PM
Posted 12 July 2013 - 03:21 PM
Did you try and run wifical.sh in Terminal? and as su
Posted 12 July 2013 - 03:45 PM
Posted 12 July 2013 - 06:19 PM
Posted 12 July 2013 - 06:43 PM
Do you have the Terminal Emulator app or ROM Toolbox Pro has it as well. If not get one of those.
Then in Terminal Emulator type "su" (no quotes) and hit enter so now your root. Then type "wifical.sh" (no quotes) and hit enter to run the script. Hopefully that will fix the issue.
Posted 13 July 2013 - 04:05 AM
"If you truly learned from your mistakes, I would be a genius by now!"
