Whenever I turn on my phone by pressing the power button, it only displays this screen:
AP Fastboot Flash Mode (S) (Flash Failure)
0A.66
Device is LOCKED, Status Code:0
Battery OK
OK to Program
Connect USB
Data Cable
By pressing both pressing both volume buttons and the power button I am able to boot up normally from the boot selection screen, but I cannot flash anything. I have tried flashing fastboot files from rsd lite, but it stops immediately saying that it failed. Any solution to this?
EDIT: I am still on gingerbread 2.3.6, and am on the stock asian rom, if that matters.
AP Fastboot Flash Failure
pewpew
, Jun 27 2013 11:08 PM
2 replies to this topic
Posted 27 June 2013 - 11:08 PM
Posted 07 July 2013 - 05:35 AM
try flashing ur stock
Posted 07 July 2013 - 07:17 AM
If you boot fine past there, all you need to do is get something to flash. Just reflash tou r logo.bin and the fast boot start up should go away.
