AP Fastboot Flash Mode (s) (Recipe Failure) after Droid Razor Utility
FastbootBoot Loop
Best Answer ang , 05 February 2014 - 02:46 PM
I was able to recover from the Recipe error on my Droid RAZR MAXX.  After trying everything I've read on every post out there and almost quitting after the last post from a trusted moderator, I succeeded with the following steps:
1) Fully charged phone
2) Used Motorola cable
3) Upgraded driver to latest version 2.4.5
4) Used VRZ_XT912_9.8.2O-72_VZW-16-5_CFC.xml
5) Used RSDLite 5.7 with the following settings:
  1. Flash options: Restart after flexing and TI Blank flash
  2. Use image files and delete files on exit
Phone connects/disconnects multiple time on flash and then finally does a full reset where you will see droid with "blue electrical work animation."  RSDLite waits for phone to come back but it never will because after the animation the phone does a last reboot into the new image instead of into fastboot.  I've done multiple boots since and every time it works fine.
Go to the full post
58 replies to this topic
#41 ltdan
ltdan
  • 7 posts
  • Current Device(s):Droid X2
Posted 23 September 2013 - 08:44 AM
Ok think i figured out what might actually be causing this, i think it's an incomplete fastboot command, coz at the end of rsd lite and Matt's utility, where the phone is supposed to reboot, it just blanks out then brings the "recipe failure" up, i'll look at another xml file like from the bionic, see if there's a difference, if anyone knows a possible fix or xml edit for this be really nice, it sorta makes sense to me, coz it's only at that point of the flashing where it errors, right where it's supposed to reboot, hence the boot looping then, rsd says "PASS" coz the command initiates but don't think it knows that it didn't complete, any ideas on this or other ones lemme know, and thanx John for your input on the boot lock, i'll leave that alone, right now got the phone up and running with eclipse, but see what i can figure out today on this with a possible xml edit, thanx again to all, really appreciate your time, sincerely, rod
here's a copy of the xml code from my bionic xml file and the xt912 file, can't tell if anything is out of order on the xt912...
this is the cdma_spyder_9.8.20-72_VZW-16_1ff
<?xml version="1.0" encoding="UTF-8"?>
<flashing>
  <header>
    <phone_model model="SPYDER" />
    <software_version version="9.8.2O-72_VZW-16" />
    <interfaces>
      <interface name="AP" />
    </interfaces>
  </header>
  <steps interface="AP">
    <step operation="flash" partition="mbm" filename="allow-mbmloader-flashing-mbm.bin" MD5="55d703d1d8d8631f31be89a6069ad68e" />
    <step operation="reboot-bootloader" />
    <step operation="flash" partition="mbmloader" filename="mbmloader.bin" MD5="42f7110de49d6d28ea0540f1c02f9f1b" />
    <step operation="flash" partition="mbm" filename="mbm.bin" MD5="f541f64f56739d65c19557e33f8aef3c" />
    <step operation="flash" partition="motoboot" filename="motoboot.img" MD5="a2517202dd87b95e63bc52f092449c10" />
    <step operation="erase" partition="cache" />
    <step operation="flash" partition="logo.bin" filename="logo.bin" MD5="cd111cc7b675e62a7d85a50632fb88e8" />
    <step operation="flash" partition="devtree" filename="device_tree.bin" MD5="04e2f24447783a0ff32e86e0dca1d0c0" />
    <step operation="flash" partition="system" filename="system.img" MD5="b2b52f5917990ee52b5ec78bdbbc5167" />
    <step operation="flash" partition="boot" filename="boot.img" MD5="4b041e7af8bd8ed30610d7c6eb18df39" />
    <step operation="flash" partition="recovery" filename="recovery.img" MD5="9a73f1b364990cf326324db1f856fe50" />
    <step operation="flash" partition="cdrom" filename="cdrom" MD5="fd1d40c2b40f0222eb8ef98aeb3aa87c" />
    <step operation="flash" partition="preinstall" filename="preinstall.img" MD5="fb0c510d318004120ea3269e39de1c1d" />
    <step operation="flash" partition="radio" filename="radio.img" MD5="e68433c86794d0439363baf7bcf303f5" />
  </steps>
</flashing>
this is the VRZ_XT875_5.9.905.Verizon.en.US_CFC
<flashing>
  <header>
    <phone_model model="TARGA" />
    <software_version version="5.5.1_84_DBN-74" />
    <interfaces>
    </interfaces>
  </header>
    <step operation="flash" partition="mbm" filename="allow-mbmloader-flashing-mbm.bin" MD5="f6102e4b34c74cfefd5e80151a6913ff" />
    <step operation="flash" partition="mbmloader" filename="mbmloader.bin" MD5="b0c30799c8509c4d66599550e3fbdd82" />
    <step operation="flash" partition="mbm" filename="mbm.bin" MD5="da0b9ae7f38048a2987e0ae24593fb4b" />
    <step operation="flash" partition="cdt.bin" filename="cdt.bin" MD5="fd8c44b060415dfd963fa870ae7a4f35" />
    <step operation="erase" partition="userdata" />
    <step operation="erase" partition="emstorage" />
    <step operation="flash" partition="lbl" filename="lbl" MD5="239bbc49a9cdb329577074ba60bbf1e5" />
    <step operation="flash" partition="logo.bin" filename="logo.bin" MD5="06c07c2970460a4e656a3206859a3617" />
    <step operation="flash" partition="ebr" filename="ebr" MD5="4c6df9afcd64661036a982e03eb1aa1a" />
    <step operation="flash" partition="mbr" filename="mbr" MD5="712e3e3757219ecfd925eb43be14f944" />
    <step operation="flash" partition="devtree" filename="device_tree.bin" MD5="2404a4f245f1da389d3422d0d59be24a" />
    <step operation="flash" partition="system" filename="system.img" MD5="8e306ac58dd4fcf01566c517eabc098d" />
    <step operation="flash" partition="boot" filename="boot.img" MD5="b64b38a48897c51fe229cf80a095d235" />
    <step operation="flash" partition="recovery" filename="recovery.img" MD5="ce9ee505c7fc708f7394617907ae5694" />
    <step operation="flash" partition="cdrom" filename="cdrom" MD5="6bdf130ecaa5183c0e463d2f3fa5d966" />
    <step operation="flash" partition="preinstall" filename="preinstall.img" MD5="f7f2ff434d2b0c819c1e28744d1b4d01" />
    <step operation="flash" partition="emstorage" filename="emstorage.img" MD5="953494fd0d356f25a58842f1a41b132d" />
    <step operation="flash" partition="webtop" filename="grfs.img" MD5="c9502cd8fd6fa7206c64e4dae3ed9b50" />
    <step operation="flash" partition="radio" filename="radio.img" MD5="683184cc2522ba00e6a0c38d321a8806" />
  </steps>
</flashing>
09.24.13 update
ok, called motorola, they glazed over on this, so gonna just let this phone go and move into the xt926 model, that's the fix for the recipe failure  ;)
#42 brob8576
brob8576
Posted 08 January 2014 - 09:23 PM
I believe the repair was found here:
I had the same problem, and this resolved it in less than a minute!
#43 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 09 January 2014 - 05:01 AM
Appreciate the input man but the recipe failure is different than just a standard flash failure and is not fixed but just flashing a boot logo.
  • cmh714 likes this
#44 cmh714
Posted 11 January 2014 - 08:41 AM
I for one have never ever seen a fix for recipe failure, and I have searched long and hard trying to assist others.
#45 ang
ang
Posted 05 February 2014 - 02:46 PM   Best Answer
  • SamuriHL, johnthehillbilly, cmh714 and 5 others like this
#46 cmh714
Posted 05 February 2014 - 03:07 PM
Glad youre back, and yes this is the first I have ever seen someone recover from that error message. I hope it works for others. Thanks for posting.
  • Memnoch73 and johnthehillbilly like this
#47 livinginkaos
Posted 05 February 2014 - 03:18 PM
Should this info end up in its own thread so the fix can be found in a thread op.??
Sent From My DEV X
  • johnthehillbilly likes this
#48 cmh714
Posted 05 February 2014 - 03:21 PM
at the very least I marked it Solved.....
#49 johnthehillbilly
Posted 05 February 2014 - 03:22 PM
Sent From My DEV X
Yes it should!!!! :) ..... Recovering from that error has proven to be next to impossible ..... So this is a major breakthru !!!!!
"No more training do you require...... already know you, that which you need...."
  • cmh714 likes this
#50 livinginkaos
Posted 05 February 2014 - 03:25 PM
Ang, wanna do the honors?
Sent From My DEV X
#51 ang
ang
Posted 05 February 2014 - 05:14 PM
I'm a "noob" on this forum.  I would like someone to be able to replicate.  I obviously can't get it back to the recipe error to retest the process as we don't really know what causes it.  It's probably some combination of root method, images applied, software/driver combination and possibly bad cable/low battery flashes.
#52 jtm2381
jtm2381
  • Locationhillsborough ,new jersey
  • Current Device(s):droid razr maxx
Posted 21 February 2014 - 12:38 PM
Man what a life saver ,it worked like a charm.my razr maxx is running like new Thanks ANG.
  • Memnoch73, johnthehillbilly, livinginkaos and 1 other like this
#53 sonsila
sonsila
Posted 12 March 2014 - 01:19 PM
I used this on my droid razr and it worked flawlessly...thank you...much KUDOS!!!!!
  • johnthehillbilly, livinginkaos, cmh714 and 1 other like this
#54 icprod
icprod
Posted 16 March 2014 - 10:00 AM
I tryed and gaveme the same arror so i update the RSD lite to the vertion 6 and worked womderfull
  • livinginkaos and cmh714 like this
#55 Drayy
Drayy
  • Current Device(s):LG G2
Posted 31 July 2014 - 08:38 PM
I tried this Multiple times with no success.  Then I decided I better follow directions 100% and let phone fully charge.  The next day I tried and again and worked like a charm!  Great instructions.  Thanks!
#56 mustang302
mustang302
Posted 08 December 2014 - 10:15 AM
Use the file in the original post (Search on google, it's the very first post) It works great . Thhanks for the info.
#57 FareakyGeek
FareakyGeek
  • 29 posts
Posted 08 January 2015 - 12:47 AM
Guys This Is Realy Work :D  ;)
#58 theawesome1
theawesome1
Posted 24 January 2015 - 07:44 PM
Thank you, thank you, thank you. I have been scouring the web for solution to this, and have tried multiple solutions. This one works perfectly.
Thank you again
#59 Alice_Cooper
Alice_Cooper
  • LocationIoannina, Greece
  • Current Device(s):Lenovo VIBE P1m
Posted 03 September 2016 - 03:06 PM
I solve it with this command
I think this work like this
now the device boot in ap fastboot mode
at the end just with
go back to normal boot mode
