RAZR Error: I need help !
razr fastboot flash mode xt910 flash failure motoboot solution
5 replies to this topic
#1 Naaiki
Naaiki
Posted 21 June 2013 - 10:05 AM
Hi !
I'm a new member in this foro.
I need help with my Motorola Razr XT910. I'm from Argentina.
I need to know how to reinstall the system to my cellphone.
I try different processes lei forum but can not find solution. Errors like these are after me trying to solve by using the RSD Lite program file: cdma_spyder_9.8.2O-72_VZW-16_1ff.xml
 6/16 she tell me "failed flashing process 6/16 flash motoboot.
AP Fasboot Flash Mode (S) (Flash Failure)
Info: Size 16G
Device is Locked. Status Code: 0
Battery Low
Cannot Program
Connect USB
Data Cable
I hope you can help me.
Thank you.
#2 livinginkaos
Posted 21 June 2013 - 11:46 AM
First off, the battery is low so nothing will flash until you get that thing charged
  • ZKK007 likes this
#3 johnthehillbilly
Posted 21 June 2013 - 03:47 PM
You will need to either buy a team black hat adapter.....
..... or make a "factory" cable so you can get power to it so flashing will be possible again
#4 chdwrk
chdwrk
  • 36 posts
  • Twitter:workca
  • Locationnear Buffalo, NY
  • Current Device(s):Razr, Razr HD
Posted 21 June 2013 - 04:55 PM
A while back I had to pry my XT912 apart to get to the battery and tape bare wires to charge it. But that's not the best idea
Sent from my XT926 using Tapatalk 4 Beta
#5 johnthehillbilly
Posted 21 June 2013 - 04:59 PM
Very effective method, however, extremely high risk :)
  • chdwrk likes this
#6 cmh714
Posted 22 June 2013 - 07:03 AM
Besides needing to get your battery charged, it appears to me that you are trying to flash the incorrect file. The file you listed is for the Razr Maxx xt912 not the 910.
You need one of the files from here:
  • livinginkaos likes this
Also tagged with one or more of these keywords: razr, fastboot, flash mode, xt910, flash failure, motoboot, solution
