AP Fastboot flash Mode (S) loop
AP Fastboot brick flash failure device is unlocked status code: 3
Best Answer johnthehillbilly , 17 June 2013 - 12:49 PM
Theres the problem.... windoze 8.... LOL
Seriously tho.... windoze 8 does not play nice with our utilities sometimes....
tapadriving ...... hillbilly style Go to the full post
13 replies to this topic
#1 aslowe
aslowe
  • Twitter:asl0we
  • Google+:101691710251881209717
  • LocationFort Wayne
  • Current Device(s):Moto X
Posted 17 June 2013 - 12:05 PM
I was running CM 10 and CWM on my XT907.  (this was the thread I used to get that setup -
Audio was questionable so I decided to go back to stock.  Current OS and recovery status is unknown because I cannot get anywhere to see them.
I cannot boot the phone.  I get the fastboot menu everytime I try to boot it regardless of key combos
I have read through about a dozen different threads with variations of this problem.  None exactly like mine.  I have tried several different solutions from RSD Lite restores to Droid Razr M Utility.
(error from utility - "'fastboot' is not recognized as an internal or external command, operable program or batch file.")
My goal is to have rooted with a stock image that I can debloat.
This is what my Fastboot Menu displays. Thoughts anyone?
AP Fastboot Flash Mode (S)
10.9B(*) (sha-1e9f557, 2013-04-05 09:36:59)
eMMC Info: Size 8GB
Device is UNLOCKED, Status Code: 3
Battery OK
Transfer Mode:
USB Connected
Fastboot Reason: Flash Failure
usb connected
#2 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 17 June 2013 - 12:09 PM
eMMC Info: Size 8GB
Battery OK
Transfer Mode:
USB Connected
usb connected
Sounds like you are either not it the folder with fastboot when running the commands or you do not have it on your computer. Have you tried matts utility?
#3 johnthehillbilly
Posted 17 June 2013 - 12:10 PM
With the utility.... you have to completely extract the zip file to desktop and run the executable(.bat file for windows or .sh file for Linux and Mac) from within the folder
And for windows, make sure your drivers are up to date..... :)
Edit ninj'd by Tim :) :ph34r:
  • timpohladthomas likes this
#4 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 17 June 2013 - 12:12 PM
:ph34r:
#5 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 17 June 2013 - 12:16 PM
:ph34r:
:ph34r:
#6 aslowe
aslowe
  • Twitter:asl0we
Posted 17 June 2013 - 12:21 PM
The utility you are all referring to is the one I have tried to use and I get the error message.  I am running it from my desktop as well with admin access.
#7 johnthehillbilly
Posted 17 June 2013 - 12:27 PM
Indeed.... the only reason you should be getting that error is that the utility is not "seeing" the fastboot files which are included in the utility..... try to extract the utility again.....make sure you are using winrar or WinZip to extract (they are typically the best for complete extraction) then try running again :)
#8 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 17 June 2013 - 12:28 PM
As stated above that is the error when you have not extracted the Utility properly. What did you use to extract it? Try winrar...
ninja'd  :ph34r:
#9 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 17 June 2013 - 12:32 PM
People getting ninja'd like crazy today.
  • Memnoch73 and johnthehillbilly like this
#10 aslowe
aslowe
  • Twitter:asl0we
Posted 17 June 2013 - 12:43 PM
I ran it from my Linux machine and it ran flawlessly.  I've had so many problems doing anything with my devices on Windows 8.  Thanks guys.
  • Memnoch73 likes this
#11 johnthehillbilly
Posted 17 June 2013 - 12:49 PM   Best Answer
#12 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 17 June 2013 - 01:05 PM
LINUX OR BUST!!
  • johnthehillbilly and LSDWiZaRd like this
#13 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
  • Twitter:@BytecodeMe
Posted 17 June 2013 - 07:50 PM
Arch Linux or Bust
Sent from my Nexus 4 using Tapatalk 4 Beta
  • johnthehillbilly likes this
#14 johnthehillbilly
Posted 17 June 2013 - 07:56 PM
Bodhi.....Arch......Mint.....Ubuntu....... :)
Also tagged with one or more of these keywords: AP Fastboot, brick, flash failure, device is unlocked, status code: 3
